B24B-PHDSS-B(LF)(SN)
    JST
    插件,P=2mm
    线对板针座 2x12P 间距:2mm 直插 系列:PHD
B24B-PHDSS-B(LF)(SN) 数据手册
PHD CONNECTOR 2.0mm pitch/Disconnectable Crimp style connectors Specifications ––––––––––––––––––– • Current rating: 3A AC, DC (AWG #22) • Voltage rating: 250V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10m Ω max. After environmental testing/ 20m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 800V AC/minute • Applicable wire: AWG #28 to #22 • Applicable PC board thickness: 1.6mm This is a 2.0mm pitch, crimp style, doublerow, wire-to-board connector. It is designed to meet the demand for highdensity and low-profile connection. • Compact • Reliable contacts • Fully shrouded header * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 Top entry type Side entry type 5 2 ±0.05 1.95 min φ0.7 +0.1  0 5 7 min Even number circuits (3) Odd number circuits 2 ±0.05 (3) 2 ±0.05 8.8 φ0.7 +0.1  0 1.95 min 11.8 1.5 min 2 ±0.05 Circuit No.1 Note: 1. The above figure is the figure viewed from soldering side. 2. Tolerances are non-cumulative: ±0.05mm for all centers. 3. Hole dimensions differ according to the kind of PC board and piercing method. If PC boards made of hard material are used, the hole dimensions should be larger. The dimensions above should serve as a guideline. Contact JST for details. Contact Applicable wire AWG # mm2 Model No. 1.5 SPHD-002T-P0.5 SPHD-001T-P0.5 Insulation O.D. (mm) 0.08∼0.21 28∼24 0.9∼1.5 0.13∼0.33 26∼22 1.0∼1.5 Q'ty / reel 8,000 Material and Finish 6.5 Phosphor bronze, tin-plated (reflow treatment) 2.85 RoHS compliance 1.3 Contact Crimping machine Crimp applicator SPHD-002T-P0.5 AP-K2N Note: *Strip-crimp applicator 1 Applicator Dies Crimp applicator with dies MKS-L-10 MK/SPHD-002-05 APLMK SPHD002-05 *MKS-SC-10 SC/SPHD-002-05 APLSC SPHD002-05 Contact SPHD-001T-P0.5 Crimping machine Crimp applicator AP-K2N Applicator Dies Crimp applicator with dies MKS-L-10 MK/SPHD-001-05 APLMK SPHD001-05 *MKS-SC-10 SC/SPHD-001-05 APLSC SPHD001-05 PHD CONNECTOR Housing Circuits Model No. 8 PHDR-08VS PHDR-10VS PHDR-12VS PHDR-14VS PHDR-16VS PHDR-18VS PHDR-20VS PHDR-22VS PHDR-24VS PHDR-26VS PHDR-28VS PHDR-30VS PHDR-32VS PHDR-34VS 10 12 14 16 Circuit No.1 Circuit No.1 Circuit No.2 18 20 22 H JST 24 7.3 26 28 30 32 2 34 2 1.95 A 4.2 B 5 A Dimensions (mm) B Q'ty / bag 6.0 9.9 1,000 8.0 11.9 1,000 10.0 13.9 1,000 12.0 15.9 1,000 14.0 17.9 1,000 16.0 19.9 1,000 18.0 21.9 1,000 20.0 23.9 1,000 22.0 25.9 1,000 24.0 27.9 1,000 26.0 29.9 1,000 28.0 31.9 1,000 30.0 33.9 1,000 32.0 35.9 1,000 Material PA 66, UL94V-0, natural (white) RoHS compliance