RC0603FR-1033KL
RC0603FR-1033KL
    YAGEO(国巨)
    RC0603FR-1033KL
RC0603FR-1033KL 数据手册
DATA SHEET GENERAL PURPOSE CHIP RESISTORS RC_L series ±0.1%, ±0.5%, ±1%, ±5% Sizes 0075/0100/0201/0402/0603/0805/ 1206/1210/1218/2010/2512 Product specification – August 03, 2022 V.12 RoHS compliant & Halogen free Product specification Chip Resistor Surface Mount SCOPE This specification describes RC series chip resistors with lead free terminations made by thick film process. RC_L SERIES 2 10 0075 to 2512 ORDERING INFORMATION - GLOBAL PART NUMBER Global part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. GLOBAL PART NUMBER RC XXXX X X X XX XXXX L (1) APPLICATIONS  All general purpose application (2) (3) (4) (5) (6) (7) (1) SIZE 0075/0100/0201/0402/0603/0805/1206/1210/1218/2010/2512 FEATURES  Halogen Free Epoxy  RoHS compliant  Products with lead free terminations meet RoHS requirements  Pb-glass contained in electrodes, resistors element and glass are exempted by RoHS  Reducing environmentally hazardous wastes  High component and equipment reliability  Saving of PCB space  None forbidden-materials used in products/production (2) TOLERANCE B = ± 0.1% D = ± 0.5% F = ± 1.0% J = ± 5.0% (for jumper ordering, use code of J) (3) PACKAGING TYPE R = Paper taping reel K = Embossed taping reel S = ESD safe reel (0075/0100 only) (4) TEMPERATURE COEFFICIENT OF RESISTANCE - = Based on spec. (5) TAPING REEL & POWER 07 = 7 inch dia. Reel 10=10 inch dia. Reel 13 =13 inch dia. Reel 7W = 7 inch dia. Reel & 2 x standard power 7N = 7 inch dia. Reel, ESD safe reel (0075/0100 only) 3W = 13 inch dia. Reel & 2 x standard power (6) RESISTANCE VALUE There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point Example: 97R6 = 97.6Ω 9K76 = 9760Ω 1M = 1,000,000Ω (7) DEFAULT CODE Letter L is the system default code for ordering only.(Note) ORDERING EXAMPLE The ordering code for a RC0402 0.0625W chip resistor value 100KΩwith ±5% tolerance, supplied in 7-inch tape reel of 10,000 units per reel is: RC0402JR-07100KL. NOTE 1. All our RSMD products meet RoHS compliant and Halogen Free. "LFP" of the internal 2D reel label mentions "Lead Free Process". 2. On customized label, "LFP" or specific symbol can be printed. www.yageo.com Aug. 3, 2022 V.12 Product specification Chip Resistor Surface Mount RC_L SERIES 3 10 0075 to 2512 MARKING RC0075 / RC0100 / RC0201 / RC0402 No Marking ynsc007 Fig. 1 RC0603 0 1%, 0.5%,E24 exception values 10/11/13/15/20/75 of E24 series YNSC037 Fig. 2 240 = 24 × 100 = 24 88 YNSC038 1%, 0.5%, E96 refer to EIA-96 marking method, including values 10/11/13/15/20/75 of E24 series Fig. 3 88A = 806 × 100 = 806 Ω 03 YNSC001 5%, E24 series : 3 digits First two digits for significant figure and 3rd digit for number of zeros Fig. 4 Value = 10 KΩ RC0805 / RC1206 / RC1210 / RC2010 / RC2512 00 YNSC004 1%, 0.5%, E24/E96 series : 4 digits First three digits for significant figure and 4th digit for number of zeros Fig. 5 Value = 10 KΩ 03 YNSC001 5%, E24 series : 3 digits First two digits for significant figure and 3rd digit for number of zeros Fig. 6 Value = 10 KΩ RC1218 YNSC099 E-24 series: 3 digits, ± 5% First two digits for significant figure and 3rd digit for number of zeros Fig. 7 Value = 10 KΩ 00 YNSC103 Both E-24 and E-96 series: 4 digits, ± 1% & ± 0.5% First three digits for