ES0402V014CT
ES0402V014CT
    AEM
ES0402V014CT 数据手册
Revision of August 2017 Surface Mount ESD Suppressors Recommended Reflow Soldering Profile: Profile Feature Preheat/Soak Temperature Min (Tsmin) Temperature Max(Tsmax) Time(ts) from (Tsmin to Tsmax) Ramp-uprate (TL to Tp) Liquidous temperature(TL) Time(tL) maintained above TL Peak package body temperature (Tp) Pb-Free Assembly 150°C 200°C 60~120 seconds 3°C/second max. 217°C 60~150 seconds 260°C Time (tp)*within 5°C of the specified classification temperature (Tc) 30 seconds * Ramp-down rate (Tp to TL) 6°C/second max. Time 25°C to peak temperature 8 minutes max. * Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum Recommended Conditions for Hand Soldering: 1. Appropriate temperature (max.) of soldering iron tip/soldering time (max.): 280°C/10s or 350°C/ 3s. 2. Using hot air rework station with tip that can melt the solder on both terminations at the same time is strongly recommended. Do not directly contact the chip termination with the tip of soldering iron Disclaimer: Specifications are subject to change without notice. AEM products are designed for specific applications and should not be used for any purpose (including, without limitation, automotive, aerospace, medical, life-saving applications, or any other application which requires especially high reliability for the prevention of such defect as may directly cause damage to the third party’s life, body or property) not expressly set forth in applicable AEM product documentation. It is the customer’s responsibility to validate that a particular product with the properties described in the product specification is suitable for use in a particular application. Warranties granted by AEM shall be deemed void for products used for any purpose not expressly set forth in applicable AEM product documentation. AEM shall not be liable for any claims or damages arising out of products used in applications not expressly intended by AEM as set forth in applicable AEM product documentation. The sale and use of AEM products is subject to AEM terms and conditions of sale. Please refer to AEM’s website for updated catalog and terms and conditions of sale. Website: www.aemchina.com & www.aemcomponents.com Revision of August 2017 Surface Mount ESD Suppressors GcDiode® ESD Suppressors Features:          Glass ceramic monolithic structure Ultra low capacitance (0.25 pF typical) Low leakage current (
ES0402V014CT 价格&库存
很抱歉,暂时无法提供与“ES0402V014CT”相匹配的价格&库存,您可以联系我们找货
