SS310BF
SS310BF
    SK(時科)
    SMBF
    特性:金属硅结,多数载流子传导。 适用于表面贴装应用。 低功耗,高效率。 高正向浪涌电流能力。 适用于低电压、高频逆变器、续流和极性保护应用
SS310BF 数据手册
Surface Mount Schottky Barrier Rectifier Reverse Voltage - 20 to 200V Forward Current - 3.0A FEATURES • Metal silicon junction, majority carrier conduction • For surface mounted applications • Low power loss, high efficiency • High forward surge current capability • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications MECHANICAL DATA • Case: SMBF • Terminals: Solderable per MIL-STD-750, 750, Method 2026 • Approx. Weight: 57 mg / 0.002oz Absolute Maximum Ratings and Electrical characteristics Ratings at 25 °C C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,for capacitive load, derate by 20 % 1) Measured at 1MHz and applied reverse voltage of 4 V D.C. 2) P.C.B. mounted with 0.5 X 0.5" (12.7 X 12.7 mm) copper pad areas. 1 of 3 2 of 3 PACKAGE OUTLINE Plastic surface mounted package; 2 leads SMBF 3 of 3
SS310BF 价格&库存
很抱歉,暂时无法提供与“SS310BF”相匹配的价格&库存,您可以联系我们找货
SS310BF
    • 5000+0.18266
    库存:39000
