RXJ101M1CBK-0611
RXJ101M1CBK-0611
    LELON(立隆电子)
    插件,D6.3xL11mm
    直插铝电解电容 AEC_D6.3X11MM_TM
RXJ101M1CBK-0611 数据手册
Aluminum Electrolytic Capacitors RXJ Features ‧ 105℃, 2,000 ~ 5,000 hours assured ‧ Low ESR, suitable for switching power supplies ‧ Smaller size with large permissible ripple current ‧ RoHS Compliance Sleeve & Marking Color: Brown & White SPECIFICATIONS Items Performance -55℃ ~ +105℃ Category Temperature Range ±20% I = 0.01CV or 3 (μ A) whichever is greater (after 2 minutes) Where, C = rated capacitance in μF V = rated DC working voltage in V Capacitance Tolerance Leakage Current (at 20℃) Dissipation Factor (Tanδat 120Hz, 20℃) (at 120Hz, 20℃) Rated Voltage 6.3 10 16 25 35 50 63 100 Tanδ(max) 0.22 0.19 0.16 0.14 0.12 0.10 0.09 0.08 When the capacitance exceeds 1,000μ F, 0.02 shall be added every 1,000μ F increase. Impedance ratio shall not exceed the values given in the table below. Low Temperature Characteristics (at 120Hz) Rated Voltage Impedance Z(-55℃)/Z(+20℃) Ratio 6.3 10 16 25 35 50 63 100 4 4 3 3 3 3 3 3 Capacitance Change 2,000 Hrs for φD ≦ 8 mm; 5,000 Hrs for φD ≧ 10 mm Within ±20% of initial value Dissipation Factor Less than 200% of specified value Test Time Endurance Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage applied with rated ripple current for 2,000/5,000 hours at 105℃. Test Time Shelf Life Test 1,000 Hrs Capacitance Change Within ±20% of initial value Dissipation Factor Less than 200% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Freq.(Hz) Cap.(μ F) 60 (50) 120 500 1k 10k 100k Ripple Current & Under 33 0.40 0.55 0.65 0.80 0.90 1.00 Frequency Multipliers 39 ~ 330 0.60 0.70 0.80 0.90 0.95 1.00 390 ~ 1,000 0.65 0.80 0.85 0.98 1.00 1.00 1,200 up above 0.80 0.90 0.95 0.98 1.00 1.00 DIAGRAM OF DIMENSIONS Sleeve 2011 Version φD+βmax 15 min 4 min LEAD SPACING AND DIAMETER P±0.5 L+α max φd Vent≧6.3φ φD P φd α β 5 2.0 6.3 2.5 0.5 8 3.5 10 5.0 0.6 1.0 12.5 5.0 1.5 0.5 Unit: mm 16 18 7.5 7.5 0.8 Aluminum Electrolytic Capacitors Dimension: φD × L(mm) Ripple Current: mA/rms at 100k Hz, 105°C DIMENSION & PERMISSIBLE RIPPLE CURRENT V. DC Item 6.3V (0J) φD×L µF Impedance (Ω, Max/100K Hz) 20℃ -10℃ RXJ 10V (1A) Ripple Current (mA/rms, 105℃) 120 Hz 100k Hz φD×L Impedance (Ω, Max/100K Hz) 20℃ -10℃ 16V (1C) Ripple Current (mA/rms, 105℃) 120 Hz 100k Hz φD×L Impedance (Ω, Max/100K Hz) 20℃ -10℃ Ripple Current (mA/rms, 105℃) 120 Hz 100k Hz 33 5×11 1.30 3.90 108 154 39 5×11 1.30 3.90 108 154 260 47 5×11 2.10 5.50 78 111 6.3×11 0.60 1.80 182 56 5×11 1.90 4.80 85 121 6.3×11 0.60 1.80 182 260 68 5×11 1.30 3.90 108 154 6.3×11 0.60 1.80 182 260 100 5×11 1.30 3.90 108 154 6.3×11 0.60 1.80 182 260 6.3×11 0.60 1.80 182 260 220 6.3×11 0.60 1.80 182 260 8×11.5 0.33 0.99 280 400 8×11.5 0.33 0.99 320 400 330 8×11.5 0.33 0.88 280 400 8×11.5 0.33 0.99 280 400 10×12.5 0.25 0.75 360 510 390 8×11.5 0.33 0.88 320 400 10×12.5 0.27 0.75 410 510 10×16 0.19 0.57 510 635 470 10×12.5 0.25 0.75 410 510 10×12.5 0.25 0.75 410 510 10×16 0.19 0.57 510 635 560 10×12.5 0.25 0.75 410 510 10×16 0.19 0.57 510 635 10×20 0.14 0.42 775 860 680 10×16 0.19 0.57 510 635 10×16 0.19 0.57 510 635 10×20 0.14 0.42 775 860 1,000 10×20 0.14 0.42 690 860 10×20 0.14 0.37 690 860 12.5×20 0.085 0.26 1,000 1,250 1,200 10×20 0.14 0.42 775 860 10×25 0.12 0.30 930 1,030 12.5×20 0.085 0.26 1,125 1,250 2,200 12.5×20 0.085 0.26 1,125 1,250 12.5×25 0.070 0.21 1,200 1,355 12.5×25 