uP9616PDC8
uP9616PDC8
    UPI(力智)
    VDFN8
    uP9616PDC8
uP9616PDC8 数据手册
uP9616 Conceptual tia l 3.3A Charger Interface, Wide Input Sensorless CC/CV Synchronous-Rectified Buck Converter for QC2.0/QC3.0/PE+1.1/PE+2.0 And FCP Applications General Description † † PDA Like Device Car Chargers Portable Charging Devices Ordering Information en The uP9616 is a high-efficiency synchronous-rectified buck converter with an internal power switch. With internal low RDS(ON) switches, the high-efficiency buck converter is capable of delivering up to 3.3A output current for charger interface and a wide input voltage range from 8V to 32V. It operates in either CV (Constant Output Voltage) mode or CC (Constant Output Current) mode and provides a current limitation function. The uP9616 has a constant output voltage 5.2V/9V/12V for Qualcomm® Quick ChargeTM 3.0/ 2.0(QC2.0/QC3.0) that is detected from D+ and D- line and automatically detects whether a connected Powered Device (PD) is Quick Charge (QC2.0/QC3.0) capable before enabling output voltage adjustment. If a PD not compliant to Quick Charge (QC2.0/QC3.0) is detected, the uP9616 disables output voltage adjustment to ensure safe operation with legacy 5.2V only USB PDs. uP9616 is a USB secondary side fast-charging converter, supporting Qualcomm® Quick ChargeTM 3.0 (QC 3.0) High Voltage Dedicated Charging Port (HVDCP) Class A specification. uP9616 allows for selection of the output voltage of an AC/ DC USB adapter based on commands from the Portable Device (PD) being powered. Selecting a higher charging voltage will reduce the charging current for a given power level resulting in reduced IR drops and increased system efficiency. Another advantage of QC3.0 is a decreased battery charging time and a reduced PD system cost thanks to the ability to select an optimum charging voltage. This eliminates the need for costly DC/DC converters within the PD. The USB-bus voltage can be controlled in discreet steps from 3.6 V up to 12.1V. The output current is limited not to exceed maximum allowable power level. Other features for the buck converter include internal softstart, adjustable external CC (Constant Output Current) limit setting, built-in fixed line-compensation, short circuit protection, VIN/VOUT over voltage protection, and over temperature protection. It is available in space saving VDFN6x5-8L and VDFN5x6-10L packages. Order Number Package Type Top Marking uP9616PDC8 VDFN6x5-8L uP9616P uP9616PDYA VDFN5x6-10L uP9616P uP9616-DS-C3202, Feb. 2017 www.upi-semi.com Pin Configuration VIN 1 VIN 2 8 LX 7 BOOT GND D+ 3 6 SENSE+ D- 4 5 SENSE- VIN 5 CC2 CC1 D+ 4 3 9 8 7 6 SENSE+ BOOT LX LX 10 GND 2 1 D- VDFN6x5-8L SENSE- uP IC on fid Note: (1) Please check the sample/production availability with uPI representatives. (2) uPI products are compatible with the current IPC/JEDEC J-STD-020 requirement. They are halogen-free, RoHS compliant and 100% matte tin (Sn) plating that are suitable for use in SnPb or Pb-free soldering processes. VDFN5x6-10L 1 uP9616 Conceptual Features † Compliant with Apple® and Samsung Devices Certification: uP9616 is certified by Qualcomm® and UL. Please refer to the information below for verification: l † Internal QC2.0/QC3.0/PE+1.1/PE+2.0/FCP Protocol and USB Type C „ Qualcomm Quick Charge is a product of Qualcomm Technologies, Inc. † Wide Output Voltage Range: 3.6V to 12.1V „ UL Certificate No. 47876554328-2 for uP9616 Series † Output Voltage Accuracy: +1.5% † Fixed 125kHz Frequency Operation † Up to 95% Conversion Efficiency † Fixed Cable Compensation Voltage † Adjustable External CC (Constant Output Current) Limit Setting: Default = 3.3A † CC (Constant Output Current) Limit Accurarcy:+3% † Short Circuit Protection † VIN/VOUT Over Voltage Protection and Over Temperature Protections † VDFN6x5-8L and VDFN5x6-10L Packages † RoHS Compliant and Halogen Free † Wide Input Voltage Range : 8V to 32V † Input Voltage Absolute Maximum Rating: 36V † Up to 3.3A Output