FH19SC-30S-0.5SH(05)
    HRS(广濑)
    SMD
FH19SC-30S-0.5SH(05) 数据手册
0.5 mm Pitch, 0.9 mm Height, FPC/FFC Connectors FH19C Series/FH19SC Series FH19C – FPC/FFC thickness: 0.2±0.03mm FH19SC – FPC/FFC thickness: 0.3±0.03mm Actuator color: Black ■Features ● 0.9mm high (30 pos. shown) 1. Low-profile 0.5mm pitch FPC/FFC Connectors Miniaturization of portable equipment and personal mobile devices has created increased demand for a low profile, high density, and high reliability connectors. 17m m m *The design of this connector has been made thinner and smaller, with a height of 0.9mm and width of 3mm. *PCB footprint: Reduced approximately 48% (as compared with Hirose Electric's 0.5mm pitch FH12 Series connectors) *Connector weight: Reduced approximately 78% (as compared with Hirose Electric's 0.5mm pitch FH12 Series connectors) 0.9mm 3m Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Actuator color: Brown ● Can be mounted over conductive traces 2. Conductive traces on the PCB can run under the connector All bottom surface of the connector is solid, without any exposure of the contact. 3. Proven Flip-Lock Actuator System assures easy and reliable operation Rotating actuator permits easy insertion and reliable connection with the FPC & FFC. Tactile sensation confirms complete mechanical locking of the actuator and the electrical connection. 4. Accepts 0.2mm & 0.3mm thick FPC/FFC No exposed contacts on the bottom of the connector. The connector will also terminate with 0.2mm thick Flat Flexible Cable (FFC). 5. Board placement with automatic equipment Flat upper surface and tape and reel packaging facilitate vacuum pick-up and placement. Standard reel packaging contains 5000 connectors. Enclosed construction (No exposed contacts) Metal fittings (Leadless) ● Metal Fittings (Leadless Type) No protrusions on the sides allows close side-by-side board placement. ● Actuator Temporary Hold Mechanism 6. Wide range of contact counts The contact positions available range from 4 to 50. 7. Satisfies Halogen-free requirements All materials and substances used in this product comply with the Halogen-free standards. * Defined according to IEC61249-2-21 Br: 900ppm max, Cl: 900ppm max, Br+Cl: 1,500ppm max Actuator stays open during insertion of the FPC/FFC. 2013.11w 1 FH19C & FH19SC Series●0.5mm pitch, 0.9mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors ■Product Specifications Current rating 0.5 A (Note1) Rating Voltage rating 50 V AC Recommended Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FPC, FFC Operating temperature range -55ç to +85ç (Note 2) Operating humidity range Relative humidity 90% max. (No condensation) Storage temperature range -10ç to +50ç (Note 3) Storage humidity range Relative humidity 90% max. (No condensation) FH19C Series Thickness: = 0.2 ± 0.03mm Gold plated FH19SC Series Thickness: = 0.3 ± 0.03mm Gold plated Item Specification 1. Insulation resistance 500 M ohms min. 2. Withstanding voltage No flashover or insulation breakdown 100 m ohms max. 3. Contact resistance *Including FPC/FFC conductor resistance Conditions 1 mA 4. Durability Contact resistance: 100 m ohms max. (insertion/ withdrawal) No damage, cracks, or parts dislocation. 20 cycles 100 V DC 150 V AC/1 minute 5. Vibration No electrical discontinuity of 1 μs or more. Frequency: 10 to 55 Hz, single amplitude of Contact resistance: 100 m ohms max. No damage, cracks, or parts dislocation. 