0.070 0.21 1,200 1,355 3,300 12.5×25 0.070 0.21 1,200 1,355 12.5×25 0.070 0.21 1,200 1,355 16×31.5 0.048 0.14 1,830 2,030 4,700 16×25 0.060 0.18 1,595 1,770 16×31.5 0.048 0.14 1,830 2,030 16×35.5 0.044 0.13 2,065 2,295 V. DC Item 25V (1E) φD×L µF Impedance (Ω, Max/100K Hz) 20℃ -10℃ 35V (1V) Ripple Current (mA/rms, 105℃) 120Hz 100KHz φD×L Impedance (Ω, Max/100K Hz) 20℃ -10℃ 50V (1H) Ripple Current (mA/rms, 105℃) 120Hz 100KHz φD×L Impedance (Ω, Max/100K Hz) 20℃ -10℃ Ripple Current (mA/rms, 105℃) 120Hz 100KHz 1 5×11 5.0 15.0 43 78 2.2 5×11 4.0 12.0 48 88 3.3 5×11 3.50 11.0 52 94 4.7 5×11 3.00 9.00 55 100 6.8 5×11 3.00 9.00 55 100 10 5×11 2.00 6.00 68 124 0.60 1.80 143 260 22 5×11 1.30 3.90 108 154 6.3×11 33 5×11 1.30 3.90 108 154 6.3×11 0.60 1.80 182 260 6.3×11 0.60 1.80 143 260 39 6.3×11 0.60 1.80 182 260 6.3×11 0.60 1.80 182 260 6.3×11 0.60 1.80 182 260 47 6.3×11 0.60 1.80 182 260 6.3×11 0.60 1.80 182 260 8×11.5 0.33 0.99 320 400 56 6.3×11 0.60 1.80 182 260 6.3×11 0.60 1.80 182 260 8×11.5 0.33 0.99 320 400 68 6.3×11 0.60 1.80 182 260 6.3×11 0.60 1.80 182 260 8×11.5 0.33 0.99 320 400 100 8×11.5 0.33 0.99 320 400 8×11.5 0.33 0.99 320 400 10×16 0.19 0.57 445 635 220 10×12.5 0.25 0.75 360 510 10×16 0.19 0.57 445 635 10×25 0.12 0.30 825 1,030 330 10×16 0.19 0.57 445 635 10×20 0.12 0.42 600 860 12.5×20 0.085 0.26 875 1,250 390 10×20 0.14 0.42 775 965 10×25 0.12 0.30 930 1,030 12.5×25 0.070 0.21 1,085 1,355 470 10×20 0.14 0.42 775 965 12.5×20 0.085 0.26 1,000 1,250 12.5×25 0.070 0.21 1,085 1,355 560 10×25 0.12 0.30 930 1,030 12.5×20 0.085 0.26 1,000 1,250 12.5×25 0.070 0.21 1,085 1,355 680 12.5×20 0.085 0.26 1,000 1,250 12.5×25 0.070 0.21 1,085 1,355 16×25 0.060 0.18 1,415 1,770 1,000 12.5×25 0.070 0.23 1,080 1,355 12.5×25 0.070 0.21 1,085 1,355 16×25 0.060 0.18 1,595 1,770 1,200 12.5×25 0.070 0.21 1,200 1,355 12.5×25 0.070 0.21 1,200 1,355 16×31.5 0.048 0.14 1,830 2,030 2,200 16×25 0.060 0.18 1,595 1,770 16×35.5 0.044 0.13 2,065 2,295 18×40 0.037 0.10 2,465 2,740 3,300 16×35.5 0.044 0.13 2,065 2,295 18×40 0.037 0.10 2,465 2,740 4,700 18×40 0.037 0.10 2,465 2,740 2011 Verison Aluminum Electrolytic Capacitors Dimension: φD×L(mm) Ripple Current: mA/rms at 100k Hz, 105℃ DIMENSION & PERMISSIBLE RIPPLE CURRENT V. DC Item 63V (1J) φD×L µF Impedance (Ω, Max/100K Hz) 20℃ -10℃ 100V (2A) Ripple Current (mA/rms, 105℃) 120 Hz 100k Hz φD×L Impedance (Ω, Max/100K Hz) 20℃ -10℃ Ripple Current (mA/rms, 105℃) 120 Hz 100k Hz 1 5×11 7.0 25.0 36 66 2.2 5×11 6.00 21.0 40 72 3.3 5×11 5.00 18.0 43 78 4.7 6.3×11 1.20 4.20 100 180 6.3×11 1.20 4.20 100 180 8×11.5 0.56 2.00 168 305 180 8×11.5 0.56 2.00 168 308 305 10×12.5 0.50 1.80 210 380 305 10×16 0.32 1.10 350 500 170 305 10×20 0.27 0.95 435 620 265 380 10×20 0.27 0.95 435 620 1.80 265 380 10×25 0.21 0.63 530 760 0.27 0.95 435 620 12.5×20 0.16 0.56 625 890 12.5×20 0.094 0.24 570 820 16×25 0.090 0.32 1,010 1,440 12.5×25 0.073 0.21 770 1,100 16×31.5 0.060 0.17 1,255 1,790 390 12.5×25 0.073 0.21 770 1,100 16×35.5 0.056 0.14 1,650 2,065 470 16×25 0.060 0.18 1,420 1,770 560 16×31.5 0.048 0.14 1,625 2,030 680 16×31.5 0.048 0.14 1,625 2,030 1,000 18×35.5 0.041 0.11 1,790 2,240 6.8 10 6.3×11 22 6.3×11 1.20 4.20 100 33 8×11.5 0.56 2.00 170 39 8×11.5 0.56 2.00 170 47 8×11.5 0.56 2.00 56 10×12.5 0.50 1.80 68 10×12.5 0.50 100 10×20 220 330 2011 Version 1.20 4.20 100 180 RXJ
RXJ101M1CBK-0611 价格&库存
很抱歉,暂时无法提供与“RXJ101M1CBK-0611”相匹配的价格&库存,您可以联系我们找货