Current † CV/CC Mode Control (Constant Voltage and Constant Current) en „ http://www.qualcomm.com/documents/quickcharge-device-list tia † fid † Supports USB DCP Shorting D+ Line to D- Line Per USB Battery Charging Sepecification BC 1.2 † Supports USB DCP Applying 2.7V on D+ Line and 2.7V on D- Line † Supports USB DCP Applying 1.2V on D+ Line and D- Line VIN=8V~32V on Typical Application Circuit VIN C1 100uF/50V BOOT C3 0.1uF C2 1uF/50V GND RSENSE 39m ohm VOUT = 3.6V~12.1V LX uP9616PDC8 D+ SENSE+ D- SENSE- VIN BOOT IC L1 22uH R1 3.3 ohm C6 3.3nF C4 22uFx4/16V/X7R/MLCC 220uF/16V/ESR=90m ohm/EC 220uF/16V/ESR=25m ohm/OSCON C5 0.1uF/16V USB/FCP VIN=8V~32V USB/FCP/QC 2.0 and 3.0 GND uP9616PDYA D- L1 22uH RSENSE 39m ohm VOUT = 3.6V~12.1V LX D+ SENSE+ R1 3.3 ohm C6 3.3nF C4 22uFx4/16V/X7R/MLCC 220uF/16V/ESR=90m ohm/EC 220uF/16V/ESR=25m ohm/OSCON C5 0.1uF/16V CC1 USB Type C Detect 2 C3 0.1uF C2 1uF/50V uP C1 100uF/50V SENSECC2 uP9616-DS-C3202, Feb. 2017 www.upi-semi.com uP9616 Conceptual Functional Pin Description Pin No. Pin Name Pin Function PDYA 1,2 5 VIN Pow er Supply Input. Input voltage that supplies current to the output voltage and powers the internal control circuit. Bypass the input voltage with a minimum 1uFx1 X5R or X7R ceramic capacitor. -- 4 CC1 USB Type C Port CC1 Input Connection. CC1 Voltage On Source Side. -- 3 CC2 USB Type C Port CC2 Input Connection. CC2 Voltage On Source Side. 3 2 D+ USB Port D+ Input Connection. USB D+ data line input. 4 1 D- USB Port D- Input Connection. USB D- data line input. 5 10 SENSE- 6 9 SENSE+ The Current Sense Input (+) Pin. Adjustable line and cable compensation voltage. 7 8 BOOT Bootstrap Supply for the Floating Upper Gate Driver. Connect the bootstrap capacitor C BOOT between BOOT pin and the LX pin to form a bootstrap circuit. The bootstrap capacitor provides the charge to turn on the upper MOSFET. Typical value for C BOOT is 0.1uF or greater. Ensure that C BOOT is placed near the IC. 8 6,7 LX en fid The Current Sense Input (-) Pin. Adjustable line and cable compensation voltage. Internal Sw itches Output. Connect this pin to the output inductor. Ground. Ground of the buck converter. The exposed pad is the main path for heat convection and should be well-soldered to the PCB for best thermal performance. uP IC on Exposed Pad (GND) tia l PD C 8 uP9616-DS-C3202, Feb. 2017 www.upi-semi.com 3 uP9616 Conceptual Functional Block Diagram tia l VIN POR Internal Regulator POR VCC VREF VA VA VREF_CV COMP_CV en Current Sense BOOT UG Driver VREF_UVP UVP FB LX VCC VREF_OVP OTP SENSEX1 Control & Protection Logic fid OVP LG Driver OTP GND COMP_CC SENSE+ VREF_CC Diff Amplifier EN EN Logic Current Sense/CC (Constant Output Current) Limit Amplifier CC1 USB TYPE C BC1.2/QC2.0/ QC3.0/FCP D+ CC2 Line/Cable Compensation D- uP IC PE+1.1/PE+2.0 on Set Current Limit 4 uP9616-DS-C3202, Feb. 2017 www.upi-semi.com uP9616 Conceptual Functional Description CV/CC Mode Control l 200 tia 150 VCOMP (mV) 100 RCOMP = 60mV/A (Fixed) 50 en The uP9616 provides CV/CC function. It operates in either CV (Constant Output Voltage) mode or CC (Constant Output Current) mode. The function provides a current limitation function and adjusts external current limit setting (Default=3.3A). In the CV mode, the output voltage is controlled within +1.5%. In the CC mode, the output current variation is less than +3% of the nominal value which can be set up to 3.3A by the current sensing resistor. When Output current increase until it reaches the CC limit set by the RSENSE resistor. At this point, the device will transition from regulating output voltage to regulating output current, and the output voltage will drop with increasing load. CC (Constant Output Current) Limit = 0 500 1000 1500 2000 2500 3000 ILOAD (mA) Figure 1 USB Cable Compensation at a Fixed Resistor Divider Value fid The CC (Constant Output Current) limit is set at 3.3A by default with an external resistance RSENSE = 39mΩ, When the (SENSE1+) - (SENSE1-) voltage gets higher than 130mV and reaches the current limit, the driver is turned off. The CC (Constant Output Current) limit is set according to the following equation: 0 130mV RSENSE Output Cable Resistance Compensation The uP9616 continuously monitors the inductor current, when the inductor current is higher than current limit threshold, the current limit function activates and forces the upper switch turning off to limit inductor current cycle by cycle. Output Short Circuit Protection IC on In charger applications, the large load will cause voltage drop in the output cable. The uP9616 has a built-in cable compensation function. When the load increases, the cable compensator will increase an adjustable regulation of the error amplifier that can make the output voltage constant. Use the curve and table to adjust internal the reference voltage values for fixed USB cable compensation by outside resistance RSENSE = 39mΩ (default), as shown in Figure 1 and Table 1.The fixed cable compensation is calculated as follows: Current Limit Protection VCOMP = ILOAD x RCOMP RCOMP(mΩ) 60 Fixed USB Cable Compensation Voltage (mV) 0 0 uP ILOAD(mA) 500 0 1000 60 1500 90 2000 120 2500 150 3000 180 The uP9616 provides output short circuit protection function. Once the output loader short-circuits, the SCP will be triggered then always hiccup, the hiccup cycle time is set by an internal counter. When the SCP condition is removed or disappears, the converter will resume normal operation and the hiccup status will terminate. Output Over Voltage Protection The uP9616 provides output over voltage protection. Once the output voltage (measured the at SENSE- pin) gets higher than OVP threshold, the OVP will be triggered to shut down the converter. When the OVP condition disappears, the converter will resume normal operation and resume the normal state automatically. Over Temperature Protection The OTP is triggered and shuts down the uP9616 if the junction temperature is higher than 150oC The OTP is a non-latch type protection. The uP9616 automatically initiates another soft start cycle if the junction temperature drops below 130oC. Table 1 USB Cable Compensation Application Table uP9616-DS-C3202, Feb. 2017 www.upi-semi.com 5 uP9616 Conceptual Functional Description High Voltage Dedicated Charging Port (HVDCP) Mode D- Output Voltage tia D+ HVDCP Class A l Portable Device After power-up pins D+ and D- of uP9616 are shorted with impedance RDCP_DAT and internal reference voltage VREF is set to VBUS voltage 5.2V. The device is in a BC1.2 compatible mode. If a portable device compatible with the Qualcomm Quick Charge specification is connected, a negotiation between HVDCP and PD is executed. Once the negotiation is successful the uP9616 opens D+ and D- short connection and D- is pulled down with a RDM_DWN. The uP9616 enters HVDCP mode. It monitors D+ and D- inputs. Based on the specified control patterns, the internal voltage reference value VREF is adjusted in order to increase or decrease output voltage to the required value. GND 5.2V 3.3V 0.6V 9V 0.6V 0.6V 12V 0.6V 3.3V Continuous Mode en 0.6V 3.3 Previous Voltage Table2. HVDCP detection voltage coding and status Note: GND is not forced by the portable device. The portable device shall go High-Z and the HVDCP pulls D- low through Rdm_dwn. This is to prevent misdetection when current flowing through GND causes the GND in the portable device to be at a higher voltage relative to HVDCP GND. Care should be taken in the portable device as this can result in a negative relative voltage on D- as seen by the portable device. fid The uP9616 is available in Class A version. Class A allows to change the output voltage up to VBUS = 12V. If the unplug event is detected the decoder circuitry turns-on an internal current sink, which discharges the output capacitors to a safe voltage level. If the uP9616 is set to a Continuous mode it responds to the PD requests in a Single request