32208723
32208723
    HERAEUS(贺利氏)
    Radial
32208723 数据手册
Nexensos M310, Pt Temperature Sensor according to DIN EN 60751 Temperature range -70 °C to +500 °C, temporary up to +550 °C Narrow footprint for small diameter environments Excellent long term stability and low drift High accuracy and interchangeability High vibration and shock resistance Optimized for welding, brazing and crimping M-series Pt-RTDs are characterized by long-term stability and excellent precision over a wide temperature range. The M310 element combines the advantages of the the M-Series with a very slim size, supporting small probe gemetries and compact assemblies. This can be important in medical devices, industry and lab equipment, home appliance, consumer products and many other applications. In principle, the products can also be used in automotive applications, in this case Heraeus will check upon the request of the customer, whether additional requirements can be met (e.g. IMDS, PPAP). Nominal Resistance R₀ [Ω] Tolerance Class Order Number Packaging Pt100 F 0.15 (Class A) F 0.3 (Class B) 32208725 / 5014254 32208721 / 5014252 Blister reel / Plastic bag Blister reel / Plastic bag Pt1000 F 0.15 (Class A) F 0.3 (Class B) 32208727 / 5014255 32208723 / 5014253 Blister reel / Plastic bag Blister reel / Plastic bag The measuring point for the nominal resistance is 8 mm from the end of the sensor body. Temperature Range of Tolerance Class Tolerance Class F 0.15 (A) -50 °C to +300 °C Tolerance Class F 0.3 (B) -70 °C to +500 °C The specified tolerance classes refer to continuous operation. Class F 0.3 also applies up to +550 °C for short periods. Temperature Coefficient TCR = 3850 ppm/K Response Time Water (v = 0.4 m/s): Air (v = 2 m/s): t0.5 t0.9 t0.5 t0.9 = = = = Dimensions and Tolerances in mm L: W1: H: LL: Lø: W2: 3.0 ±0.15 1.0 ±0.15 0.8 +0.3 -0.2 10 ±1.0 0.15 ±0.02 0.5 ±0.1 0.04 s 0.12 s 2.5 s 8s Measuring Current Pt100 Ω: 0,3 to 1 mA Pt1000 Ω: 0.1 to 0.3 mA (self-heating has to be considered) Image for illustration purposes only Color, shape and forming of fixing drop may vary Heraeus Nexensos GmbH, Germany Web: www.heraeus-nexensos.com Contact: nexensos.america@heraeus.com Document: 20002220990 | Part 001 | Version 01 | Status: 09/2021 Page 1 of 2 Nexensos M310, Pt Temperature Sensor according to DIN EN 60751 Temperature range -70 °C to +500 °C, temporary up to +550 °C Long-Term Stability The drift of the resistance value at 0 °C after a storage for 1000 hours in air at the declared upper temperature limit is not more than the tolerance value of the declared tolerance class according DIN EN 60751. Typical drift of R(0 °C) is 0.04 % after 1000 hours at +500 °C. Self-Heating 0.4 K/mW at 0 °C Insulation Resistance > 100 MΩ at 20 °C > 2 MΩ at 500 °C Vibration Resistance At least 40 g acceleration at 10 to 2000 Hz, depends on installation Shock Resistance At least 100 g acceleration with 8 ms half sine wave, depends on installation Connection Technology Welding, Crimping, Brazing Lead Type Pt clad Ni-wire Tensile Strength of Leads ≥ 7N Packaging Blister reel, Plastic bag Alternative packaging forms on request. Storage Life Min. 12 months (in original packaging) Note Other tolerances, values of resistance and wire lengths are available on request. Due to random sample measurements, a bending of connection wires may occur (called V-shape). This bending is batch-dependent and has no influence on the functionality of the platinum measuring resistor. California Proposition 65 WARNING WARNING: This product can expose you to chemicals including lead oxide, which is known to the State of California to cause cancer and birth defects or other reproductive harm, and including cobalt oxide, nickel and cobalt, which are known to the State of California to cause cancer. For more information go to www.p65warnings.ca.gov The information provided in this data sheet describes certain technical characteristics of the product, but shall not be qualified or construed as quality guarantee (Beschaffenheitsgarantie) in the meaning of sections 443 and 444 German Civil Code. The information provided in this data sheet regarding measurement values (including, but not limited to, response time, long-term stability, vibration and shock resistance, insulation resistance and self-heating) are average values that have been obtained under laboratory conditions in tests of large numbers of the product. Product results or measurements achieved by customer or any other person in any production, test, or other environment may vary depending on the specific conditions of use. The customer is solely responsible to determine whether the product is suited for the customer's intended use; in this respect Heraeus cannot assume any liability. The sale of any products by Heraeus is exclusively subject to the General Terms of Sale and Delivery of Heraeus in their current version at the time of purchase, which is available under www.heraeus.com/gtc or may be furnished upon request. This data sheet is subject to changes without prior notice. Heraeus Nexensos GmbH, Reinhard-Heraeus-Ring 23, 63801 Kleinostheim, Germany Heraeus Nexensos GmbH, Germany Web: www.heraeus-nexensos.com Contact: nexensos.america@heraeus.com Document: 20002220990 | Part 001 | Version 01 | Status: 09/2021 Page 2 of 2
32208723 价格&库存
很抱歉,暂时无法提供与“32208723”相匹配的价格&库存,您可以联系我们找货
