WIMA MKS 2
Metallized Polyester (PET) Capacitors in PCM 5 mm.
Capacitances from 0.01 F to 4.7 F. Rated Voltages from 63 VDC to 630 VDC.
Special Features
Electrical Data
O High volume/capacitance ratio
O Self-healing
O AEC-Q200 qualified
O According to RoHS 2015/863/EU
Typical Applications
For general DC-applications e.g.
O By-pass
O Blocking
O Coupling and decoupling
O Timing
Construction
Capacitance range:
0.01 F to 4.7 F (E12-values on request)
Rated voltages: 63 VDC 100 VDC,
250 VDC, 400 VDC, 630 VDC
Capacitance tolerances:
±20%, ±10%, ±5%
Operating temperature range:
–55° C to +125° C
Climatic test category:
55/100/21 in accordance with IEC
Test specifications:
In accordance with IEC 60384-2
Insulation resistance at +20° C:
Test voltage: 1.6 Ur, 2 sec.
Voltage derating:
A voltage derating factor of 1.25 % per K
must be applied from +85° C for DC
voltages and from +75° C for AC
voltages
Reliability:
Operational life 300 000 hours (+125° C
permitted for 1000 hours max. distributed
over the entire operating life)
Failure rate 2 fit (0.5 x Ur and 40° C)
Ur Utest C 0.33 F 0.33 F < C T 4.7 F
Dielectric:
Polyethylene-terephthalate (PET) film
Capacitor electrodes:
Vacuum-deposited
Internal construction:
Plastic film
Vacuum-deposited
electrode
Metal contact layer
(schoopage)
Terminating wire
Encapsulation:
Solvent-resistant, flame-retardant plastic
case with epoxy resin seal, UL 94 V-0
Terminations:
Tinned wire.
Marking: Colour: Red.
Marking: Black.
1 x 104 MΩ
63 VDC 50 V
U100 VDC
100 V
1.5 x
104
1250 sec (MΩ x F)
MΩ
3000 sec (MΩ x F)
Measuring time: 1 min.
Dissipation factors at + 20° C: tan
at f
1 kHz
10 kHz
100 kHz
C 0.1 F 0.1 F < C T 1.0 F
C > 1.0 F
8 x 10-3
8 x 10-3
10 x 10-3
15 x 10-3
15 x 10-3 –
30 x 10-3 –
Maximum pulse rise time:
Capacitance
F
63 VDC
0.01 ... 0.022
0.033 ... 0.068
0.1 ... 0.47
0.68 ... 1.0
1.5 ... 3.3
4.7
35
12
7.5
5
max. pulse rise time V/sec
100 VDC 250 VDC 400 VDC
35
25
10
5
Mechanical Tests
80
80
80
630 VDC
110
90
80
Packing
Available taped and reeled.
Detailed taping information and graphs
at the end of the catalogue.
For further details and graphs please
refer to Technical Information.
03.26
Pull test on pins:
10 N in direction of pins according to
IEC 60068-2-21
Vibration:
6 hours at 10 ... 2000 Hz and 0.75 mm
displacement amplitude or 10 g in
accordance with IEC 60068-2-6
Low air density:
1kPa = 10 mbar in accordance with
IEC 60068-2-13
Bump test:
4000 bumps at 390 m/sec2 in
accordance with IEC 60068-2-29
50
50
50
25
34
WIMA
WIMA MKS
FKP 42
Continuation
General Data
Capacitance