mode. It does not support Group request mode. 3.3 uP IC on HVDCP Continuous Mode The continuous mode of operation leverages the previously unused state in QC2.0. If the portable devices try and utilize this mode, it applies voltages on D+ and D- per Table 2. Assuming the HVDCP supports this mode of operation, it will glitch filter the request as it currently does, using TGLITCH_V_CHANGE(40ms). Before the portable device can begin to increment or decrement the voltage, it must wait TV_NEW_REQUEST_CONT before pulling D+ and Dhigh or low. Once this time has finished, the portable device now attempts to increment or decrement the voltage. To increment, the portable device sends a pulse of width TACTIVE by pulling D+ to VDP_UP and then must return D+ to VDP_SRC for TINACTIVE. 6 uP9616-DS-C3202, Feb. 2017 www.upi-semi.com uP9616 Conceptual Absolute Maximum Rating (Note 1) en tia l Supply Input Voltage, VIN ------------------------------------------------------------------------------------------------------------- -0.3V to +36V LX Voltage to GND ------------------------------------------------------------------------------------------------------- -0.3V to + (VIN + -0.3V) D+/D-/CC1/CC2 Pin Voltage -------------------------------------------------------------------------------------------------------------- -0.3V to +6.0V SENSE+/SENSE- Pin Voltage ---------------------------------------------------------------------------------------------------------- -0.3V to +14V Storage Temperature Range ------------------------------------------------------------------------------------------------------------- -65oC to +150oC Junction Temperature ------------------------------------------------------------------------------------------------------------------------------------ 150oC Lead Temperature (Soldering, 10 sec) ------------------------------------------------------------------------------------------------------------ 260oC ESD Rating (Note 2) D+/D-/Sense- Pin HBM (Human Body Mode) --------------------------------------------------------------------------------------------------------------------- 4kV MM (Machine Mode) ----------------------------------------------------------------------------------------------------------------------------- 400V Other Pins HBM (Human Body Mode) --------------------------------------------------------------------------------------------------------------------- 2kV MM (Machine Mode) ----------------------------------------------------------------------------------------------------------------------------- 200V fid Thermal Information on Package Thermal Resistance (Note 3) VDFN6x5 - 8L θJA -------------------------------------------------------------------------------------------------------------------- 45oC/W VDFN6x5 - 8L θJC ------------------------------------------------------------------------------------------------------------------------- 4oC/W VDFN5x6 - 10L θJA -------------------------------------------------------------------------------------------------------------------- 45oC/W VDFN5x6 - 10L θJC ------------------------------------------------------------------------------------------------------------------------ 4oC/W Power Dissipation, PD @ TA = 25oC VDFN6x5 - 8L --------------------------------------------------------------------------------------------------------------------------------------- 2.2W VDFN5x6 - 10L ------------------------------------------------------------------------------------------------------------------------------------- 2.2W Recommended Operation Conditions (Note 4) IC Operating Junction Temperature Range ------------------------------------------------------------------------------------------ -40oC to +125oC Operating Ambient Temperature Range ------------------------------------------------------------------------------------------ -40oC to +85oC Supply Input Voltage, VIN ------------------------------------------------------------------------------------------------------------------- +8V to 32V uP Note 1. Stresses listed as the above Absolute Maximum Ratings may cause permanent damage to the device. These are for stress ratings. Functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may remain possibility to affect device reliability. Note 2. Devices are ESD sensitive. Handling precaution recommended. Note 3. θJA is measured in the natural convection at TA = 25oC on a low effective thermal conductivity test board of JEDEC 51-3 thermal measurement standard. Note 4. The device is not guaranteed to function outside its operating conditions. uP9616-DS-C3202, Feb. 2017 www.upi-semi.com 7 uP9616 Conceptual Electrical Characteristics (VIN = 12V, TA =25oC, unless otherwise specified) Symbol Test Conditions Input Voltage Range 32 V -- 7.5 -- V -- 7.0 -- V 32.8 -- -- V 32.3 -- -- V -- 1 1.50 mA -- -- 150 uA -- 70 -- mΩ -- 45 -- mΩ -- 125 -- kHz 96 98 99 % -1.50 -- +1.50 VIN = 12V, VOUT = 9V, only for QC2.0/QC3.0 -1.50 -- +1.50 VIN = 12V, VOUT = 9.2V, only for FCP -1.50 -- +1.50 VIN = 24V, VOUT = 12V, only for QC2.0/QC3.0 -1.50 -- +1.50 VIN = 24V, VOUT = 12.1V, only for FCP -1.50 -- +1.50 -- 10 -- ms VOUT = 5.2V 127 130 133 mV VOUT = 5.2V, IO = 2.5A measured at VSENSE 110 150 190 mV VIN Falling VIN_OVP Rising en VIN_OVP Falling Supply Input Current Input Quiescent Current IQ1 No switching Input Standby Current IQ2 Type C detection RDS(ON) Low-Side Switch On Resistance RDS(ON) Oscillation Frequency fOSC Maximum Duty Cycle DMAX Output Voltage and Soft Start fid Pow er Sw itches Hi-Side Switch On Resistance Soft Start Time on VIN = 12V, VOUT = 5.2V, only for C2.0/QC3.0/FCP Output Voltage Accuracy ∆VOUT TSS IC Current Sense Amplifier Voltage Difference Between SENSE+ and SENSE- at CC Mode Operation ∆VSEN Units -- VIN Rising VIN_OVP Max 8 VIN VIN POR Threshold Input OVP Threshold Typ tia Supply Input Voltage Min l Parameter % Output Cable Resistance Compensation Fixed Line Compensation uP Protection VOUT CC (Constant Output Current) Limit IOUT RSENSE = 39mΩ , VOUT = 5.2V 3.256 3.33 3.410 A Output Voltage needs to collapse threshold VOUT Into CC (Constant Output Current) Limit. Only for QC2.0/3.0 and MTK 2.850 3.100 3.350 V Output Over Voltage Protection VOVP measured at VSENSE- -- 10 -- % 6.7 -- VUVP VOUT = 9.2V, only for FCP -- Output Under Voltage Protection VOUT = 12.1V, only for FCP -- 10 -- 8 V uP9616-DS-C3202, Feb. 2017 www.upi-semi.com uP9616 Conceptual Electrical Characteristics Parameter Symbol Test Conditions TSD Thermal Shutdown Hysteresis TSDHYS Max High Voltage Dedicated Charging Port (D+/D-) 150 -- o C -- 20 -- o C VDAT_REF 0.25 0.325 0.40 V Output Voltagte Selection Reference VSEL_REF 2.0V Reference for Selection HVDCP Voltage 1.80 2 2.20 V Current Limit for HVDCP at Any Output Voltage IHVDCP_MIN All HVDCP's must output this current at minimum 500 -- -- mA TGLITCHP_DM_LOW After D+/- A are open and Rdm_dwn is asserted, how long should HVDCP expect D- to stay low before being pulled high. 1 -- -- ms D- High Glitch Filter Time TGLITCHP_DM_HIGH After D+/- A are open and Rdm_dwn is asserted, how long after a portable device sees D- go low, before it makes first voltage request and pulls D-high. 40 -- -- ms D+ High Glitch Filter Time TGLITCHP_BC_Done After BC1.2 Detection is complete, HVDCP 1 -- 1.50 s Output Voltage Glitch Filter Time fid en Data Detect Voltage Units -- tia Thermal Shutdown Temprature Typ l Protection (Cont.) Min TGLITCHP_V_CHANGE Glitch filter after D+/- toggle before HVDCP attempts to change output voltage 20 40 60 ms Time for Vbus to discharge to 5.2V in HVDCP on unplug -- -- 500 ms Time for D+/D- to short on HVDCP -- 10 20 ms Equivalent capacitance on D+ and D- to GND -- -- 1 nF RDAT_LKG 300 -- 1500 kΩ RD-_DWN 12 15 18 kΩ -- 20 40 Ω Unplug Vbus Discharge D+/D- HVDCP Short Time D+D- Capacitance Data Line Leakage TD+_D-_SHORT CDCP_PWR IC D- Pull Down Resistance TV_UNPLUG on D- Low Glitch Filter Time BC 1.2 