ELXM201VSN471MR25S
ELXM201VSN471MR25S
    NCC(贵弥功)
ELXM201VSN471MR25S 数据手册
LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS LXM Long life snap-ins, 105℃ LXM Series ・Endurance with ripple current : 7,000 hours at 105℃ ・Non solvent resistant type ・RoHS2 Compliant Longer life LXQ ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -25 to +105℃ 160 to 450Vdc ±20% (M) I≦3 CV Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) Rated voltage (Vdc) 160 to 400V 420 & 450V tanδ (Max.) 0.15 0.20 Rated voltage (Vdc) 160 to 400V 420 & 450V Z (-25℃)/Z (+20℃) 4 8 Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) (at 20℃, 120Hz) (at 20℃ after 5 minutes) (at 20℃, 120Hz) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 7,000 hours at 105℃. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦250% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±15% of the initial value D.F. (tanδ) ≦150% of the initial specified value Leakage current ≦The initial specified value Endurance Shelf Life ◆DIMENSIONS [mm] Code : VS (φ22 toφ35) : Standard Sleeve (PET : Brown) ●Terminal PC board pin-out (View from Solder side) Negative mark Code : LI (φ35) Sleeve (PET : Brown) Negative mark Vent φD+1max. φD+1max. 10 2-1.2×6 2-φ2 *4.0±0.5 L±2 PC board pin-out (View from Solder side) 4.2±0.5 ●Terminal Vent 5±0.5 L±2 4.5±1 14.2±1 *φD=35mm : 3.5±0.5mm The standard design has no plastic disc. ◆PART NUMBERING SYSTEM 1 2 3 4 E L XM 5 6 7 8 9 10 VS N 11 12 13 14 M 15 16 17 18 S Supplement code Size code Capacitance tolerance code Capacitance code (ex. 47µF:470, 2,200µF:222) Dummy terminal code Terminal code (VS, LI) Voltage code (ex. 160V:161, 315V:3B1, 450V:451) Series code Category Please refer to "Product code guide (snap-in type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Long life snap-ins, 105℃ LXMSeries ◆STANDARD RATINGS WV (Vdc) 160 180 200 Cap (µF) Rated ripple current Case size tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 330 390 470 470 560 560 680 680 680 820 820 820 1,000 1,000 1,200 1,200 1,200 1,500 1,500 1,800 1,800 2,200 270 330 390 390 470 470 560 560 560 680 680 680 820 820 1,000 1,000 1,000 1,200 1,200 1,500 1,500 1,800 2,200 220 270 330 330 390 390 470 470 470 560 560 560 680 680 820 820 1,000 1,000 1,200 1,200 1,500 1,800 22 ×25 22 ×30 22 ×30 25.4×25 22 ×35 25.4× 30 22 × 40 25.4× 35 30 × 25 22 × 50 25.4× 40 30 × 30 25.4× 45 30 × 35 25.4× 50 30 × 40 35 × 30 30 × 45 35 × 35 30 × 50 35 ×40 35 ×50 22 ×25 22 ×30 22 ×30 25.4×25 22 ×35 25.4×30 22×40 25.4×30 30 ×25 22 ×45 25.4×35 30×30 25.4×40 30 ×35 25.4×50 30×35 35×30 30×45 35×35 30×50 35×40 35×45 35×50 22 ×25 22 ×30 22 ×30 25.4×25 22×35 25.4×30 22 ×40 25.4×30 30 ×25 22 × 45 25.4× 35 30 × 30 25.4× 40 30 ×30 25.4×45 30 ×35 30 ×45 35 ×30 30 ×50 35× 40 35 × 45 