W
0.01 F
0.015 „
0.022 „
0.033 „
0.047 „
0.068 „
2.5 6.5
2.5 6.5
2.5 6.5
2.5 6.5
2.5 6.5
2.5 6.5
7.2
7.2
7.2
7.2
7.2
7.2
5
5
5
5
5
5
MKS2C021001A00_ _ _ _
MKS2C021501A00_ _ _ _
MKS2C022201A00_ _ _ _
MKS2C023301A00_ _ _ _
MKS2C024701A00_ _ _ _
MKS2C026801A00_ _ _ _
2.5
6.5 7.2
2.5
6.5 7.2
2.5
6.5 7.2
2.5
6.5 7.2
2.5
6.5 7.2
2.5
6.5 7.2
5
5
5
5
5
5
MKS2D021001A00_ _ _ _
MKS2D021501A00_ _ _ _
MKS2D022201A00_ _ _ _
MKS2D023301A00_ _ _ _
MKS2D024701A00_ _ _ _
MKS2D026801A00_ _ _ _
0.1 F
0.15 „
0.22 „
0.33 „
0.47 „
0.68 „
2.5 6.5
2.5 6.5
3 7.5
3.5 8.5
3.5 8.5
4.5 9.5
7.2
7.2
7.2
7.2
7.2
7.2
5
5
5
5
5
5
MKS2C031001A00_ _ _ _
MKS2C031501A00_ _ _ _
MKS2C032201B00_ _ _ _
MKS2C033301C00_ _ _ _
MKS2C034701C00_ _ _ _
MKS2C036801E00_ _ _ _
2.5
6.5 7.2
3.5
8.5 7.2
3.5
8.5 7.2
4.5
9.5 7.2
4.5
9.5 7.2
5 10 7.2
5
5
5
5
5
5
MKS2D031001A00_ _ _ _
MKS2D031501C00_ _ _ _
MKS2D032201C00_ _ _ _
MKS2D033301E00_ _ _ _
MKS2D034701E00_ _ _ _
MKS2D036801F00_ _ _ _
1.0
1.5
2.2
3.3
4.7
5 10
5.5 11.5
7.2 13
11 16
11 18
7.2
7.2
7.2
7.2
7.2
5
5
5
5
5
MKS2C041001F00_ _ _ _
MKS2C041501H00_ _ _ _
MKS2C042201K00_ _ _ _
MKS2C043301N00_ _ _ _
MKS2C044701O00_ _ _ _
7.2 13 7.2
8.5 14 7.2
11 16 7.2
11 16 7.2
11 18 7.2
5
5
5
5
5
MKS2D041001K00_ _ _ _
MKS2D041501M00_ _ _ _
MKS2D042201N00_ _ _ _
MKS2D043301N00_ _ _ _
MKS2D044701O00_ _ _ _
F
H
L
63 VDC/40 VAC*
PCM**
Part number
W
100 VDC/63 VAC*
L PCM**
Part number
Capacitance
W
0.01
0.015
0.022
0.033
0.047
0.068
F
2.5 6.5
2.5 6.5
2.5 6.5
3.5 8.5
3.5 8.5
3.5 8.5
7.2
7.2
7.2
7.2
7.2
7.2
5
5
5
5
5
5
MKS2F021001A00_ _ _ _
MKS2F021501A00_ _ _ _
MKS2F022201A00_ _ _ _
MKS2F023301C00_ _ _ _
MKS2F024701C00_ _ _ _
MKS2F026801C00_ _ _ _
2.5
6.5 7.2
2.5
6.5 7.2
3.5
8.5 7.2
4.5
9.5 7.2
4.5
9.5 7.2
5.5 11.5 7.2
5
5
5
5
5
5
MKS2G021001A00_ _ _ _
MKS2G021501A00_ _ _ _
MKS2G022201C00_ _ _ _
MKS2G023301E00_ _ _ _
MKS2G024701E00_ _ _ _
MKS2G026801H00_ _ _ _
0.1 F
0.15 „
0.22 „
0.33 „
0.47 „
0.68 „
4.5 9.5
5 10
5.5 11.5
7.2 13
8.5 14
11 16
7.2
7.2
7.2
7.2
7.2
7.2
5
5
5
5
5
5
MKS2F031001E00_ _ _ _
7.2 13 7.2
MKS2F031501F00_ _ _ _
8.5 14 7.2
MKS2F032201H00_ _ _ _ 11 16 7.2
MKS2F033301K00_ _ _ _ 11 18 7.2
MKS2F034701M00_ _ _ _ 11 18 7.2
MKS2F036801N00_ _ _ _
5
5
5
5
5
MKS2G031001K00_ _ _ _
MKS2G031501M00_ _ _ _
MKS2G032201N00_ _ _ _
MKS2G033301O00_ _ _ _
MKS2G034701O00_ _ _ _
1.0 F
11 18 7.2
5
MKS2F041001O00_ _ _ _
H
250 VDC/160 VAC*
L PCM**
Part number
H
W
H
400 VDC/200 VAC*
L PCM**
Part number
* AC voltage: f 50 Hz; 1.4 x Urms + UDC Ur
New values and box sizes.
** PCM = Printed circuit module = pin spacing.
W
Dims. in mm.
