TSS40U
TSS40U
    TAIWANSEMICONDUCTOR(台湾半导体)
TSS40U 数据手册
TSS40U Taiwan Semiconductor Small Signal Product Surface Mount Schottky Barrier FEATURES - Designed for mounting on small surface - Extremely thin/leadless package - Low capacitance - Low forward voltage drop - Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC - Halogen-free according to IEC 61249-2-21 0603 MECHANICAL DATA - Case: 0603 - Terminal: Gold plated, solderable per MIL-STD-750, method 2026 - Polarity: Indicated by cathode band - Weight: 3 mg (approximately) - Marking code: BC MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted) PARAMETER Repetitive Peak Reverse Voltage DC Reverse Voltage RMS Reverse Voltage Average Forward Current Peak Forward Surge Current 8.3ms Single Half Sine-Wave Superimposed on Rate Load Power Dissipation Forward Voltage SYMBOL VALUE UNIT VRRM 40 V VR 40 V VR(RMS) 28 V IO 200 mA IFSM 600 mA 150 mW Pd IF = 1.0 mA IF = 40 mA VF 0.38 1.0 V IR 0.2 μA CJ 5 pF trr 5 ns Junction Temperature TJ -65 to +125 °C Storage Temperature TSTG -65 to +125 °C Reverse Leakage Current Typical Capacitance Between Terminals VR = 0 V , f = 1.0 MHz Reverse Voltage Reverse Recovery Time ( IF= IR= 10mA, IRR= 0.1×IR, RL=100Ω ) VR = 30 V Version: C1601 TSS40U Taiwan Semiconductor Small Signal Product RATINGS AND CHARACTERISTICS CURVES (TA=25°C unless otherwise noted) Fig. 2 Reverse Characteristics Fig.1 Forward Characteristics 100000 100 125°C 10 25°C 1 125°C 10000 75°C Reverse Current (nA) Forward Current (mA) 1000 75°C 1000 25°C 100 -25°C 10 -25°C -25oC 1 0.1 0 0.2 0.4 0.6 0.8 1 0 1.2 10 20 30 40 Reverse Voltage (V) Forward Voltage (V) Fig. 3 F Fig. 3 Capacitance Between Terminals Characteristics Fig. 4 120 Average Forward Current (%) Capacitance Between Terminals (pF) 4 3 2 1 0 0 10 20 30 40 Mounting on glass epoxy PCBs 100 80 60 40 20 0 0 25 50 75 100 125 150 Reverse Voltage (V) Ambient Temperature (°C) Version: C1601 TSS40U Taiwan Semiconductor Small Signal Product ORDERING INFORMATION PART NO. PACKING CODE TSS40U RG PACKING CODE SUFFIX PACKAGE PACKING 0603 4K / 7" Reel G Note: Whole series with green compound EXAMPLE EXAMPLE PART NO. TSS40U RGG PART NO. PACKING CODE TSS40U RG PACKING CODE DESCRIPTION SUFFIX G Green compound PACKAGE OUTLINE DIMENSION 0603 DIM. Unit (mm) Unit (inch) Min Typ. Max Min Typ. Max L 1.60 - 1.80 0.063 - 0.071 W 0.80 - 1.00 0.031 - 0.039 T 0.70 - 0.85 0.028 - 0.033 C - 0.45 - - 0.018 - D - 0.70 - - 0.028 - Version: C1601 TSS40U Taiwan Semiconductor Small Signal Product Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Version: C1601
TSS40U 价格&库存
很抱歉,暂时无法提供与“TSS40U”相匹配的价格&库存,您可以联系我们找货