0.75mm, 10 cycles in each of the 3 directions 6. Shock No electrical discontinuity of 1 μs. min. Contact resistance: 100 m ohms max. No damage, cracks, or parts dislocation. Acceleration of 981 m/s2, 6 ms duration, sine halfwave waveform, 3 cycles in each of the 3 axis. 7. Humidity (Steady state) Contact resistance: 100 m ohms max. Insulation resistance: 100 M ohms min. No damage, cracks, or parts dislocation. 96 hours at temperature of 40ç and humidity of 90 to 95% 8. Temperature cycle Contact resistance: 100 m ohms max. Insulation resistance: 100 M ohms min. No damage, cracks, or parts dislocation. Temperature: -55ç / +15ç to +35ç / +85ç / +15ç to +35ç Time : -30 / 2 to 3 / +30 / 2 to 3(Minutes) 5 cycles 9. Resistance to soldering heat No deformation of components affecting performance. Reflow: At the recommended temperature profile Manual soldering: 350ç±5ç for 5 seconds Note 1: When passing the current through all of the contacts, use 70% of the current rating. Note 2: Includes temperature rise caused by current flow. Note 3: The term “storage” refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non- conducting condition of installed connectors in storage, shipment or during transportation.Information ■Materials Part Material Insulator LCP Contacts Metal fittings Phosphor bronze Phosphor bronze Finish Color: Beige Color: Brown (FH19C Series) Color: Black (FH19SC Series) Gold plated Pure tin reflow plated Remarks UL94V-0 ------------- ■Ordering information FH 19 C - 30S - 0.5 SH (05) 1 2 3 4 5 6 1 Series name : FH 5 Contact pitch : 0.5mm 2 Series No. : 19 6 Terminal type 3 FPC thickness : 0.2mm FPC/FFC thickness : 0.3mm C : SC : 4 No. of contacts : 4 to 50 7 SH: SMT horizontal mounting type 7 Material and plating specifications : FH19C : (10)...Gold plating with nickel barrier 5,000pieces/reel (99)...Gold plating with nickel barrier 500pieces/reel FH19SC : (09)...Gold plating with nickel barrier 5,000pieces/reel (99)...Gold plating with nickel barrier 500pieces/reel 2 FH19C & FH19SC Series●0.5mm pitch, 0.9mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors ■Connector Dimension [FH19C Series] 3 A±0.15 B +0.15 0 0.5 (0.15) 2.5±0.15 A Polarizing mark indicator (0.5) Number of contacts indicator (130°) (1.6) Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (1) 0.15 G 0.9±0.1(Including contact terminal leads) G ∞Number of contacts 0.5 (0.15) (C: FPC insertion slot dimension) 2 1 0.15MAX D±0.1 0.15MAX (1.3) 1 2 S 2.15±0.2 Notes 1 The coplanarity of each terminal lead and metal fitting is within 0.1mm. 2 The contact terminal lead position indicates the dimension from the bottom surface of the insulator body. 3 Difference between terminal contact to be max. 0.1mm. 4 Packaged on tape and reel only. Check packaging specification. 5 Any discoloration of the plastic compound will NOT AFFECT form, fit or function of the connector. 6 After reflow, the terminal plating may change color, however this does not represent a quality issue. Unit: mm Part Number CL No. Number of Contacts A B C D FH19C-04S-0.5SH(**) 580-0410-1-** 4 4 1.5 2.57 3.35 FH19C-05S-0.5SH(**) 580-0418-3-** 5 4.5 2 3.07 3.85 FH19C-06S-0.5SH(**) 580-0409-2-** 6 5 2.5 3.57 4.35 FH19C-07S-0.5SH(**) 580-0411-4-** 7 5.5 3 4.07 4.85 FH19C-08S-0.5SH(**) 580-0404-9-** 8 6 3.5 4.57 5.35 FH19C-09S-0.5SH(**) 580-0403-6-** 9 6.5 4 5.07 5.85 FH19C-10S-0.5SH(**) 580-0412-7-** 10 7 4.5 5.57 6.35 FH19C-12S-0.5SH(**) 580-0413-0-** 