L
H
d = 0.5 Ø
6 -2
d
5
PCM
at the pin exit points
(± 0.5)
Part number completion:
Tolerance: 20 % = M
10 % = K
5 % = J
Packing:
bulk = S
Pin length: 6-2 = SD
Taped version see page 133.
Rights reserved to amend design data without prior notification.
03.26
Continuation page 36
35
WIMA
WIMA MKS
FKP 42
Continuation
General Data
Capacitance
0.01
0.015
0.022
0.033
0.047
0.068
F
0.1 F
W
H
630 VDC/220 VAC*
L PCM**
Part number
4.5 9.5 7.2
5.0 10 7.2
5.5 11.5 7.2
7.2 13 7.2
8.5 14 7.2
11 16 7.2
5
5
5
5
5
5
MKS2J021001E00_ _ _ _
MKS2J021501F00_ _ _ _
MKS2J022201H00_ _ _ _
MKS2J023301K00_ _ _ _
MKS2J024701M00_ _ _ _
MKS2J026801N00_ _ _ _
11 18 7.2 5
MKS2J031001O00_ _ _ _
Impedance change with frequency
(general guide).
Dims. in mm.
W
L
H
6 -2
d = 0.5 Ø
d
5
PCM
(± 0.5)
Tolerance: 20 % = M
10 % = K
5 % = J
Packing:
bulk = S
03.26
Permissible AC voltage in relation to
frequency at 10° C internal temperature
rise (general guide).
36
Recommendation for Processing
and Application of
Through-Hole Capacitors
Soldering Process
Internal temperature of the capacitor must
be kept as follows:
Polyester:
preheating: Tmax. T125° C
soldering: Tmax. T135° C
Polypropylene: preheating: Tmax. T100° C
soldering: Tmax. T110° C
Single wave soldering
Soldering bath temperature: T P 260 ° C
Dwell time:
t P 5 sec
Double wave soldering
Dwell time:
∑t P 5 sec
Due to different soldering processes and
heat requirements the graphs are to be
regarded as a recommendation only.
WIMA Quality and Environmental Philosophy
ISO 9001:2015 Certification
ISO 9001:2015 is an international basic
standard of quality assurance systems
for all branches of industry. The approval according to ISO 9001:2015 of
our factories certifies that organisation,
equipment and monitoring of quality
assurance in our factories correspond to
internationally recognized standards.
WIMA WPCS
The WIMA Process Control System (WPCS)
is a quality surveillance and optimization
system developed by WIMA. WPCS is a
major part of the quality-oriented WIMA
production. Points of application during
production process:
All WIMA capacitors, irrespective of
whether through-hole devices or SMD,
are made of environmentally friendly
materials. Neither during manufacture
nor in the product itself any toxic substances are used, e.g.
– Lead – PBB/PBDE
– PCB
– Arsenic
– CFC – Cadmium
– Hydrocarbon chloride – Mercury
– Chromium 6+
– etc.
We merely use pure, recyclable materials
for packing our components, such as:
carton
cardboard
adhesive tape made of paper
polystyrene
We almost completely refrain from using
packing materials such as:
! adhesive tapes made of plastic
! metal clips
RoHS Compliance
According to the RoHS Directive 2015/863/EU
as amended from time to time certain
hazardous substances like e.g. lead, cadmium,
mercury must not be used any longer in
electronic equipment as of July 1st, 2006.
For the sake of the environment WIMA has
re-fraind from using such substances since
years already.
WIMA Kondensatoren sind bleifrei
konform RoHS 2015/863/EU
WIMA capacitors are lead free
in accordance with RoHS 2015/863/EU
Tape for lead-free WIMA capacitors
DIN EN ISO 14001:2004
WIMA’s environmental management has
been established in accordance with the
guidelines of DIN EN ISO 14001:2004
to optimize the production processes
with regard to energy and resources.