DCP Mode (Short Mode) D+ to D- Resistance During DCP Mode RDCP_DAT D+ Output Voltage VDP_1.2V+ VIN = 12V 1.12 1.20 1.28 V D- Output Voltage VDM_1.2V+ VIN = 12V 1.12 1.20 1.28 V RDP_1.2V ID+ = -5uA 80 102 130 kΩ VDM_1.2V+ ID- = -5uA 80 102 130 kΩ D+ Output Voltage VD+_2.7V VIN = 12V 2.57 2.70 2.84 V D- Output Voltage VD-_2.7V VIN = 12V 2.57 2.70 2.84 V D+ Output Impedance RD+_2.7V ID+ = -5uA -- 36 -- kΩ D- Output Impedance RD-_2.7V ID- = -5uA -- 36 -- kΩ uP D+ Output Impedance D- Output Impedance Divider Mode (2.7V/2.7V) uP9616-DS-C3202, Feb. 2017 www.upi-semi.com 9 uP9616 Conceptual en tia l Typical Operation Characteristics uP IC on fid This page is intentionally left blank and will be updated when data is available. 10 uP9616-DS-C3202, Feb. 2017 www.upi-semi.com uP9616 Conceptual Application Information Output Capacitor Selection Output inductor selection is usually based on the considerations of inductance, rated current value, size requirements and DC resistance (DCR). The ESR of the output capacitor determines the output ripple voltage and the initial voltage drop following a high slew rate load transient edge. The output ripple voltage can be calculated as: ∆IL = tia ∆VOUT = ∆IC × (ESR + 1 ) 8 × fOSC × C OU T Where f OSC = operating frequency, C OUT = output capacitance and ∆IC = ∆IL = ripple current in the inductor. The ceramic capacitor with low ESR value provides the low output ripple and low size profile. In the case of electrolytic capacitors, the ripple is dominated by RESR multiplied by the ripple current. Connect a 220uF electrolytic capacitor at output SENSE+ terminal for good performance and low output ripple and place output capacitor5s as close as possible to the device. In the case of ceramic output capacitors, RESR is very small and does not contribute to the output ripple. Connect a 0.1uF ceramic capacitor at output SENSE- terminal for good performance and place output capacitors as close as possible to the device. en The inductance is chosen based on the desired ripple current. Large value inductors result in lower ripple currents and small value inductors result in higher ripple currents. Higher VIN or VOUT also increases the ripple current as shown in the equation below. A reasonable starting point for setting ripple current is ∆IL = 900mA (30% of 3000mA). l Output Inductor Selection V 1 × VOUT (1 − OUT ) fOSC × L OUT VIN fid Maximum current ratings of the inductor are generally specified in two methods: permissible DC current and saturation current. Permissible DC current is the allowable DC current that causes 40oC temperature raise. The saturation current is the allowable current that causes 10% inductance loss. Make sure that the inductor will not saturate over the operation conditions including temperature range, input voltage range, and maximum output current. If possible, choose an inductor with rated current higher than 5A so that it will not saturate even under current limit condition. The PCB layout is an important step to maintain the high performance of the uP9616. High switching frequencies and relatively large peak currents make the PCB layout a very important part of all high frequency switching power supply design. Both the high current and the fast switching nodes demand full attention to the PCB layout to save the robustness of the uP9616 through the PCB layout. Improper layout might show the symptoms of poor load or lineregulation, radiate excessive noise at ground or input, output voltage shifts, stability issues, unsatisfying EMI behavior or worsened efficiency. Follow the PCB layout guidelines for optiomal performances of uP9616. on The size requirements refer to the area and height requirement for a particular design. For better efficiency, choose a low DC resistance inductor. DCR is usually inversely proportional to size. PCB Layout Consideration IC Different core materials and shapes will change the size, current and price/current relationship of an