significant figure and 4th digit for number of zeros Fig. 8 Value = 10 KΩ For further marking information, please see special data sheet "Chip resistors marking". www.yageo.com Aug. 3, 2022 V.12 Product specification Chip Resistor Surface Mount RC_L 4 10 0075 to 2512 SERIES Outlines CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added on each end to make the contacts to the thick film resistive element. The composition of the resistive element is a noble metal imbedded into a glass and covered by a second glass to prevent environmental influences. The resistor is laser trimmed to the rated resistance value. The resistor is covered with a protective epoxy coat, finally the two external terminations (matte tin on Ni-barrier) are added, as shown in Fig.9. For dimensions, please refer to Table 1 marking layer overcoat primary glass layer resistive layer (Jumper chip is a conductor) inner electrode termination(Ni/matte tin) inner electrode H ceramic substrate I2 overcoat I1 W YNSC086 L 9 Fig. 9 Chip resistor outlines DIMENSION Table 1 TYPE RC0075 L (mm) W (mm) H (mm) I1 (mm) I2 (mm) 0.30±0.01 0.15±0.01 0.13±0.01 0.08±0.03 0.08±0.03 RC0100 0.40±0.02 0.20±0.02 0.13±0.02 0.10±0.03 0.10±0.03 RC0201 0.60±0.03 0.30±0.03 0.23±0.03 0.10±0.05 0.15±0.05 RC0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.25±0.10 RC0603 1.60±0.10 0.80±0.10 0.45±0.10 0.25±0.15 0.25±0.15 RC0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.35±0.20 RC1206 3.10±0.10 1.60±0.10 0.55±0.10 0.45±0.20 0.45±0.20 RC1210 3.10±0.10 2.60±0.15 0.55±0.10 0.45±0.15 0.50±0.20 RC1218 3.10±0.10 4.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 RC2010 5.00±0.10 2.50±0.15 0.55±0.10 0.60±0.20 0.55±0.20 RC2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.20 0.60±0.20 ELECTRICAL CHARACTERISTICS Table 2 CHARACTERISTICS POWER OPERATING TEMPERATURE RANGE -55℃ to 125℃ RC0075 1/50 outlines W Fig. 4 Chip resistor MAXIMUM WORKING VOLTAGE 10V MAXIMUM DIELECTRIC OVERLOAD WITHSTANDING VOLTAGE VOLTAGE 25V 25V RESISTANCE RANGE TEMPERATURE COEFFICIENT JUMPER CRITERIA 5% (E24) 10Ω≦R
RC0603FR-1033KL
物料型号:文档描述的是YAGEO品牌的RC_L系列通用芯片电阻,包括多种尺寸,如0075、0100、0201、0402、0603、0805、1206、1210、1218、2010和2512。
器件简介:RC_L系列芯片电阻采用厚膜工艺制造,具有无铅端子,符合RoHS标准和无卤要求,适用于所有通用目的应用。
引脚分配:文档中没有明确提到具体的引脚分配,但提到了电阻器的构造,包括陶瓷基板、内部金属电极、厚膜电阻元件、覆盖玻璃和外部端子。
参数特性:电阻值公差有±0.1%、±0.5%、±1%和±5%可选。产品具有高组件和设备可靠性、节省PCB空间、无禁用材料等特点。
功能详解:文档详细介绍了电阻器的构造,包括电阻元件的组成、激光修调至额定电阻值、保护性环氧涂层以及外部端子的添加。
应用信息:适用于所有通用目的应用,包括减少环境有害废物、提高组件和设备可靠性、节省PCB空间。
封装信息:文档提供了详细的封装尺寸信息,包括长度、宽度、高度、内径和外径的尺寸数据。
RC0603FR-1033KL 价格&库存
很抱歉,暂时无法提供与“RC0603FR-1033KL”相匹配的价格&库存,您可以联系我们找货
RC0603FR-1033KL
  • 10000+0.0365010000+0.00473
  • 20000+0.0326420000+0.00423
  • 30000+0.0307630000+0.00399
  • 50000+0.0287450000+0.00373
  • 70000+0.0275770000+0.00358
  • 100000+0.02649100000+0.00344
库存:26110
RC0603FR-1033KL
  • 1+0.884871+0.11470
  • 10+0.2206910+0.02861
  • 25+0.1658925+0.02151
  • 50+0.1322050+0.01714
  • 100+0.10757100+0.01395
  • 250+0.08286250+0.01074
  • 500+0.06894500+0.00894
  • 1000+0.058281000+0.00756
  • 5000+0.041355000+0.00536
库存:26110
RC0603FR-1033KL
    库存:10000
    RC0603FR-1033KL
    • 10000+0.03754
    • 20000+0.03241
    • 30000+0.02965
    • 40000+0.02771
    • 50000+0.02633
    • 80000+0.02327
    • 100000+0.02188
    • 120000+0.02078
    • 160000+0.01981
    • 750000+0.01870