35 × 50 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 1.11 1.26 1.39 1.38 1.55 1.55 1.75 1.78 1.74 1.97 2.01 1.96 2.27 2.26 2.54 2.56 2.52 2.96 2.89 3.32 3.30 3.87 1.00 1.16 1.26 1.26 1.42 1.42 1.59 1.55 1.58 1.79 1.78 1.79 2.01 2.04 2.32 2.26 2.30 2.65 2.58 3.03 3.01 3.41 3.87 0.90 1.05 1.16 1.16 1.29 1.29 1.46 1.42 1.45 1.63 1.62 1.62 1.83 1.79 2.06 2.04 2.42 2.30 2.71 2.70 3.11 3.50 Part No. ELXM161VSN331MP25S ELXM161VSN391MP30S ELXM161VSN471MP30S ELXM161VSN471MQ25S ELXM161VSN561MP35S ELXM161VSN561MQ30S ELXM161VSN681MP40S ELXM161VSN681MQ35S ELXM161VSN681MR25S ELXM161VSN821MP50S ELXM161VSN821MQ40S ELXM161VSN821MR30S ELXM161VSN102MQ45S ELXM161VSN102MR35S ELXM161VSN122MQ50S ELXM161VSN122MR40S ELXM161VSN122MA30S ELXM161VSN152MR45S ELXM161VSN152MA35S ELXM161VSN182MR50S ELXM161VSN182MA40S ELXM161VSN222MA50S ELXM181VSN271MP25S ELXM181VSN331MP30S ELXM181VSN391MP30S ELXM181VSN391MQ25S ELXM181VSN471MP35S ELXM181VSN471MQ30S ELXM181VSN561MP40S ELXM181VSN561MQ30S ELXM181VSN561MR25S ELXM181VSN681MP45S ELXM181VSN681MQ35S ELXM181VSN681MR30S ELXM181VSN821MQ40S ELXM181VSN821MR35S ELXM181VSN102MQ50S ELXM181VSN102MR35S ELXM181VSN102MA30S ELXM181VSN122MR45S ELXM181VSN122MA35S ELXM181VSN152MR50S ELXM181VSN152MA40S ELXM181VSN182MA45S ELXM181VSN222MA50S ELXM201VSN221MP25S ELXM201VSN271MP30S ELXM201VSN331MP30S ELXM201VSN331MQ25S ELXM201VSN391MP35S ELXM201VSN391MQ30S ELXM201VSN471MP40S ELXM201VSN471MQ30S ELXM201VSN471MR25S ELXM201VSN561MP45S ELXM201VSN561MQ35S ELXM201VSN561MR30S ELXM201VSN681MQ40S ELXM201VSN681MR30S ELXM201VSN821MQ45S ELXM201VSN821MR35S ELXM201VSN102MR45S ELXM201VSN102MA30S ELXM201VSN122MR50S ELXM201VSN122MA40S ELXM201VSN152MA45S ELXM201VSN182MA50S WV (Vdc) 220 250 315 Cap (µF) Rated ripple current Case size tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 220 270 330 330 390 390 470 470 470 560 560 560 680 680 820 820 820 1,000 1,000 1,200 1,500 180 220 270 270 330 330 390 390 390 470 470 470 560 560 680 680 680 820 820 1,000 1,200 100 120 150 150 180 180 220 220 220 270 270 270 330 330 330 390 390 390 470 470 560 560 680 820 22 × 25 22 × 30 22 × 35 25.4 × 25 22 × 40 25.4 × 30 22 × 45 25.4 × 35 30 × 25 22 × 50 25.4× 40 30 × 30 25.4× 45 30 × 35 25.4× 50 30 × 40 35 × 30 30 × 50 35 × 40 35 × 45 35 × 50 22 × 25 22 × 30 22 × 35 25.4 × 25 22 × 40 25.4 × 30 22 × 45 25.4 × 35 30 × 25 22 × 50 25.4 × 40 30 × 30 25.4 × 45 30 × 35 25.4 × 50 30 × 40 35 × 30 30 × 45 35 × 35 35 × 40 35 × 50 22 × 25 22 × 30 22 × 30 25.4 × 25 22 × 35 25.4 × 30 22 × 40 25.4 × 30 30 × 25 22 × 45 25.4 × 35 30 × 30 25.4 × 40 30 × 35 35 × 30 25.4 × 50 30 × 35 35 × 30 30 × 45 35 × 35 30 × 50 35 × 40 35 × 45 35 × 50 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.90 1.05 1.19 1.16 1.33 1.29 1.49 1.48 1.45 1.63 1.71 1.62 1.87 1.86 2.10 2.12 