inductor. Toroid or shielded pot cores in ferrite or permalloy materials are small and don’t radiate much energy, but generally cost more than powdered iron core inductors with similar electrical characteristics. The choice of which style inductor to use often depends on the price vs. size requirements and any radiated field/EMI requirements. Input Capacitor Selection uP The input capacitor needs to be carefully selected to maintain sufficiently low ripple at the supply input of the converter. A low ESR capacitor is highly recommended. Since large current flows in and out of this capacitor during switching, its ESR also affects efficiency. The input capacitance needs to be higher than 22uF. The best choice is he ceramic type and low ESR electrolytic types may also be used provided that the RMS ripple current rating is higher than 50% of the output current. In the case of the electrolytic types, they can be further away if a small parallel 1uF ceramic capacitor is placed right close to the IC. A 100uF elecrolytic capacitor and 1uF ceramic capacitor are recommended and placed close to VIN and GND pins, with the shortest traces possible. uP9616-DS-C3202, Feb. 2017 www.upi-semi.com 11 uP9616 Conceptual Application Information Layout Guidelines For uP9616PDC8: en tia l 1. Arrange the power components to reduce the AC loop size consisting of CIN, VIN (Pin 1, 2) and LX (Pin 8) 2. The input decoupling ceramic capacitor 1uF must be placed closest to the VIN (Pin 1, 2) and Exposed Pad GND plane through vias or a short and wide path. 3. Return SENSE+ (PIN 6) to signal GND pin, and connect the signal GND to power GND at a single point for best noise immunity. Connect exposed pad to power ground opper area with copper and vias. 4. Apply copper plane to Exposed Pad GND for best heat dissipation and noise immunity. The exposed pad is the main path for heat convection and should be well-soldered to the PCB for best thermal performance. 5. Use a short trace connecting the bootstrap capacitor CBOOT to BOOT (Pin 7) and LX (Pin 8) to form a bootstrap circuit. 6. Use a short trace connecting R-C to LX (Pin 8) and Exposed Pad GND Plane to form a Snubber Circuit. 7. The LX (Pin 8) pad is the noise node switching from VIN (Pin 1, 2) to GND. LX node copper area should be GND Plane fid minimized to reduce EMI and should be isolated from the rest of circuit for good EMI and low noise operation. 8. The D+ (Pin 3) pad and D- (Pin 4) pad of the uP9616 are the USB detect data line input node, the D+ and D- Pin of the via or trace area should be isolated using 0.96mm space to prevent direct contact with VIN area components which may cause voltage of D+ and D- pins to exceed maximum rating of 6V. - + 1 VIN Plane 2 Via to D+ 8 Exposed Pad (GND) 4 USB Connector SENSEPlane 5V 7 D+ 6 D- on 3 Via to D- SENSE+ Plane + 5 Via to GND Plan GND GND Plane uP IC uP9616PDC8 12 uP9616-DS-C3202, Feb. 2017 www.upi-semi.com uP9616 Conceptual Application Information Layout Guidelines For uP9616PDYA: GND Plane fid en tia l 1. Arrange the power components to reduce the AC loop size consisting of CIN, VIN (Pin 5) and LX (Pin 6,7) 2. The input decoupling ceramic capacitor 1uF must be placed closest to the VIN (Pin 5) and Exposed Pad GND plane through vias or a short and wide path. 3. Return SENSE+ (PIN 9) to signal GND pin, and connect the signal GND to power GND at a single point for best noise immunity. Connect exposed pad to power ground copper area with copper and vias. 4. Apply copper plane to Exposed Pad GND for best heat dissipation and noise immunity. The exposed pad is the main path for heat convection and should be well-soldered to the PCB for best thermal performance. 5. Use a short trace connecting the bootstrap capacitor CBOOT to BOOT (Pin 8) and LX (Pin 6,7) to form a bootstrap circuit. 6. Use a short trace connecting R-C to LX (Pin 6,7) and Exposed Pad GND Plane to form a Snubber Circuit. 