Positive Thermal Coefficent Diodes
RLVR240-012~055 Series
The RLVR240 Series is designed to protect against short duration high voltage fault currents (power cross or power
induction surge) typically found in telecom applications . The series can be used to help telecom
networking equipment meet the protection requirements specified in ITU K.20 and K.21.
Features
ROHS
• 0.12 – 0.55 hold current range, 240VAC operating voltage
• 240VAC interrupt rating
• Fast time–to-trip
• Binned and sorted narrow resistance ranges available
• RoHS compliant, Lead- Free and Halogen-Free*
Applications
• Customer Premises Equipment (CPE)
• Central Office (CO)/ telecom centers
• LAN/WAN equipment
• Access equipment
• PC peripherals
• Point-of-sale (POS) equipment
• PCMCIA cards
• USB port protection - USB 2.0, 3.0 & OTG
• HDMI 1.4 Source protection
• Computers&peripherals
• General Electronics
Dimension
A
Part Marking System
C
A
C
rademark
B
HR 250
080
XXXX
Voltage Rating
Current Rating
Date Code
rademark
HR 250
120
XXXX
Voltage Rating
Current Rating
Date Code
B
D
D
F
E
Fi ure 1
Type Number
F
E
Fi ure 2
Figure
A
mm
Max
B
mm
Max
C
mm
Max
D
mm
Min
E
mm
typ
F
mm
Min
RLVR240-012
1
8.3
12.9
3.8
7.6
5.1
0.6
RLVR240-016
1
9.9
13.8
3.8
7.6
5.1
0.6
RLVR240-025
2
9.6
18.8
3.8
7.6
5.1
0.6
RLVR240-033
2
11.4
29.0
3.8
7.6
5.1
0.6
RLVR240-040
2
11.5
20.9
3.8
7.6
5.1
0.6
RLVR240-055
2
14.0
22.4
4.1
7.6
5.1
0.6
All data is subject to change,Please check our data sheets at www ruilon com for updates.
©2012 RuiLong Yuan,Inc.
PTC 01
Electriacl Characteristics
Ihold
Itrip
Vmax
Imax
Pd
max.
(A)
(A)
(VAC)
(A)
(W)
Rmin
(Ω)
R1max
(Ω)
RLVR240-012
0.12
0.30
240
1
1
3.0
6.5
RLVR240-016
0.16
0.37
240
3
1.5
2.5
4.1
RLVR240-025
0.25
0.56
240
3
1.5
1.3
2.1
RLVR240-033
0.33
0.74
240
3
1 .5
0.77
1.24
RLVR240-040
0.40
0.90
240
3
1.5
0.60
0.97
RLVR240-055
0.55
1.25
240
3
1.5
0.45
0.73
Type Number
Resistance
Ihold = Hold current: maximum current device will pass without tripping in 23°C still air.
Rmin = Minimum resistance of device in initial (un-soldered) state.
Itrip = Trip current: minimum current at which the device will trip in 23°C still air.
Rtyp = Typical resistance of device in initial (un-soldered) state.
Vint = Maximum voltage the device can withstand without damage at rated current (Imax)
Vop= The device regular operation voltage
Imax = Maximum fault current device can withstand without damage at rated voltage (Vmax)
Pd = Power dissipated from device when in the tripped state at 23°C still air.
R1max = Maximum resistance of device at 20°C measured one hour after tripping.
Caution: Operation beyond the specified rating may result in damage and possible arcing and flame.
PTC 02
Note: If soldering temperatures exceed the recommended
requirements.
Condition
30 Sec ~ 60 Sec
Preheat 160°C ~ 190°C
60 Sec ~ 90 Sec
Storage Condition
0°C~35°C, < 70%RH
air oven, N2 environment for lead-free.
Soldering
260
Temperature (°C)
260°C > 5 Sec
Peak Temp/ Duration Time
> 220°C
Cooling
220
Preheating
190
160
• Devices are not designed to be wave soldered to the
bottom side of the board.
• Devices can be cleaned using standard industry methods
and solvents.
30 to 60
60 to 90
120
Time(s)
Note:
requirements.
Lead Material
Tin-plated Copper
Soldering
Characteristics
Solderability per MIL–STD–202,
Method 208E
Insulating Material
Device Labeling
meets UL94V-0 requirements.
Marked with 'LF', voltage, current rating,
and date code.
RUILONG.YUAN CO.,LTD
Tel: +86- 0755-82908296
Fax: +86- 0755-82908002
Operating/Storage
Temperature
-40°C to +85°C
Maximum Device Surface
Temperature in Tripped State
125°C
Passive Aging
65°C/85°C, 1000 hours
Humidity Aging
+85°C, 85% R.H,.1000 hours
Thermal Shock
MIL–STD–202F, Method 107G
+125°C to -55°C 10 times
Solvent Resistance
MIL–STD–202, Method 215F
Moisture Sesitivity Level
Level 1, J–STD–020C
Email: jack@ruilon.com
Website: http://www.ruilon.com
RuiLongYuan Electronics are trademarks.
Information furnished is believed to be accurate and reliable. However, users should independently evaluate the suitability of and test each
product selected for their own applications. RUILONYUAN Electronics reserves the right to change or update, without notice, any information
contained in this publication; to change, without notice, the design, construction, processing, or specification of any product; and to discontinue
or limit production or distribution of any product. This publication supersedes and replaces all information previously supplied. Without
expressed or written consent by an officer of RUILONYUAN Electronics, RUILONYUAN Electronics does not authorize the use of any of its
products as components in nuclear facility applications, aerospace, or in critical life support devices or systems. RUILONYUAN Electronics
expressly disclaims all implied warranties regarding the information contained herein, including, but not limited to, any implied warranties of
merchantability or fitness for a particular purpose. RUILONYUAN Electronics’ only obligations are those in the RUILONYUAN Electronics
Standard Terms and Conditions of Sale and in no case will RUILONYUAN Electronics be liable for any incidental, indirect, or consequential
damages.
PTC 03
很抱歉,暂时无法提供与“RLVR240-012”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.24300
- 50+0.95480
- 500+0.88000
- 国内价格
- 5+1.96753
- 50+1.53372
- 150+1.34778
- 500+1.03723
- 2500+0.93400
- 5000+0.87199