2.08 2.48 2.46 2.78 3.20 0.82 0.95 1.08 1.05 1.22 1.19 1.36 1.35 1.32 1.49 1.52 1.49 1.70 1.69 1.91 1.93 1.90 2.19 2.13 2.46 2.86 0.67 0.77 0.86 0.85 0.96 0.96 1.09 1.06 1.08 1.24 1.23 1.23 1.40 1.42 1.45 1.59 1.54 1.57 1.81 1.77 2.03 2.02 2.29 2.59 Part No. ELXM221VSN221MP25S ELXM221VSN271MP30S ELXM221VSN331MP35S ELXM221VSN331MQ25S ELXM221VSN391MP40S ELXM221VSN391MQ30S ELXM221VSN471MP45S ELXM221VSN471MQ35S ELXM221VSN471MR25S ELXM221VSN561MP50S ELXM221VSN561MQ40S ELXM221VSN561MR30S ELXM221VSN681MQ45S ELXM221VSN681MR35S ELXM221VSN821MQ50S ELXM221VSN821MR40S ELXM221VSN821MA30S ELXM221VSN102MR50S ELXM221VSN102MA40S ELXM221VSN122MA45S ELXM221VSN152MA50S ELXM251VSN181MP25S ELXM251VSN221MP30S ELXM251VSN271MP35S ELXM251VSN271MQ25S ELXM251VSN331MP40S ELXM251VSN331MQ30S ELXM251VSN391MP45S ELXM251VSN391MQ35S ELXM251VSN391MR25S ELXM251VSN471MP50S ELXM251VSN471MQ40S ELXM251VSN471MR30S ELXM251VSN561MQ45S ELXM251VSN561MR35S ELXM251VSN681MQ50S ELXM251VSN681MR40S ELXM251VSN681MA30S ELXM251VSN821MR45S ELXM251VSN821MA35S ELXM251VSN102MA40S ELXM251VSN122MA50S ELXM3B1VSN101MP25S ELXM3B1VSN121MP30S ELXM3B1VSN151MP30S ELXM3B1VSN151MQ25S ELXM3B1VSN181MP35S ELXM3B1VSN181MQ30S ELXM3B1VSN221MP40S ELXM3B1VSN221MQ30S ELXM3B1VSN221MR25S ELXM3B1VSN271MP45S ELXM3B1VSN271MQ35S ELXM3B1VSN271MR30S ELXM3B1VSN331MQ40S ELXM3B1VSN331MR35S ELXM3B1VSN331MA30S ELXM3B1VSN391MQ50S ELXM3B1VSN391MR35S ELXM3B1VSN391MA30S ELXM3B1VSN471MR45S ELXM3B1VSN471MA35S ELXM3B1VSN561MR50S ELXM3B1VSN561MA40S ELXM3B1VSN681MA45S ELXM3B1VSN821MA50S Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Long life snap-ins, 105℃ LXMSeries ◆STANDARD RATINGS WV (Vdc) 350 400 Cap (µF) Rated ripple current Case size tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 100 120 120 150 150 180 180 180 220 220 220 270 270 330 330 330 390 390 470 470 560 680 68 82 100 100 120 120 150 150 150 180 180 180 220 220 270 270 270 330 330 390 390 470 560 22 ×25 22 ×30 25.4×25 22 ×35 25.4×30 22 ×40 25.4×30 30 ×25 22 ×45 25.4×35 30 ×30 25.4×40 30 ×35 25.4×45 30 ×35 35 ×30 30 ×40 35 ×35 30 ×50 35 ×40 35 ×40 35 ×50 22 ×25 22 ×30 22 ×30 25.4×25 22×35 25.4×30 22×40 25.4 ×30 30 ×25 22 ×45 25.4 ×35 30 ×30 25.4 ×40 30 ×35 25.4 ×50 30 ×40 35 ×30 30 ×45 35 ×35 30 ×50 35 ×40 35 ×45 35 ×50 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.67 0.77 0.76 0.88 0.88 0.99 0.96 0.98 1.12 1.11 1.11 1.26 1.28 1.40 1.42 1.45 1.60 1.61 1.86 1.85 2.02 2.36 0.55 0.63 0.70 0.70 0.79 0.79 0.90 0.88 0.90 0.99 1.01 1.01 1.14 1.16 1.32 1.33 1.31 1.52 1.48 1.69 1.68 1.91 2.14 Part No. ELXM351VSN101MP25S ELXM351VSN121MP30S ELXM351VSN121MQ25S ELXM351VSN151MP35S ELXM351VSN151MQ30S ELXM351VSN181MP40S ELXM351VSN181MQ30S ELXM351VSN181MR25S ELXM351VSN221MP45S ELXM351VSN221MQ35S ELXM351VSN221MR30S ELXM351VSN271MQ40S ELXM351VSN271MR35S