RS1M
RS1M
    STARSEA(星海)
    SMA(DO-214AC)
    RS1M为FR107的贴片规格
RS1M 数据手册
RS1A THRU RS1M SURFACE MOUNT FAST RECOVERY RECTIFIER Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Ampere DO-214AC FEATURES The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 For surface mounted applications Fast switching for high efficiency Low reverse leakage Built-in strain relief,ideal for automated placement High forward surge current capability High temperature soldering guaranteed: 260 C/10 seconds at terminals 0.110(2.80) 0.100(2.54) 0.067 (1.70) 0.051 (1.30) 0.177(4.50) 0.157(3.99) 0.012(0.305) 0.006(0.152) 0.096(2.42) 0.078(1.98) MECHANICAL DATA 0.060(1.52) 0.030(0.76) 0.008(0.203)MAX. 0.222(5.66) 0.194(4.93) Case: JEDEC DO-214AC molded plastic body Terminals: Solder plated, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight:0.002 ounce, 0.07 grams Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. SYMBOLS Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TL=90 C Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 1.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=100 C Maximum reverse recovery time (NOTE 1) Typical junction capacitance (NOTE 2) Typical thermal resistance (NOTE 3) Operating junction and storage temperature range VRRM VRMS VDC RS1A RS1B RS1D RS1G RS1J 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 RS1K RS1M UNITS 800 560 800 VOLTS VOLTS VOLTS 1000 700 1000 I(AV) 1.0 Amp IFSM 30.0 Amps VF 1.3 Volts IR 5.0 50.0 µA trr CJ RθJA TJ,TSTG 150 250 15.0 50.0 -65 to +150 500 ns pF C/W C Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A 2.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas 357 STAR SEA AVERAGE FORWARD RECTIFIED CURRENT, AMPERES RATINGS AND CHARACTERISTIC CURVES RS1A THRU RS1M PEAK FORWARD SURGE CURRENT, AMPERES FIG. 1- FORWARD CURRENT DERATING CURVE 1.0 0.8 0.6 Single Phase Half Wave 60Hz Resistive or inductive Load 0.4 0.2 0 0 25 50 75 100 125 150 FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 30 25 20 15 10 175 5.0 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 1 10 AMBIENT TEMPERATURE, C FIG. 4-TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 20 10 1 TJ=25 C PULSE WIDTH=300 µs 1%DUTY CYCLE 0.1 0.01 0.6 0.8 1.0 1.2 1.4 1.5 1,000 100 10 TJ=100 C 1 0.1 TJ=25 C 0.01 INSTANTANEOUS FORWARD VOLTAGE, VOLTS TRANSIENT THERMAL IMPEDANCE, C/W FIG. 5-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE, pF 0 20 40 60 80 100 PERCENT OF PEAK REVERSE VOLTAGE,% 200 TJ=25 C 100 100 NUMBER OF CYCLES AT 60 Hz 10 FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE 100 10 1 0.1 0.01 0.1 1 10 100 1 0.1 1.0 10 100 REVERSE VOLTAGE,VOLTS t,PULSE DURATION,sec. 358 STAR SEA
RS1M
物料型号:RS1A, RS1B, RS1D, RS1G, RS1J, RS1K, RS1M
器件简介:表面安装型快速恢复整流器,具有快速开关以提高效率,低反向漏电,内置应变缓解,适合自动化放置,高正向浪涌电流能力,保证高温焊接260°C/10秒。
引脚分配:JEDEC DO-214AC封装,焊点为MIL-STD-750标准可焊。
参数特性: - 最大重复峰值反向电压:50V至1000V - 最大有效值电压:35V至700V - 最大直流阻断电压:50V至1000V - 最大平均正向整流电流:1.0A(特定型号) - 峰值正向浪涌电流:30.0A(特定型号) - 最大瞬时正向电压:1.3V(特定型号) - 最大直流反向电流:5.0uA至50.0uA(特定型号) - 最大反向恢复时间:150ns至500ns(特定型号) - 典型结电容:15.0pF(特定型号) - 典型热阻:50.0°C/W(特定型号)
功能详解:文档提供了正向电流降额曲线、最大非重复峰值正向浪涌电流、瞬时正向特性、反向特性、瞬态热阻和结电容的典型特性曲线。
应用信息:适用于表面安装应用,具有高效率和高正向浪涌电流能力。
很抱歉,暂时无法提供与“RS1M”相匹配的价格&库存,您可以联系我们找货
RS1M
    • 50+0.10034
    • 500+0.07787
    • 2000+0.06243
    库存:3202