12 8 5.5 6.57 7.35 FH19C-13S-0.5SH(**) 580-0405-1-** 13 8.5 6 7.07 7.85 FH19C-15S-0.5SH(**) 580-0406-4-** 15 9.5 7 8.07 8.85 FH19C-17S-0.5SH(**) 580-0408-0-** 17 10.5 8 9.07 9.85 FH19C-20S-0.5SH(**) 580-0402-3-** 20 12 9.5 10.57 11.35 FH19C-21S-0.5SH(**) 580-0414-2-** 21 12.5 10 11.07 11.85 FH19C-24S-0.5SH(**) 580-0407-7-** 24 14 11.5 12.57 13.35 FH19C-27S-0.5SH(**) 580-0401-0-** 27 15.5 13 14.07 14.85 FH19C-30S-0.5SH(**) 580-0400-8-** 30 17 14.5 15.57 16.35 FH19C-34S-0.5SH(**) 580-0419-6-** 34 19 16.5 17.57 18.35 FH19C-40S-0.5SH(**) 580-0416-8-** 40 22 19.5 20.57 21.35 FH19C-50S-0.5SH(**) 580-0417-0-** 50 27 24.5 25.57 26.35 Note1: Embossed tape reel packaging (5,000 pieces/reel, 500 pieces/reel). Order by number of reels. 3 FH19C & FH19SC Series●0.5mm pitch, 0.9mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors [FH19SC Series] 3 A±0.15 0.5 (0.15) 2.5±0.15 (1) 0.15 G +0.15 0 G ∞Number of contacts 0.5 0.93±0.1(Including contact terminal leads) B Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. A Polarizing mark indicator (0.5) 5 (130°) (1.6) Number of contacts indicator (0.15) (C: FPC insertion slot dimension) 2 1 0.15MAX D±0.1 0.15MAX (1.3) 1 2 S 2.15±0.2 Notes 1 2 3 4 5 6 7 The coplanarity of each terminal lead and metal fitting is within 0.1mm. The contact terminal lead position indicates the dimension from the bottom surface of the insulator body. Difference between terminal contact to be max. 0.1mm. Any discoloration of the plastic compound will NOT AFFECT form, fit or function of the connector. The contacts are protruding. 0.03mm max. from the housing top surface. Packaged on tape and reel only. Check packaging specification. After reflow, the terminal plating may change color, however this does not represent a quality issue. CL No. Number of Contacts A B C D FH19SC-12S-0.5SH(**) 580-0512-1-** 12 8 5.5 6.57 7.35 FH19SC-13S-0.5SH(**) 580-0518-8-** 13 8.5 6 7.07 7.85 FH19SC-14S-0.5SH(**) 580-0509-7-** 14 9 6.5 7.57 8.35 FH19SC-15S-0.5SH(**) 580-0503-0-** 15 9.5 7 8.07 8.85 FH19SC-16S-0.5SH(**) 580-0521-2-** 16 10 7.5 8.57 9.35 FH19SC-17S-0.5SH(**) 580-0504-3-** 17 10.5 8 9.07 9.85 FH19SC-18S-0.5SH(**) 580-0519-0-** 18 11 8.5 9.57 10.35 FH19SC-20S-0.5SH(**) 580-0502-8-** 20 12 9.5 10.57 11.35 FH19SC-21S-0.5SH(**) 580-0505-6-** 21 12.5 10 11.07 11.85 FH19SC-22S-0.5SH(**) 580-0506-9-** 22 13 10.5 11.57 12.35 FH19SC-24S-0.5SH(**) 580-0511-9-** 24 14 11.5 12.57 13.35 FH19SC-26S-0.5SH(**) 580-0510-6-** 26 15 12.5 13.57 14.35 FH19SC-27S-0.5SH(**) 580-0516-2-** 27 15.5 13 14.07 14.85 FH19SC-28S-0.5SH(**) 580-0513-4-** 28 16 13.5 14.57 15.35 FH19SC-30S-0.5SH(**) 580-0500-2-** 30 17 14.5 15.57 16.35 FH19SC-32S-0.5SH(**) 580-0514-7-** 32 18 15.5 16.57 17.35 Note1: Embossed tape reel packaging (5,000 pieces/reel, 500pieces/reel) . Order by number of reels. 4 Unit: mm Part Number FH19C & FH19SC Series●0.5mm pitch, 0.9mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors ■Recommended PCB Land and Metal Mask Dimensions [Common to FH19C & FH19SC Series] Recommended metal mask thickness: 0.10 mm. H (3) (0.15) (0.2) (0.15) 0.8±0.05 (0.05) J±0.1 K±0.1 (A) ■Recommended FPC, FFC Dimensions [Common to FH19C & FH19SC Series] L±0.05 2R0 0.35±0.03(FPC) 0.3±0.03(FFC) 0.5±0.03 FH19C Series FH19SC Series 0.2±0.03 0.3±0.03 (X) 3.5 min. (Stiffener) 3.5 min. (Stiffener) B±0.03 .2 0.5±0.07 2.5±0.3 (Exposed traces) Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3.3±0.05 (0.15) (0.15) 0.5 (2.5) 0.8±0.05 B ∞Number of contacts 0.3±0.05 (Land) 0.1 H 0.25±0.05 (Metal mask) Note 1: Stiffener dimension should be 3.5mm min., and X dimension should be 0.5mm for improved flexibility of FPC. Unit: mm Number of Contacts 4 5 6 7 8 9 10 12 13 14 15 16 17 18 A 4.0 4.5 5.0 5.5 6.0 6.5 7.0 8.0 8.5 9.0 9.5 10.0 10.5 11.0 B 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.5 6.0 6.5 7.0 7.5 8.0 8.5 J 3.1 3.6 4.1 4.6 5.1 5.6 6.1 7.1 7.6 8.1 8.6 9.1 9.6 10.1 K 3.9 4.4 4.9 5.4 5.9 6.4 6.9 7.9 8.4 8.9 9.4 9.9 10.4 10.9 L 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.5 7.0 7.5 8.0 8.5 9.0 9.5 Unit: mm Number of Contacts 20 21 22 24 26 27 28 30 32 34 40 45 50 A 12.0 12.5 13.0 14.0 15.0 15.5 16.0 17.0 18.0 19.0 22.0 24.5 27.0 B 9.5 10.0 10.5 11.5 12.5 13.0 13.5 14.5 15.5 16.5 19.5 22.0 24.5 J 11.1 11.6 12.1 13.1 14.1 14.6 15.1 16.1 17.1 18.1 21.1 23.6 26.1 K 11.9 12.4 12.9 13.9 14.9 15.4 15.9 16.9 17.9 18.9 21.9 24.4 26.9 L 10.5 11.0 11.5 12.5 13.5 14.0 14.5 15.5 16.5 17.5 20.5 23.0 25.5 5 FH19C & FH19SC Series●0.5mm pitch, 0.9mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors ■FH19C & FH19SC Series FPC/FFC Construction (Recommended Specifications) 1. Using Single-sided FPC FPC : Flexible Printed Circuit Material Name Covering layer film Material Polyimide 1 mil thick Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Cover adhesive (25) (25) (25) 3 3 35 35 Surface treatment Copper foil Cu Base adhesive Thermosetting adhesive 25 25 Base film Polyimide 1 mil thick 25 25 Reinforcement material adhesive Thermosetting adhesive 30 30 75 175 193 293 1oz Polyimide FH19C : 3mil FH19SC: 7mil Total FPC : Flexible Printed Circuit Material Name Covering layer film Cover adhesive Material Polyimide 1 mil thick Thickness (μm) FH19C FH19SC (25) (25) (25) (25) 3 3 15 15 18 18 Surface treatment Nickel under plated 1 to 5μm / Gold plated 0.2μm Through-hole copper Cu Copper foil Cu Base adhesive Thermosetting adhesive 18 18 Base film Polyimide 25 25 Base adhesive 18 18 Copper foil Cu 18 18 Cover adhesive Thermosetting adhesive 25 25 Polyimide 1 mil thick 25 25 Reinforcement material adhesive Thermosetting adhesive 25 50 25 100 197 297 Covering layer film 1/2oz 1 mil thick 1/2oz Polyimide Stiffener FH19C : 1mil FH19SC: 4mil Total 3. Using FFC (Flexible Flat Cable) (25) Nickel under plated 1 to 5μm / Gold plated 0.2μm Stiffener 2. Using Double-sided FPC Thickness (μm) FH19C FH19SC FFC : Flexible Flat Cable Material Name Material Polyester film Adhesive Polyester thermoplastic type (Nickel under plated / Gold plated), soft copper film Adhesive Polyester Polyester Thickness (μm) FH19C FH19SC (12) (12) (30) (30) 35 35 30 30 12 12 Adhesive Polyester 30 30 Stiffener Polyester 100 188 Total 207 295 * Practical tolerance of thickness dimension is ±20μm (i.e., 187 to 227μm). 4. Precautions 1. This specification is a recommendation for the construction of the FH19C/FH19SC Series FPC and FFC (t=0.2/0.3±0.03). 2. For details about the construction, please contact the FPC/FFC manufacturers. 6 FH19C & FH19SC Series●0.5mm pitch, 0.9mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors ■Packaging Specifications [Common to FH19C & FH19SC Series] ● Embossed Carrier Tape Dimensions 8±0.1 (3.3) (4.3) Unreeling direction Flat surface for placement with automatic equipment (1) ) ●Reel Dimensions (Ø1 3 (Ø80) (R:INSIDE) (Ø380) Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Q) Ø1 .5 (0.3) M±0.3 1.75±0.1 2±0.15 + 0. 