ELXM351VSN331MQ45S ELXM351VSN331MR35S ELXM351VSN331MA30S ELXM351VSN391MR40S ELXM351VSN391MA35S ELXM351VSN471MR50S ELXM351VSN471MA40S ELXM351VSN561MA40S ELXM351VSN681MA50S ELXM401VSN680MP25S ELXM401VSN820MP30S ELXM401VSN101MP30S ELXM401VSN101MQ25S ELXM401VSN121MP35S ELXM401VSN121MQ30S ELXM401VSN151MP40S ELXM401VSN151MQ30S ELXM401VSN151MR25S ELXM401VSN181MP45S ELXM401VSN181MQ35S ELXM401VSN181MR30S ELXM401VSN221MQ40S ELXM401VSN221MR35S ELXM401VSN271MQ50S ELXM401VSN271MR40S ELXM401VSN271MA30S ELXM401VSN331MR45S ELXM401VSN331MA35S ELXM401VSN391MR50S ELXM401VSN391MA40S ELXM401VSN471MA45S ELXM401VSN561MA50S WV (Vdc) 420 450 Cap (µF) Rated ripple current Case size tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 56 68 82 82 100 100 120 120 120 150 150 150 180 180 220 220 220 270 270 330 330 390 470 47 56 68 68 82 82 100 100 100 120 120 120 150 150 180 180 180 220 220 270 270 330 390 22 × 25 22 × 30 22 × 30 25.4 × 25 22 × 35 25.4 × 30 22 × 40 25.4 × 30 30 × 25 22 × 45 25.4 × 35 30 × 30 25.4 × 40 30 × 35 25.4 × 50 30 × 35 35 × 30 30 × 45 35 × 35 30 × 50 35 × 40 35 × 45 35 × 50 22 × 25 22 × 30 22 × 30 25.4 × 25 22 × 35 25.4× 30 22 × 40 25.4 × 30 30 × 25 22 × 45 25.4 × 35 30 × 30 25.4 × 40 30 × 35 25.4 × 45 30 × 35 35 × 30 30 × 40 35 × 35 30 × 50 35 × 40 35 × 45 35 × 50 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.50 0.58 0.63 0.63 0.72 0.72 0.81 0.79 0.80 0.92 0.92 0.92 1.03 1.05 1.19 1.16 1.18 1.38 1.34 1.56 1.55 1.74 1.96 0.46 0.52 0.58 0.58 0.65 0.65 0.74 0.72 0.73 0.83 0.82 0.82 0.94 0.96 1.06 1.05 1.07 1.20 1.21 1.41 1.40 1.60 1.79 Part No. ELXM421VSN560MP25S ELXM421VSN680MP30S ELXM421VSN820MP30S ELXM421VSN820MQ25S ELXM421VSN101MP35S ELXM421VSN101MQ30S ELXM421VSN121MP40S ELXM421VSN121MQ30S ELXM421VSN121MR25S ELXM421VSN151MP45S ELXM421VSN151MQ35S ELXM421VSN151MR30S ELXM421VSN181MQ40S ELXM421VSN181MR35S ELXM421VSN221MQ50S ELXM421VSN221MR35S ELXM421VSN221MA30S ELXM421VSN271MR45S ELXM421VSN271MA35S ELXM421VSN331MR50S ELXM421VSN331MA40S ELXM421VSN391MA45S ELXM421VSN471MA50S ELXM451VSN470MP25S ELXM451VSN560MP30S ELXM451VSN680MP30S ELXM451VSN680MQ25S ELXM451VSN820MP35S ELXM451VSN820MQ30S ELXM451VSN101MP40S ELXM451VSN101MQ30S ELXM451VSN101MR25S ELXM451VSN121MP45S ELXM451VSN121MQ35S ELXM451VSN121MR30S ELXM451VSN151MQ40S ELXM451VSN151MR35S ELXM451VSN181MQ45S ELXM451VSN181MR35S ELXM451VSN181MA30S ELXM451VSN221MR40S ELXM451VSN221MA35S ELXM451VSN271MR50S ELXM451VSN271MA40S ELXM451VSN331MA45S ELXM451VSN391MA50S ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Frequency(Hz) 160 to 250Vdc 315 to 450Vdc 50 0.81 0.77 120 1.00 1.00 300 1.17 1.16 1k 1.32 1.30 10k 1.45 1.41 50k 1.50 1.43 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U
ELXM201VSN471MR25S 价格&库存
很抱歉,暂时无法提供与“ELXM201VSN471MR25S”相匹配的价格&库存,您可以联系我们找货
