EMZR500ADA101MF80G
EMZR500ADA101MF80G
    NCC(贵弥功)
EMZR500ADA101MF80G 数据手册
Engineering Bulletin AlchipTM Tentative No.840A/Mar.2014 Vertical Surface Mount Type Aluminum Electrolytic Capacitors - MZRSeries ● Downsizing and Lower ESR, 2,000 hours at 105℃ ● Rated voltage range : 6.3 to 50V, Nominal capacitance range : 150 to 2,200μF ● Solvent resistant type ● Vibration resistant structure ● RoHS Compliant ◆ SPECIFICATIONS Items Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life Surge Voltage Test Characteristics -55 to +105℃ 6.3 to 50Vdc ±20%(M) (at 20℃ , 120Hz) I=0.01CV or 3μA, which is greater. Where, I : Max. leakage current (μA), C : Nominal capacitance (μF), V : Rated voltage (V) (at 20℃ after 2 minutes) 6.3V 10V 16V 25V 35V 50V Rated voltage (Vdc) tanδ(Max.) 0.26 0.19 0.16 0.14 0.12 0.10 (at 20℃ , 120Hz) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V Z(-25℃ ) /Z(+20℃ ) 2 2 2 2 2 2 Z(-40℃ ) /Z(+20℃ ) 3 3 3 3 3 3 Z(-55℃ ) /Z(+20℃ ) 4 4 4 3 3 3 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 2,000 hours at 105℃. Capacitance change ≦ ±30% of the initial value D.F. (tanδ) ≦ 200% of the initial specified value Leakage current ≦ The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦ ±30% of the initial value D.F. (tanδ) ≦ 200% of the initial specified value Leakage current ≦ The initial specified value The capacitors shall be subjected to 1,000 cycles each consisting of charging with the specified surge voltage for 30±5 seconds through a protective resistor (as required for RC=0.1±0.05sec) and open-circuiting for 5.5 minutes at a room temperature of 15 to 35℃. Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V 7.2V 12V 18V 29V 40V 57V Surge voltage (Vdc) Appearance Capacitance change D.F. (tanδ) Leakage current No significant damage ≦ ±20% of the initial value ≦ 200% of the initial specified value ≦ The initial specified value (Caution) Surge Voltage Test intends to evaluate capacitors in durability of an exceptional excessive voltage under specific conditions.It does not imply long-term use at all. ◆ DIMENSIONS [mm] ●Terminal Code : A ●Size code : F80 to JA0 ●Terminal Code : G(Vibration resistant structure) ●Size code : HA0 to JA0 ⊕ W ⊕ W 0.3max. Vent for JA0 P A±0.2 0.3max. L±0.5 ⊖ L±0.5(Note) Note : L±0.3 for F80 C±0.2 B±0.2 φD±0.5 C±0.2 B±0.2 φD±0.5 P Vent for JA0 A±0.2 Size Code F80 HA0 JA0 D 6.3 8 10 L A B C W P 7.7 6.6 6.6 7.2 0.5 to 0.8 1.9 10.0 8.3 8.3 9.0 0.7 to 1.1 3.1 10.0 10.3 10.3 11.0 0.7 to 1.1 4.5 : Dummy terminals ⊖ ◆ MARKING ●Rated voltage symbol EX) 35V330μF 3Q ⊖ 330 VZR ⊕ Rated voltage(Vdc) Symbol 6.3 j 10 A 16 C 25 E 35 V 50 H Applying voltage over the rated voltages causes the capacitors to have short lifetime. Besides, applying voltage over the specified surge voltages may cause to have short circuit failure. A protection circuit should be used if applied voltage will exceed the rated voltages. Please contact us for mass production schedule. Specifications in this bulletin are subject to change without notice. NIPPON CHEMI-CON CORPORATION 1669 1 Engineering Bulletin AlchipTM Tentative No.840A/Mar.2014 Vertical Surface Mount Type Aluminum Electrolytic Capacitors - MZR Series ◆ PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 E MZR 9 10 11 12 13 DA 14 15 16 17 M 18 G Supplement code Size code Capacitance tolerance code Capacitance code (ex. 220μF:221, 1,000μF:102) Taping code Terminal code(A, G) Voltage code (ex. 6.3V:6R3, 10V:100, 35V:350) Series code Category ◆ STANDARD RATINGS WV (Vdc) 6.3 10 16 25 35 50 Cap (μF) 680 1,500 2,200 470 1,000 1,500 330 680 1,000 220 470 820 150 330 560 220 330 Size code F80 HA0 JA0 F80 HA0 JA0 F80 HA0 JA0 F80 HA0 JA0 F80 HA0 JA0 HA0 JA0 tanδ 0.26 0.26 0.26 0.19 0.19 0.19 0.16 0.16 0.16 0.14 0.14 0.14 0.12 0.12 0.12 0.10 0.10 ESR (Ωmax/20℃ , 100kHz) Rated ripple current (mArms/105℃ , 100kHz) 0.16 0.08 0.06 0.16 0.08 0.06 0.16 0.08 0.06 0.16 0.08 0.06 0.16 0.08 0.06 0.18 0.12 600 850 1,190 600 850 1,190 600 850 1,190 600 850 1,190 600 850 1,190 670 900 Part No. EMZR6R3ADA681MF80G EMZR6R3□DA152MHA0G EMZR6R3□DA222MJA0G EMZR100ADA471MF80G EMZR100□DA102MHA0G EMZR100□DA152MJA0G EMZR160ADA331MF80G EMZR160□DA681MHA0G EMZR160□DA102MJA0G EMZR250ADA221MF80G EMZR250□DA471MHA0G EMZR250□DA821MJA0G EMZR350ADA151MF80G EMZR350□DA331MHA0G EMZR350□DA561MJA0G EMZR500□DA221MHA0G EMZR500□DA331MJA0G □ :Enter the appropriate terminal code. Please contact us for mass production schedule. Specifications in this bulletin are subject to change without notice. NIPPON CHEMI-CON CORPORATION 1669 2
EMZR500ADA101MF80G 价格&库存
很抱歉,暂时无法提供与“EMZR500ADA101MF80G”相匹配的价格&库存,您可以联系我们找货