03.26
! incoming material inspection
! metallization
! film inspection
! schoopage
! pre-healing
! pin attachment
! cast resin preparation/encapsu lation
! 100% final inspection
! Testing as per customer require ments
WIMA Environmental Policy
14
Typical Dimensions for
Taping Configuration
Vh
P
P2
Diagram 1:
PCM 2.5/5/7.5mm
W
W1
W0
H
H1
W2
P1
D0
d
P
t
F
P0
H1
P
P1
H
P1
d
d
F
P0
P2
Diagram 2: PCM 10/15 mm
Diagram 3: PCM 22.5 and 27.5*mm
*PCM 27.5 taping possible with two feed holes between components
Designation
Carrier tape width
Dimensions for Radial Taping
Symbol PCM 2.5 taping
W
P0
P2
F
PCM 5 taping
PCM 7.5 taping
PCM 10 taping*
PCM 15 taping*
PCM 22.5 taping
PCM 27.5 taping
18.0 ±0.5 18.0 ±0.5 18.0 ±0.5 18.0 ±0.5 18.0 ±0.5 18.0 ±0.5 18.0 ±0.5
for hot-sealing
for hot-sealing
for hot-sealing
for hot-sealing
for hot-sealing
for hot-sealing
for hot-sealing
Hold-down tape width
W0 6.0
6.0
12.0
12.0
12.0
12.0
12.0
adhesive tape adhesive tape adhesive tape adhesive tape adhesive tape adhesive tape adhesive tape
Hole position
W1 9.0 ±0.5 9.0 ±0.5 9.0 ±0.5 9.0 ±0.5 9.0 ±0.5 9.0 ±0.5 9.0 ±0.5
Hold-down tape position
W2
Feed hole diameter
D0 4.0 ±0.2 4.0 ±0.2 4.0 ±0.2 4.0 ±0.2 4.0 ±0.2 4.0 ±0.2 4.0 ±0.2
*38.1 ±1.5 or 50.8 ±1.5
P
12.7 ±1.0 12.7 ±1.0 12.7 ±1.0 25.4 ±1.0 25.4 ±1.0 38.1 ±1.5
0.5 to 3.0 max.
0.5 to 3.0 max.
Pitch of component
cumulative pitch
Feed hole pitch
P0 12.7
±0.3 error max.
12.7 ±0.3
1.0 mm/20 pitch
0.5 to 3.0 max.
cumulative pitch
error max.
1.0 mm/20 pitch
12.7 ±0.3
0.5 to 3.0 max.
cumulative pitch
error max.
1.0 mm/20 pitch
12.7 ±0.3
cumulative pitch
error max.
1.0 mm/20 pitch
0.5 to 3.0 max.
12.7 ±0.3
0.5 to 3.0 max.
cumulative pitch
error max.
1.0 mm/20 pitch
12.7 ±0.3
cumulative pitch
error max.
1.0 mm/20 pitch
0.5 to 3.0 max.
12.7 ±0.3
cumulative pitch
error max.
1.0 mm/20 pitch
Feed hole centre
to pin
P1 5.1 ±0.5 3.85 ±0.7 2.6 ±0.7 7.7 ±0.7 5.2 ±0.7 7.8 ±0.7 5.3 ±0.7
Hole centre to
component centre
P2 6.35 ±1.3 6.35 ±1.3 6.35 ±1.3 12.7 ±1.3 12.7 ±1.3 19.05 ±1.3 19.05 ±1.3
Feed hole centre to bottom
H▲
edge of the component
16.5 ±0.3 16.5 ±0.3 16.5 ±0.5 16.5 ±0.5 16.5 ±0.5 16.5 ±0.5 16.5 ±0.5
18.5 ±0.5 18.5 ±0.5 18.5 ±0.5 18.5 ±0.5 18.5 ±0.5 18.5 ±0.5 18.5 ±0.5
Feed hole centre to top
H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1
H
edge of the component 1
32.25 max.
32.25 max.
24.5 to 31.5
25.0 to 31.5
26.0 to 37.0
30.0 to 43.0
35.0 to 45.0
Pin spacing at
+0.8
F 2.5 ±0.5 5.0
7.5 ±0.8 10.0 ±0.8 15 ±0.8 22.5 ±0.8 27.5 ±0.8
upper edge of carrier tape –0.2
Pin diameter
d
Component alignment
∆h
Total tape thickness
t
0.4 ±0.05 0.5 ±0.05
± 2.0 max.
± 2.0 max.
+0.06
± 3.0 max.
± 3.0 max.
03.26
+0.08
+0.08
± 3.0 max.
± 3.0 max.
± 3.0 max.
AMMO
52 ±2
max.
REEL Ø 360 max. B 58 ±2 or REEL ØØ 500
25 ±1
Ø 30 ±1 66 ±2
Unit
+0.08
0.6 ±0.2 0.6 ±0.2 0.6 ±0.2 0.6 ±0.2 0.6 ±0.2 0.6 ±0.2 0.6 ±0.2
ROLL/AMMO
Package
52 ±2 depending on
Ø 360 max.