As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. PHDR-10VSS…natural (white) K…black Y…yellow E…blue R…red Shrouded header Top entry type Circuits Circuit No.1 8 10 JST 12 6.5 H 14 (3) 16 1.95 20 Circuit No.1 0.5 2 18 Circuit No.2 A 1.5 2 B 5 22 24 26 28 30 32 34 Model No. Glass-filled nylon Nylon Top entry Side entry Top entry Side entry type type type type B8B-PHDSS S8B-PHDSS B10B-PHDSS S10B-PHDSS B10B-PHDSS-B S10B-PHDSS-B B12B-PHDSS S12B-PHDSS B12B-PHDSS-B S12B-PHDSS-B B14B-PHDSS S14B-PHDSS B14B-PHDSS-B S14B-PHDSS-B B16B-PHDSS S16B-PHDSS B16B-PHDSS-B S16B-PHDSS-B B18B-PHDSS S18B-PHDSS B18B-PHDSS-B S18B-PHDSS-B B20B-PHDSS S20B-PHDSS B20B-PHDSS-B S20B-PHDSS-B B22B-PHDSS S22B-PHDSS B22B-PHDSS-B S22B-PHDSS-B B24B-PHDSS S24B-PHDSS B24B-PHDSS-B S24B-PHDSS-B B26B-PHDSS S26B-PHDSS B26B-PHDSS-B S26B-PHDSS-B B28B-PHDSS S28B-PHDSS B28B-PHDSS-B S28B-PHDSS-B B30B-PHDSS S30B-PHDSS B30B-PHDSS-B S30B-PHDSS-B B32B-PHDSS S32B-PHDSS B32B-PHDSS-B S32B-PHDSS-B B34B-PHDSS S34B-PHDSS B34B-PHDSS-B S34B-PHDSS-B Side entry type 0.5 A B Top entry Side entry type type 6.0 9.9 500 500 8.0 11.9 500 500 10.0 13.9 500 500 12.0 15.9 500 250 14.0 17.9 500 250 16.0 19.9 500 250 18.0 21.9 250 250 20.0 23.9 250 250 22.0 25.9 250 200 24.0 27.9 250 200 26.0 29.9 250 200 28.0 31.9 250 200 30.0 33.9 250 200 32.0 35.9 250 200 (3) 7 Circuit No.2 5 RoHS compliance This product displays (LF)(SN) on a label. 2 6.5 9.5 1.95 B Material and Finish JST 2 A Q'ty / box Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0, natural (ivory) PA 66, UL94V-0, natural (white) Circuit No.1 H Dimensions (mm) As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. Circuit No.1 ex. B10B-PHDSS- ex. B10B-PHDSS-B- S…natural (ivory) S…natural (white) K…black Y…yellow E…blue R…red 2
物料型号: - 型号包括SPHD-002T-P0.5和SPHD-001T-P0.5,适用于不同线径和绝缘外径的电线。
器件简介: - 这是一个2.0mm间距、可分离的压接式连接器,设计用于高密度和低轮廓连接。
引脚分配: - 电路1为偶数电路,电路2为奇数电路,具体引脚分配未在文档中详细说明。
参数特性: - 电流额定值:3A AC/DC(AWG #22) - 电压额定值:250V AC/DC - 温度范围:-25°C至+85°C - 接触电阻:初始值/10mΩ最大,环境测试后/20mΩ最大 - 绝缘电阻:1,000MΩ最小 - 耐电压:800V AC/分钟
功能详解: - 连接器具有紧凑、可靠的接触和完全罩住的头部。
应用信息: - 适用于AWG #28至#22的电线,PCB板厚1.6mm。
封装信息: - 提供多种尺寸的封装,如8至34针,材料包括PA 66, UL94V-0(自然白色)和玻璃填充尼龙。
B24B-PHDSS-B(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“B24B-PHDSS-B(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
    • 1+5.781281+0.74580
    • 10+3.8279110+0.49381
    • 50+3.2935850+0.42488
    • 100+2.93444100+0.37855
    • 500+2.86437500+0.36951
    • 1000+2.803051000+0.36160
    • 2000+2.776772000+0.35821
    库存:86
    库存:2500
      • 50+7.8882250+1.01760
      • 64+6.5735264+0.84800
      库存:68
