TSM2314CX
TSM2314CX
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOT-23
TSM2314CX 数据手册
TSM2314 20V N-Channel MOSFET SOT-23 PRODUCT SUMMARY VDS (V) RDS(on)(mΩ) Pin Definition: 1. Gate 2. Source 3. Drain 20 Features ID (A) 33 @ VGS = 4.5V 4.9 40 @ VGS = 2.5V 4.4 100 @ VGS = 1.8V 2.9 Block Diagram ● Advance Trench Process Technology ● High Density Cell Design for Ultra Low On-resistance Application ● Load Switch ● PA Switch Ordering Information Part No. Package Packing TSM2314CX RFG SOT-23 3Kpcs / 7” Reel N-Channel MOSFET Note: “G” denotes Halogen Free Product. Absolute Maximum Rating (Ta = 25oC unless otherwise noted) Parameter Symbol Limit Unit Drain-Source Voltage VDS 20 V Gate-Source Voltage VGS ±12 V ID 4.9 A IDM 15 A IS 1.0 A Continuous Drain Current, VGS @4.5V. Pulsed Drain Current, VGS @4.5V Continuous Source Current (Diode Conduction) a,b o Ta = 25 C Maximum Power Dissipation 1.25 PD o Ta = 75 C Operating Junction Temperature W 0.8 TJ +150 °C TJ, TSTG -55 to +150 °C Symbol Limit Unit Junction to Case Thermal Resistance RӨJC 75 °C/W Junction to Ambient Thermal Resistance (PCB mounted) RӨJA 120 °C/W Operating Junction and Storage Temperature Range Thermal Performance Parameter Notes: a. Pulse width limited by the Maximum junction temperature b. Surface Mounted on FR4 Board, t ≤ 5 sec. Document Number: DS_P0000056 1 Version: E15 TSM2314 20V N-Channel MOSFET Electrical Specifications (Ta = 25oC unless otherwise noted) Parameter Conditions Symbol Min Typ Max Unit Static Drain-Source Breakdown Voltage VGS = 0V, ID = 250µA BVDSS 20 -- -- V Gate Threshold Voltage VDS = VGS, ID = 250µA VGS(TH) 0.6 0.85 1.2 V Gate Body Leakage VGS = ±4.5V, VDS = 0V IGSS -- -- ±1.5 µA Zero Gate Voltage Drain Current VDS = 16V, VGS = 0V IDSS -- -- 1.0 µA On-State Drain Current VDS ≥ 10V, VGS = 4.5V ID(ON) 15 -- -- A -- 27 33 -- 33 40 -- 80 100 VGS = 4.5V, ID = 4.9A Drain-Source On-State Resistance VGS = 2.5V, ID = 4.4A RDS(ON) VGS = 1.8V, ID = 2.9A mΩ Forward Transconductance VDS = 15V, ID = 5.0A gfs -- 40 -- S Diode Forward Voltage b Dynamic IS = 1.0A, VGS = 0V VSD -- 0.8 1.2 V Qg -- 11 14 Qgs -- 1.5 -- Qgd -- 2.1 -- Ciss -- 900 -- Coss -- 140 -- Crss -- 100 -- td(on) -- 0.53 0.8 tr -- 1.4 2.2 td(off) -- 13.5 20 -- 5.9 9 Total Gate Charge Gate-Source Charge Gate-Drain Charge Input Capacitance Output Capacitance Reverse Transfer Capacitance Switching VDS = 10V, ID = 5.0A, VGS = 4.5V VDS = 10V, VGS = 0V, f = 1.0MHz nC pF c Turn-On Delay Time Turn-On Rise Time Turn-Off Delay Time VDD = 10V, RL = 10Ω, ID = 1A, VGEN = 4.5V, RG = 6Ω Turn-Off Fall Time tf Notes: a. pulse test: PW ≤300µS, duty cycle ≤2% b. For DESIGN AID ONLY, not subject to production testing. c. Switching time is essentially independent of operating temperature. Document Number: DS_P0000056 2 nS Version: E15 TSM2314 20V N-Channel MOSFET Electrical Characteristics Curve (Ta = 25\oC, unless otherwise noted) Output Characteristics Transfer Characteristics On-Resistance vs. Drain Current Gate Charge On-Resistance vs. Junction Temperature Source-Drain Diode Forward Voltage Document Number: DS_P0000056 3 Version: E15 TSM2314 20V N-Channel MOSFET Electrical Characteristics Curve (Ta = 25oC, unless otherwise noted) On-Resistance vs. Gate-Source Voltage Threshold Voltage Single Pulse Power Normalized Thermal Transient Impedance, Junction-to-Ambient Document Number: DS_P0000056 4 Version: E15 TSM2314 20V N-Channel MOSFET SOT-23 Mechanical Drawing DIM A A1 B C D E F G H I J SOT-23 DIMENSION MILLIMETERS INCHES MIN MAX MIN MAX. 0.95 BSC 0.037 BSC 1.9 BSC 0.074 BSC 2.60 3.00 0.102 0.118 1.40 1.70 0.055 0.067 2.80 3.10 0.110 0.122 1.00 1.30 0.039 0.051 0.00 0.10 0.000 0.004 0.35 0.50 0.014 0.020 0.10 0.20 0.004 0.008 0.30 0.60 0.012 0.024 5º 10º 5º 10º Marking Diagram 14 = Device Code Y = Year Code M = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr S =May T =Jun U =Jul V =Aug W =Sep X =Oct Y =Nov Z =Dec L = Lot Code Document Number: DS_P0000056 5 Version: E15 TSM2314 20V N-Channel MOSFET Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Document Number: DS_P0000056 6 Version: E15
TSM2314CX 价格&库存
很抱歉,暂时无法提供与“TSM2314CX”相匹配的价格&库存,您可以联系我们找货
