Metal
Oxide
Varistors
14D Series
Circuit Protection
System
Revision:DEC-16
Please refer to http://www.ruilon.com.cn for current information.
Metal Oxide Varistors - 14D Series
Features
• Wide operating voltage (V1mA) range from 18V to 1800V.
• Fast responding to transient over-voltage.
• Large absorbing transient energy capability.
• Low clamping ratio and no following-on current.
General Information
• Surge protection in consumer electronics
• Surge protection in industrial electronics
• Relay and electromagnetic valve surge absorption
• Transistor, diode, IC, thyristor or triac semiconductor protection
• Surge protection in electronic home appliances, gas and petroleum appliances
General Characteristics
• Body: Nickel Plated
• Devices with No Leads: Nickel Plated
• Operating Temperature: -40ºC to +85ºC
• Storage Temperature: -40 ºC to +125ºC
• Leads: Surface-mount, Axial Devices: Tin Plated
Product Name
1
Element Diameter
4
D
Type
D: Disk
S: Square
4
7
1
K
J
Nominal Varistor Voltage
Varistor Voltage
Tolerance
Surge Series
471=47*101V
K = ±10 %
No Suffix:Standard
Type
J:High Surge Type
H:Super Surge Type
Circuit Protection
System
Revision:DEC-16
Page:1
Electriacl Characteristics
Type Number
Standard
High Surge
Maximum
Allowable
Voltage
Varistor Voltage
Maximum
Clamping
Voltage
VAC(V) VDC(V)
V1mA(V)
IP(A) VC(V)
Withstanding
Surge Current
I(A)
Standard
I(A)
High Surge
Maximum Energy Rated
(10/1000μs)
Power
(J)
Standard
(J)
High Surge
(W)
Typical
Capacitance
(Reference)
@1KHz(pf)
14D180K
14D180KJ
11
14
18(15~21.6)
10
36
1000
2000
3.2
4.1
0.1
18000
14D220K
14D220KJ
14
18
22(19.5~26)
10
43
1000
2000
4.0
5.0
0.1
15000
14D270K
14D270KJ
17
22
27(24~30)
10
53
1000
2000
4.9
6.1
0.1
10000
14K330K
14K330KJ
33(29.5~36.5)
10
66
1000
2000
5.9
7.4
0.1
8500
14D390K
14D390KJ
25
31
39(35~43)
10
77
1000
2000
7.0
8.8
0.1
7500
14D470K
14D470KJ
30
38
47(42~54)
10
93
1000
2000
8.5
10.6
0.1
6500
14D560K
14D560KJ
35
45
56(50~62)
10
100
1000
2000
10.1
12.6
0.1
5600
14D680K
14D680KJ
40
56
68(61~75)
10
135
1000
2000
12.2
15.3
0.1
4700
14D820K
14D820KJ
50
65
82(74~90)
50
135
4500
6000
14.8
18.5
0.6
3900
14D101K
14D101KJ
60
85
100(90~110)
50
165
4500
6000
18.0
22.5
0.6
3400
14D121K
14D121KJ
75
100
120(108~132)
50
200
4500
6000
21.6
27.0
0.6
3100
14D151K
14D151KJ
95
125
150(135~165)
50
250
4500
6000
27.0
33.8
0.6
3000
14D181K
14D181KJ
115
150
180(162~198)
50
300
4500
6000
32.4
40.5
0.6
1030
14D201K
14D201KJ
130
170
200(180~220)
50
340
4500
6000
36.0
45.0
0.6
970
14D221K
14D221KJ
140
180
220(198~242)
50
360
4500
6000
39.6
49.5
0.6
840
14D241K
14D241KJ
150
200
240(216~264)
50
395
4500
6000
43.2
54.0
0.6
710
14D271K
14D271KJ
175
225
270(243~297)
50
455
4500
6000
48.6
60.8
0.6
650
14D301K
14D301KJ
190
250
300(270~330)
50
500
4500
6000
54.0
67.5
0.6
600
14D331K
14D331KJ
210
275
330(297~363)
50
550
4500
6000
59.4
74.3
0.6
550
14D361K
14D361KJ
230
300
360(324~396)
50
595
4500
6000
64.8
81.0
0.6
500
14D391K
14D391KJ
250
320
390(351~429)
50
650
4500
6000
70.2
87.8
0.6
480
14D431K
14D431KJ
275
350
430(387~473)
50
710
4500
6000
77.4
96.8
0.6
440
14D471K
14D471KJ
300
385
470(423~517)
50
775
4500
6000
84.6
105.8
0.6
420
14D511K
14D511KJ
320
415
510(459~561)
50
845
4500