(see also page 134)
B
REEL
Ø 30 ±1 58 ±2 comp. dimensions
+0.06
0.5 ±0.05 or 0.6–0.05 $0.5 ±0.05 or 0.6 –0.05 0.8
–0.05 0.8
–0.05 0.8
–0.05
When ordering please specify dimension H and required packaging type.
$ Diameter of pins see General Data.
54 ±2
B 60 ±2
68 ±2
depending
on PCM
and component dimensions
see details page 135.
Dims in mm.
Please clarify customer-specific deviations with the manufacturer.
* PCM 10 and PCM 15 can be crimped to PCM 7.5.
Position of components according to PCM 7.5 (sketch 1). P0 = 12.7 or 15.0 is possible
133
Types of Tape Packaging of
Capacitors for Automatic
Radial Insertion
O REEL Packaging
340 max.
30±1
25±1
360 max.
500 max.
O AMMO Packaging
340 max.
370 max.
O ROLL Packaging
34
0m
ax.
50 max.
50 max.
70 max.
ax
0 m ax.
34 0 m
49
B
BAR CODE (Labelling)
Labelling of package units in
plain text and with
alphanumerical Bar Code
BARCODE PDF417
BARCODE 2D Datamatrix
! WIMA supplier number
! Date code
! Customer‘s P/O number
! P/O line
! Customer‘s part number
! WIMA part number
! Quantity
! WIMA confirmation number
! Country of origin
! Customer name
! Handling unit number
! Week of delivery.
In addition part description of
article
capacitance value
rated voltage
dimensions
technical note
capacitance tolerance
packing
connecting information
03.26
134
Packing Quantities for Capacitors with
Radial Pins in PCM 2.5 mm to 22.5 mm
Size
PCM
2.5 mm
5 mm
7.5 mm
10 mm
15 mm
22.5 mm
W
2.5
3
3.8
4.6
5.5
2.5
3
3.5
4.5
4.5
5
5.5
5.5
6.5
7.2
7.2
8.5
8.5
11
11
2.5
3
4
4.5
5
5.7
7.2
4
4
5
6
6
8
5
6
7
8
9
9
11
5
6
7
8.5
10.5
10.5
11
H
7
7.5
8.5
9
10
6.5
7.5
8.5
6
9.5
10
7
11.5
8
8.5
13
10
14
16
18
7
8.5
9
9.5
10.5
12.5
12.5
9
9.5
11
12
12.5
12
11
12.5
14
15
14
16
14
14
15
16.5
18.5
19
20.5
21
pcs. per packing unit
REEL
AMMO
Ø 360
Ø 500
340 x 340
490 x 370
H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5
N
O
F
I
H
J
A
C
B
D
2200
2500
2800
2000
2300
2300
1500
1800
1800
1200
1500
1500
900
1200
1200
2200
2500
2800
2000
2300
2300
1600
2000
2000
1300
1500
1500
1300
1500
1500
1100
1400
1400
1000
1200
1200
1000
1200
1200
800
1000
1000
700
1000
1000
700
950
1000
600
800
800
600
800
800
500
600
640
500
600
640
2500
4400
2500
2200
4300
2300
4150
1700
3200
1700
3000
1500
2900
1400
2700
1300
2500
1300
1000
2200
1100
900
1800
1000
900
1600
1450
900
1600
1400
700
1300
1100
550
1100
1000
550
1100
1000
400
800
740
600
1200
1150
500
1000
1000
450
900
850
400
800
740
350
700
650
350
700
650
300
600
540
800
770
700
640
600
550
480
450
400
360
400
360
380
350
ROLL
bulk
L
Codes
4.6
0B
4.6
0C
4.6
0D
4.6
0E
4.6
0F
7.2
1A
7.2
1B
7.2
1C
7.2
1D
7.2
1E
7.2
1F
7.2
1G
7.2
1H
7.2
1I
7.2
1J
7.2
1K
7.2
1L
7.2
1M
7.2
1N
7.2
1O
10
2A
10
2B
10
2C
10.3
2D
10.3
2E
10.3
2F
10.3
2G
13
3C
13
3D
13
3F
13
3G
13
3H
13
3I
18
4B
18
4C
18
4D
18
4F
18
4H
18
4J
18
4M
26.5
5A
26.5
5B
26.5
5D
26.5
5F
26.5
5G
26.5
5H
26.5
5I
S
5000
5000
5000
5000
5000
5000
5000
5000
6000
4000
3500
4000
2500
2500
2500
2000
2000
1500
1000
1000
5000
5000
4000
3500
3000
2000
1500
3000
3000
3000
2400
2400
2000
2400
2000
1600
1200
1200
900
1000
1200
1000
760
500
594*
594*
561*
03.26
* for 2-inch transport pitches.