0 1 4±0.1 N±0.1 (1.7) (T:OUTSIDE) End cection Mounting cection Embossed carrier tape Blank cection (10 pockets min.) Lead cection (400 mm min.) Blank cection Top cover tape (10 pockets min.) Unit: mm Number of Contacts 4 5 6 7 8 9 10 12 13 14 15 16 17 18 M 16 16 16 16 16 16 16 16 16 16 16 24 24 24 N 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 11.5 11.5 11.5 Q 4.3 4.8 5.3 5.8 6.3 6.8 7.3 8.3 8.8 9.3 9.8 10.3 10.8 11.3 R 17.4 17.4 17.4 17.4 17.4 17.4 17.4 17.4 17.4 17.4 17.4 25.4 25.4 25.4 T 21.4 21.4 21.4 21.4 21.4 21.4 21.4 21.4 21.4 21.4 21.4 29.4 29.4 29.4 Unit: mm Number of Contacts 20 21 22 24 26 27 28 30 32 34 40 45 50 M 24 24 24 24 24 24 24 24 32 32 44 44 44 N 11.5 11.5 11.5 11.5 11.5 11.5 11.5 11.5 14.2 14.2 20.2 20.2 20.2 Q 12.3 12.8 13.3 14.3 15.3 15.8 16.3 17.3 18.3 19.3 22.3 24.8 27.3 R 25.4 25.4 25.4 25.4 25.4 25.4 25.4 25.4 33.4 33.4 45.4 45.4 45.4 T 29.4 29.4 29.4 29.4 29.4 29.4 29.4 29.4 37.4 37.4 49.4 49.4 49.4 Note: Embossed tape 32 mm or wider will have perforated feed holes on two sides. 7 FH19C & FH19SC Series●0.5mm pitch, 0.9mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors ■Recommended Temperature Profile [For FH19C & FH19SC Series] MAX 250ç 250 230ç Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Temperature(ç) 200 HRS test condition Solder method Solder composition :Reflow, IR/hot air :Paste, 96.5%Sn/3.0%Ag/0.5%Cu (Senju Metal Industry, Co., 200ç Ltd.’s Part 150 Number:M705-221CM5-3210.5) 150ç Test board :Glass epoxy 45mm∞100mm∞1.6mm thick Land dimensions Metal mask :0.3mm∞0.8mm :0.25mm∞0.8mm∞0.1mm 100 50 25ç (60 sec.) 90 sec. to 120 sec. (60 sec.) This temperature profile is based on the above conditions. Soldering In individual applications the actual temperature may vary, depending on solder paste type, 0 Start Preheating Time (Seconds) volume/thickness and board size/thickness. Consult tour solder paste and equipment manufacturer for specific recommendations. 8 FH19C & FH19SC Series●0.5mm pitch, 0.9mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors ■Connector Operation and Precautions Operation 1. FPC/FFC Termination procedure. Connector installed on the board. Precautions 1) Do not apply excessive force or use any type of tool to operate the actuator. Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1) Lift up the actuator. Use thumb or index finger. 2) The connector will assure reliable performance when the actuator is open to 130° maximum. Do not exceed this angle, as this may cause permanent damage to the connector. 2) Assure that the FPC/FFC is fully inserted parallel to mounting surface, with the exposed conductive traces facing down. FPC conductor surface (Bottom side) 3) Rotate down the actuator until firmly closed. It is critical that the inserted FPC/FFC is not moved and remains fully inserted. Should the FPC/FFC be moved, open the actuator and repeat the process, starting with Step 1 above. 3) Insert the FPC/FFC straight into the insertion opening. Failing to follow this precaution can lead to damaging the FPC/FFC and altering its connectivity. ing open tion r e s in ·FFC FPC 4) When you insert the FPC into the insertion opening, do not apply excessive pressure or scrape the FPC on the bottom of the opening. Doing so can lead to deformities of the contacts and can hinder the performance of the connector. 2. FPC/FFC Removal 1) Lift up the actuator. 