7. The LX (Pin 6,7) pad is the noise node switching from VIN (Pin 5) to GND. LX node copper area should be minimized to reduce EMI and should be isolated from the rest of circuit for good EMI and low noise operation. 8. The CC1 (Pin 4), CC2 (Pin 5), D+ (Pin 2) pad and D- (Pin 1) pad of the uP9616 are the USB detect data line input node, the CC1, CC2, D+ and D- Pin of the via or trace area should be isolated using 0.96mm space to prevent direct contact with VIN area components which may cause voltage of CC1, CC2, D+ and D- pins to exceed maximum rating of 6V. - + 6 5 Via to CC1 4 Via to CC2 3 Via to D+ Via to D- Exposed Pad (GND) USB Connector SENSEPlane 5V 7 D+ 8 D- on VIN Plane SENSE+ Plane + 2 9 1 10 Via to GND Plan GND GND Plane CC1 CC2 uP IC uP9616PDYA uP9616-DS-C3202, Feb. 2017 www.upi-semi.com 13 uP9616 Conceptual Package Information VDFN6x5 - 8L 3.85 - 4.15 0.50 - 0.80 tia 8 en 6.00 BSC 3.25 - 3.55 5 l 5.00 BSC 4 1.27 BSC 0.31 - 0.51 0.80 - 1.00 fid θ 1 0.20 REF 0.00 - 0.05 uP IC on Note 1.Package Outline Unit Description: BSC: Basic. Represents theoretical exact dimension or dimension target MIN: Minimum dimension specified. MAX: Maximum dimension specified. REF: Reference. Represents dimension for reference use only. This value is not a device specification. TYP. Typical. Provided as a general value. This value is not a device specification. 2.Dimensions in Millimeters. 3.Drawing not to scale. 4.These dimensions do not include mold flash or protrusions. Mold flash or protrusions shall not exceed 0.15mm. 14 uP9616-DS-C3202, Feb. 2017 www.upi-semi.com uP9616 Conceptual Package Information VDFN5x6 - 10L l 0.31 - 0.51 6.00 BSC 1.20BSC tia 1 en 5.00 BSC 2.60 - 2.80 0.50 - 0.90 5 6 10 4.40 - 4.60 fid 0.80 - 1.00 θ 0.20 REF 0.00 - 0.05 uP IC on Note 1.Package Outline Unit Description: BSC: Basic. Represents theoretical exact dimension or dimension target MIN: Minimum dimension specified. MAX: Maximum dimension specified. REF: Reference. Represents dimension for reference use only. This value is not a device specification. TYP. Typical. Provided as a general value. This value is not a device specification. 2.Dimensions in Millimeters. 3.Drawing not to scale. 4.These dimensions do not include mold flash or protrusions. Mold flash or protrusions shall not exceed 0.15mm. uP9616-DS-C3202, Feb. 2017 www.upi-semi.com 15 uP9616 Conceptual l Important Notice uP IC on fid en tia uPI and its subsidiaries reserve the right to make corrections, modifications, enhancements, improvements, and other changes to its products and services at any time and to discontinue any product or service without notice. Customers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. uPI products are sold subject to the taerms and conditions of sale supplied at the time of order acknowledgment. However, no responsibility is assumed by uPI or its subsidiaries for its use or application of any product or circuit; nor for any infringements of patents or other rights of third parties which may result from its use or application, including but not limited to any consequential or incidental damages. No uPI components are designed, intended or authorized for use in military, aerospace, automotive applications nor in systems for surgical implantation or life-sustaining. No license is granted by implication or otherwise under any patent or patent rights of uPI or its subsidiaries. COPYRIGHT (C) 2016, UPI SEMICONDUCTOR CORP. uPI Semiconductor Corp. Headquarter 9F.,No.5, Taiyuan 1st St. Zhubei City, Hsinchu Taiwan, R.O.C. TEL : 886.3.560.1666 FAX : 886.3.560.1888 16 uPI Semiconductor Corp. Sales Branch Office 12F-5, No. 408, Ruiguang Rd. Neihu District, Taipei Taiwan, R.O.C. TEL : 886.2.8751.2062 FAX : 886.2.8751.5064 uP9616-DS-C3202, Feb. 2017 www.upi-semi.com uP9616 uP IC on fid en tia l Conceptual uP9616-DS-C3202, Feb. 2017 www.upi-semi.com 17 uP9616 uP IC on fid en tia l Conceptual 18 uP9616-DS-C3202, Feb. 2017 www.upi-semi.com
uP9616PDC8 价格&库存
很抱歉,暂时无法提供与“uP9616PDC8”相匹配的价格&库存,您可以联系我们找货