6000
84.6
105.8
0.6
390
14D561K
14D561KJ
350
460
560(504~616)
50
925
4500
6000
84.6
105.8
0.6
360
14D621K
14D621KJ
385
505
620(558~682)
50
1025
4500
6000
84.6
105.8
0.6
320
14D681K
14D681KJ
420
560
680(612~748)
50
1120
4500
6000
84.6
105.8
0.6
290
14D751K
14D751KJ
460
615
750(675~825)
50
1240
4500
6000
90.0
112.5
0.6
260
14D781K
14D781KJ
485
640
780(702~858)
50
1290
4500
6000
93.6
117.0
0.6
230
14D821K
14D821KJ
510
670
820(738~902)
50
1355
4500
6000
98.4
123.0
0.6
230
14D911K
14D911KJ
550
745
910(819~1001)
50
1500
4500
6000
109.2
136.5
0.6
200
14D951K
14D951KJ
580
780
950(855-1045)
50
1570
4500
6000
113.7
142.1
0.6
190
14D102K
14D102KJ
625
825
1000(900~1100)
50
1650
4500
6000
120.0
150.0
0.6
180
14D112K
14D112KJ
680
895
1100(990~1210)
50
1815
4500
6000
132.0
165.0
0.6
150
14D122K
14D12 2KJ
750
990
1200(1080~1320)
50
1980
4500
6000
150.0
185.0
0.6
150
14D152K
14D152KJ
900
1220
1500(1350-1650)
50
2475
4500
6000
179.0
223.0
0.6
140
14D182K
14D182KJ
1000
1465
1800(1620~1980)
50
2970
4500
6000
216.0
270.0
0.6
120
Circuit Protection
System
Revision:DEC-16
Please refer to http://www.ruilon.com.cn for current information. Page:2
Electrical Ratings
Items
Test Condition/Description
Requirement
Varistor Voltage
The voltage between two terminals with the specified measuring current
1mA.DC applied is called Vb.
Maximum Allowable
Voltage
The recommended maximum sine wave voltage (RMS) or the Maximum
DC voltage can be applied continuously.
The maximum voltage between two terminals with the specification
standard impulse current.
Applied waveform: 8/20μs
Maximum Clamping
Voltage
To meet the
Specified value
Rated Wattage
The maximum average power that can be applied within the specified
ambient temperature.
Energy
The maximum energy within the varistor voltage change of ±10% when
one impulse of 10/1000μs or 2ms is applied.
Withstanding Surge
Current
The maximum current within the varistor voltage change of ±10% with
the standard impulse current (8/20μs) applied one time.
The change of Vb shall be measured after the impulse listed below
which is applied 10,000 times continuously with the interval of ten
seconds at room temperature.
5Φ series
7Φ series
Surge Life
10Φ series
14Φ series
20Φ series
Circuit Protection
System
180K to 680K
10A (8/20μs)
820K to 751K
20A (8/20μs)
180K to 680K
25A (8/20μs)
820K to821K
50A (8/20μs)
180K to 680K
50A (8/20μs)
820K to 112K
100A (8/20μs)
180K to 680K
75A (8/20μs)
820K to 182K
150A (8/20μs)
180K to 680K
100A (8/20μs)
820K to 182K
200A (8/20μs)
∆Vb ≤±10%
Vb
Revision:DEC-16
Page:3
Soldering Recommendation
Wave Lead Free Soldering Recommendation
Item
Conditions
Peak Temperature
265ºC
Dipping Time
10 seconds (max.)
Soldering
1 time
Recommendation Reworking Conditions with Soldering Iron
Item
Conditions
Temperature of Soldering Iron-tip
360ºC (max.)
Soldering Time
3 seconds (max.)
Distance from Varistor
2mm (min.)
Circuit Protection
System
Revision:DEC-16
Please refer to http://www.ruilon.com.cn for current information. Page:4
Package Dimensions (Unit:mm)
A
T
D
B
H1
K
很抱歉,暂时无法提供与“14D361K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.80171
- 50+0.63375
- 250+0.54977
- 500+0.48678
- 2500+0.43643
- 5000+0.41116
