SRM6828S00D01GE000P00CH
    SOLIDRUN
SRM6828S00D01GE000P00CH 数据手册
Marvell ARMADA ClearFog Base Carrier Board for ARMADA SOM (System-On-Module) Rev 1.2 Simple. Robust. Computing Solutions 1 | Page SolidRun Ltd. 7 Hamada st., Yokne’am Illit, 2495900, Israel. www.solid-run.com Document revision 1.0 28082017 SolidRun Ltd. 2017 Overview Introducing the ClearFog family, a flexible IoT gateway platform which harnesses the full potential and robust processing power of the ARMADA SoC – providing a modular powerful board with endless possibilities. With the ARMADA processor at its core, the ClearFog offers both optimal modulation and fast processing speeds, cutting development costs, TTM and simplifying production process. ClearFog Base Highlighted Features Based on Marvell’s ARMADA A388 SoC Up to 2GB memory size Optimized for networking, routing and storage applications Feature rich Broad SW support 2 | Page Document revision 1.0 28082017 SolidRun Ltd. 2017 System Specifications ClearFog Base SOM Model ARMADA based A388 Memory and Storage 1GB (up to 2GB) M.2** Connectivity uSD / 8GB eMMC* (Optional) Power 1× mPCIE 1×USB 3.0 port 2×Port dedicated Ethernet 1×SFP mikroBUS Indication LEDs User Push Buttons PoE expansion header RTC Battery header FTDI (Console Only)/ Debug Header Wide range 9V- 32V Software Linux Kernel 3.x and 4.x, OpenWrt, Yocto Dimensions (WxL) 103mm×75mm Enclosure Optional Metal Enclosure I/O and Misc (*) Assembly option on the SOM. (**)M.2 includes USB 3.0, SATA, GNSS, 3G modules support 3 | Page Document revision 1.0 28082017 SolidRun Ltd. 2017 Interfaces Top View 4 | Page Document revision 1.0 28082017 SolidRun Ltd. 2017 Interfaces Bottom View 5 | Page Document revision 1.0 28082017 SolidRun Ltd. 2017 Available SKUs for ClearFog Base Carrier SKU Description SRCFCBE000CV12 ClearFog Base|Com. Temp|R1.2 SRCFCBE000IV12 ClearFog Base|Ind. Temp|R1.2 Safety Notice a. This device is to be used with Certified Power adaptor with output rated 12VDC, 1.5A. Power adapter must meet Limited power source (LPS) requirements. b. Power adapter must meet local safety standards and requirements based on product intended use. c. Power adapter must meet Operating environment conditions as specified above. Disposal Follow local regulations regarding disposal of the product. Dispose of your product in accordance with local regulations. In some areas, the disposal of these items in household or business trash may be prohibited. Help us protect the environment- recycle! IMPORTANT NOTICE – Please Read Carefully No warranty of accuracy is given concerning the contents of the information contained in this document. To the extent permitted by law no liability (including liability to any person by reason of negligence) will be accepted by SolidRun ltd. Or its employees for any direct or indirect loss or damage caused by omissions from or inaccuracies in this document. SolidRun ltd. Reserves the right to change details in this publication without notice Product and company names herein may be the trademarks of their respective owners. Information in this document supersedes and replaces information previously supplied in any prior versions of this document. 6 | Page Document revision 1.0 28082017 SolidRun Ltd. 2017 Support For technical support please visit: Our Wiki – http://wiki.solid-run.com/ Our Forums - http://forum.solid-run.com/ For direct support please contact us at: support@solid-run.com Documentation Additional documentation available at: http://wiki.solid-run.com/doku.php?id=products:a38x:documents 7 | Page Document revision 1.0 28082017 SolidRun Ltd. 2017
SRM6828S00D01GE000P00CH 价格&库存
很抱歉,暂时无法提供与“SRM6828S00D01GE000P00CH”相匹配的价格&库存,您可以联系我们找货
  • 1+1581.461581+204.70372
