TF31-8S-0.5SH(800)
TF31-8S-0.5SH(800)
    HRS(广濑)
    TF31-8S-0.5SH(800)
TF31-8S-0.5SH(800) 数据手册
DESCRIPTION OF REVISIONS COUNT RE-5-2033 8 1 △ APPLICABLE STANDARD OPERATING TEMPERATURE Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. CHKD DATE COUNT DESCRIPTION OF REVISIONS STORAGE TEMPERATURE RANGE VOLTAGE CURRENT 1 0.5A [AC(rms) / DC] (note2) APPLICABLE CABLE GENERAL EXAMINATION VISUALLY AND BY MEASURING INSTRUMENT MARKING CONFIRMED VISUALLY RELATIVE HUMIDITY 90% MAX (NOT DEWED) HUMIDITY RANGE TEST METHOD CONSTRUCTION DATE CHKD -10℃ ~ +50℃(Packed Condition) OPERATING OR STORAGE SPECIFICATIONS ITEM BY △ △ 1 -40℃ ~ +105℃ (note1) 50V [AC(rms) / DC] RANGE RATING BY Y.K.G C.D.H 18.10.04 FPC/FFC (TYPE A : t=0.3±0.03mm) (TYPE B : t=0.3±0.05mm) REQUIREMENTS QT AT ACCORDING TO DRAWING O O O O O O O O O O O - O - O - O - O - O - O - ELECTRICAL CHARACTERISTICS CONTACT RESISTANCE INSULATION RESISTANCE MATE APPLICABLE FPC/FFC AND APPLY A CURRENT OF 50 mΩ MAX. AC 20mV MAX, 1mA INCLUDING FPC/FFC BULK RESISTANCE(L=8mm) MATE APPLICABLE FPC/FFC AND APPLY A VOLTAGE OF 500 MΩ MIN. DC 100V VOLTAGE PROOF MATE APPLICABLE FPC/FFC AND APPLY A VOLTAGE OF NO FLASHOVER OR BREAKDOWN. AC 150V FOR 1 min. MECHANICAL CHARACTERISTICS FPC RETENSION FORCE 1 MEASURE BY APPLICABLE FPC/FFC(t=0.3) AT INITIAL CONDITION ①HORIZONTAL DIRECTION : 0.4N*n min. ②VERTICAL DIRECTION : 0.3N*n min. MECHANICAL OPERATION 20 TIMES INSERTIONS AND EXTRATIONS VIBRATION FREQUENCY 10 ~ 55 Hz, TOTAL AMPLITUDE 1.5 mm AT 2h, IN 3 DIRECTIONS SHOCK 981m/s2 DIRECTION OF PULSE 6ms AT 3 TIMES IN 3 DIRECTIONS. (n = Number of Contacts)(note 3) ①CONTACT RESISTANCE: 50mΩ MAX ②NO DAMAGE,CRACK AND LOOSENESS OF PARTS ①NO ELECTRICAL DISCONTINUITY OF 1㎲. ②CONTACT RESISTANCE : 50mΩ MAX ③NO DAMAGE,CRACK AND LOOSENESS OF PARTS ENVIRONMENTAL CHARACTERISTICS DAMP HEAT(STEADY STATE) EXPOSED AT 40±2℃, 90~95 %, 96Hr. ①CONTACT RESISTANCE: 50 mΩ MAX. RAPID CHANGE OF TEMPERATURE TEMPERATURE:-40±2→15~35→+105±2→15~35 ℃ ②INSULATION RESISTANCE: 50MΩ MIN. TIME : ③NO DAMAGE, CRACK OR LOOSENESS OF PARTS. 1 30 → 2~3 → 30 → 2~3 min. UNDER 5 CYCLES. DAMP HEAT, CYCLE TEMPERATURE -10→+65 HUMIDITY : 90~95% 10 CYCLE(240Hr) DRY HEAT 1 COLD CORROSION SALT SPRAY EXPOSED AT 105±2℃, 96Hr ①CONTACT RESISTANCE : 50mΩ MAX O EXPOSED AT -40±2℃, 96Hr ②NO DAMAGE, CRACK OR LOOSENESS OF PARTS. O - EXPOSED AT 35±2℃, 5±1% SALT WATER SPRAY FOR 48Hr ①CONTACT RESISTANCE 50mΩ MAX O - O - O - O - ②NO DAMAGE, CRACK OR LOOSENESS OF PARTS. HYDROGEN SULPHIDE EXPOSED IN 3 PPM FOR 96Hr. ③NO EVIDENCE OF CORROSION WHICH AFFECTS (TEST STANDARD : JEIDA-38) TO OPERATION OF CONNECTOR. RESISTANCE TO 1)REFLOW SOLDERING: SOLDERING HEAT PEAK TMP. : 250℃ MAX. TMP. 230℃ MIN FOR 60s SOLDER ABILITY 1 ①NO DEFORMATION OF CASE OF EXCESSIVE LOOSENESS OF THE TERMINALS. 2)SOLDERING IRONS TMP. : 350±10℃ FOR 5±1s ②NO DAMAGE OF ELECTRICAL PERFORMANCE SOLDER DIPPING TEMPERATURE 245±5℃ A NEW UNIFORM COATING OF SOLDER (TEST STANDARD : MIL-STD-202) SHALL COVER A MINIMUM OF 95% OF FOR IMMERSION DURATION, 3±0.3 sec. THE SURFACE BEING IMMERSED. (note 1) FOLLOW THE SPECIFICATIONS OF FPC/FFC IF IT’S ALLOWABLE MAXIMUM OPERATING TEMPERATURE IS BELOW 105℃ 1 (note 2) 1 (note 3) WHEN THE SAME VALUE OF CURRENT ARE APPLIED TO ALL CONTACTS AT THE SAME TIME IN ONCE, SET THE CURRENT TO THE 70% OF THE RATED CURRENT VALUE. THERE’S A CASE WHICH FPC/FFC RETENTION FORCE DOESN’T FULFILL THE VALUE, BECAUSE FPC/FFC SPECIFICATION AFFECTS THE RESULT OF FPC/FFC RETENTION FORCE. DRAWN DESIGNED CONDITIONS FOR TESTING REMARKS B.J KIM UNLESS OTHERWISE SPECIFIED, REFER TO JIS C 5402. NOTE QT: QUALIFICATION TEST CL 18.03.02 APPROVED D.H CHO H.C SONG ENG 18.03.02 18.10.04 DEPT 18.03.02 AT: ASSURANCE TEST O: APPLICABLE TEST HIROSE KOREA CO.,LTD. CODE NO.(OLD) 18.03.02 B.J KIM RELEASED CHECKED SPECIFICATION SHEET DRAWING NO. ELC4-632346 CODE NO. PART NO. TF31-**S-0.5SH (800) CL 6535-****-*-800 F-1-021(Rev.0) 1 1
TF31-8S-0.5SH(800) 价格&库存
很抱歉,暂时无法提供与“TF31-8S-0.5SH(800)”相匹配的价格&库存,您可以联系我们找货
TF31-8S-0.5SH(800)
    • 1+0.92169
    • 10+0.90786
    • 100+0.72412
    库存:2947
    TF31-8S-0.5SH(800)
