MBR2060CT
MBR2060CT
    MDD(辰达半导体)
    ITO-220AB-3
    电压:60V 电流:20A
MBR2060CT 数据手册
MBR2045CT THRU MBR20200CT Reverse Voltage - 45 to 200 Volts Forward Current - 20.0 Ampere SCHOTTKY BARRIER RECTIFIER Features TO-220AB  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  Construction utilizes void-free molded plastic technique  Low reverse leakage  High forward surge current capability  High temperature soldering guaranteed: 250°C,0.25”(6.35mm) from case for 10 seconds PIN2 PIN1 Mechanical Data PIN2 Case : JEDEC TO-220AB Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.080 ounce, 2.24 grams PIN3 PIN1 PIN2 PIN3 Maximum Ratings And Electrical Characteristics Ratings at 25°C ambient temperature unlss otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter SYMBOLS Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current (see fig.1) Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 10.0A Maximum DC reverse current TA=25℃ at rated DC blocking voltage TA=100℃ Typical thermal resistance (NOTE 2) Operating junction temperature range storage temperature range VRRM V RMS V DC MDD MBR 2045CT MDD MBR 2060CT MDD MBR 20100CT MDD MBR 20150CT MDD MBR 20200CT 150 135 150 200 140 200 45 32 60 100 42 70 45 60 100 I(AV) 20.0 IFSM 150 VF IR R θ JC 0.60 0.85 0.75 1.0 50.0 15.0 2.0 UNITS V V V A A 0.95 0.2 50.0 1.5 V mA ℃/W TJ -55 to +150 ℃ T STG -55 to +150 ℃ Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.Thermal resistance from junction to case. http://www.microdiode.com Rev:2024A2 Page :1 MBR2045CT THRU MBR20200CT Forward Current - 20.0 Ampere Reverse Voltage - 45 to 200 Volts Ratings And Characteristic Curves Fig.2 Typical Reverse Characteristics 20 15 ~2 00 10 V 5 0.0 20 40 60 80 100 120 140 160 180 Instaneous Reverse Current ( mA) 25 45 Average Forward Current (A) Fig.1 Typical Forward Current Derating Curve 100 45~60V 100~200V 10 T J =100°C 1.0 0.1 T J =25°C 0.01 0.001 0 Case Temperature (°C) 10 1 45V 60V 100V 150V 200V 0.1 0.2 0.4 0.6 0.8 60 80 100 1.0 Instaneous Forward Voltage (V) Fig.4 Maximum Non-Repetitive Peak Forward Surage Current Peak Forward Surage Current (A) Instaneous Forward Current (A) T J =25°C 0 40 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic(per leg) 20 20 1.2 160 140 120 100 80 60 40 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles at 60Hz The curve above is for reference only. http://www.microdiode.com Rev:2024A2 Page :2 MBR2045CT THRU MBR20200CT Reverse Voltage - 45 to 200 Volts Forward Current - 20.0 Ampere Outlitne TO-220AB Package Outline Dimensions A C E B M N D J K T L b F L1 b1 H G G TO-220AB mechanical data UNIT A B b b1 C D E F G max 10.45 2.94 1.77 0.94 4.76 16.0 1.40 2.80 H L L1 M N 6.6 3.8 0.38 3.89 13.18 2.54 TYPICAL TYPICAL TYPICAL 9.85 2.54 1.14 0.62 4.42 14.6 1.14 2.20 0.35 2.8 13.08 max 411 116 70 40 187 630 55 mil typ 391 107 50 31 178 594 50 105 min 388 100 45 24 174 575 45 http://www.microdiode.com 110 87 T K 0.64 4.2 14.79 mm typ 9.94 2.74 1.27 0.81 4.53 15.09 1.27 2.69 min J 100 TYPICAL 25 165 15 153 519 14 110 4.65 7.70 3.22 ref. ref. ref. 582 259 150 TYPICAL TYPICAL 1.83 303 126 ref. ref. ref. 515 Rev:2024A2 Page :3
MBR2060CT 价格&库存
很抱歉,暂时无法提供与“MBR2060CT”相匹配的价格&库存,您可以联系我们找货