2) Carefully remove the FPC/FFC. 5) Application of excessive force to the inserted FPC/FFC may cause damage to connector and may affect the reliability of electrical connection. If specific application requires continuous or repeated pull or bend of the inserted FPC/FFC, assure that the forces are NOT transmitted directly to the connector. 9 FH19C & FH19SC Series●0.5mm pitch, 0.9mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. NOTES : 10 FH19C & FH19SC Series●0.5mm pitch, 0.9mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. NOTES : 11 Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FH19C & FH19SC Series●0.5mm pitch, 0.9mm above the board, Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors Powered by TCPDF (www.tcpdf.org) USA: HIROSE ELECTRIC (U.S.A.), INC. Headquarters 2688 Westhills Court, Simi Valley, CA 93065-6235 Phone : 1-805-522-7958 Fax : 1-805-522-3217 http://www.hiroseusa.com USA: HIROSE ELECTRIC (U.S.A.), INC. North California Office 20400 Stevens Creek Blvd., Ste 250, Cupertino, CA 95014 Phone : 1-408-253-9640 Fax : 1-408-253-9641 http://www.hiroseusa.com USA: HIROSE ELECTRIC (U.S.A.), INC. Detroit Office (Automotive) 37677 Professional Center Drive, Suite #100C Livonia, MI 48154 Phone : 1-734-542-9963 Fax : 1-734-542-9964 http://www.hiroseusa.com GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Herzog-Carl-Strasse 4 D-73760 Ostfildern (Scharnhauser Park) Phone : 49-711-4560-02-1 Fax : 49-711-4560-02-299 http://www.hirose.de THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : 31-20-6557460 Fax : 31-20-6557469 http://www.hiroseeurope.com UK: HIROSE ELECTRIC EUROPE B.V. UK BRANCH First Floor, St Andrews House, Caldecotte Lake Business Park, Milton Keynes MK7 8LE Phone : 44-1908-369060 Fax : 44-1908-369078 http://www.hirose.co.uk CHINA: HIROSE ELECTRIC CO., LTD. BEIJING REPRESENTATIVE OFFICE A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, Chao Yang District, Beijing, 100025 Phone : 86-10-5165-9332 Fax : 86-10-5908-1381 http://www.hirose-china.com.cn CHINA: HIROSE ELECTRIC (SHANGHAI) CO., LTD. 1501-02, Cross Tower Building, 318 Fuzhou Road, Huang Pu District, Shanghai 200001 Phone : 86-21-6391-3355 Fax : 86-21-6335-0767 http://www.hirose-china.com.cn CHINA: HIROSE ELECTRIC CO., LTD. SHENZHEN OFFICE Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre 5002, ShenNanDong Road, ShenZhen City, Guangdong Province, 518008 Phone : 86-755-8207-0851 Fax : 86-755-8207-0873 http://www.hirose-china.com.cn HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Unit 1102 A&B, Energy Plaza, 92 Granville Road, Tsim Sha Tsui East, Kowloon Phone : 852-2803-5338 Fax : 852-2591-6560 http://www.hirose-hongkong.com.hk TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : 886-2-2555-7377 Fax : 886-2-2555-7350 http://www.hirose-taiwan.com.tw SINGAPORE: HIROSE ELECTRIC CO., LTD. 10 Anson Road #26-16 International Plaza 079903 Phone : 65-6324-6113 Fax : 65-6324-6123 http://www.hirose-singapore.com.sg KOREA: HIROSE KOREA CO., LTD. 1261-10, Jeoungwhang-Dong, Shihung-City, Kyunggi-Do 429-450 Phone : 82-31-496-7000,7124 Fax : 82-31-496-7100 http://www.hirose.co.kr ® 12 6-3,Nakagawa Chuoh-2-Chome,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The contents of this catalog are current as of date of 11/2013. Contents are subject to change without notice for the purpose of improvements.
FH19SC-30S-0.5SH(05) 价格&库存
很抱歉,暂时无法提供与“FH19SC-30S-0.5SH(05)”相匹配的价格&库存,您可以联系我们找货