* TPS (Tray-Packing-System). Plate versions may have different packing units.
Samples and pre-production needs on request.
135
Radial Pins in PCM 27.5 mm to 52.5 mm
Size
PCM
REEL
AMMO
Ø 360
Ø 500
340 x 340
490 x 370
N
O
F
I
H
J
A
C
B
D
460/340*
380/280*
300
270
ROLL
bulk
W
9
11
13
15
17
17
H
19
21
24
26
29
34.5
39.5
L
Codes
31.5
6A
31.5
6B
31.5
6D
31.5
6F
31.5
6G
31.5
6I
31.5
6J
S
567*
459*
378*
324*
198*
198*
162*
37.5 mm**
9
11
13
15
17
19
28
31
35
40
19
22
24
26
29
32
39.5
45.5
38
46
50
55
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
7A
7B
7C
7D
7E
7F
7G
7H
7L
7I
7J
7K
441*
357*
294*
252*
154*
140*
126*
112*
84*
84*
35*
28*
48.5 mm**
19
23
27
33
37
31
34
37.5
48
54
56
56
56
56
56
8D
8E
8H
8J
8L
120*
80*
84*
25*
25*
52.5 mm
25
30
35
45
45
45
45
50
55
65
57
57
57
57
57
9D
9E
9F
9H
9J
70*
60*
25*
20*
20*
27.5 mm
**For Snubber capacitors in 2-pin version the PCM is changing to 38.5 respective 49.5 mm.
03.26
Updated data on www.wima.com
136
WIMA Part Number System
A WIMA part number consists of 18 digits and is composed as follows:
Field 1 - 4: Type description
Field 5 - 6: Rated voltage
Field 7 - 10: Capacitance
Field 11 - 12: Size and PCM
Field 13 - 14: Version code (e.g. Snubber versions)
Field 15:
Field 16:
Packing
Field 17 - 18: Pin length (untaped)
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
M
K
S
2
C
1
A
M
S
S
D
20 %
bulk
MKS 2
03.26
Type description:
SMD-PET
= SMDT
SMD-PPS
= SMDI
MKS 02
= MKS0
FKS 2
= FKS2
FKP 2
= FKP2
MKS 2
= MKS2
MKP 2
= MKP2
MKS 4
= MKS4
MKP 4
= MKP4
MKP 10
= MKP1
FKP 1
= FKP1
MKP-X2
= MKX2
MKP-X1 R
= MKX1
MKP-Y2
= MKY2
Snubber MKP
= SNMP
Snubber FKP
= SNFP
GTO MKP
= GTOM
DC-LINK MKP 4 = DCP4
DC-LINK MKP 6 = DCP6
DC-LINK HC
= DCHC
63 VDC
Rated voltage:
63 VDC = C0
100 VDC = D0
250 VDC = F0
400 VDC = G0
450 VDC = H0
520 VDC = H2
600 VDC = I0
630 VDC = J0
700 VDC = K0
800 VDC = L0
850 VDC = M0
900 VDC = N0
1000 VDC = O1
1100 VDC = P0
1200 VDC = Q0
1250 VDC = R0
1500 VDC = S0
1600 VDC = T0
1700 VDC = TA
2000 VDC = U0
2500 VDC = V0
3000 VDC = W0
4000 VDC = X0
6000 VDC = Y0
230 VAC = 3Y
275 VAC = 1W
300 VAC = 2W
305 VAC = AW
350 VAC = BW
440 VAC = 4W
0.01 F
Capacitance:
22 pF
= 0022
47 pF
= 0047
100 pF = 0100
150 pF = 0150
220 pF = 0220
330 pF = 0330
470 pF = 0470
680 pF = 0680
1000 pF = 1100
1500 pF = 1150
2200 pF = 1220
3300 pF = 1330
4700 pF = 1470
6800 pF = 1680
0.01 F = 2100
0.022 F = 2220
0.047 F = 2470
0.1 F = 3100
0.22 F = 3220
0.47 F = 3470
= 4100
1 F
2.2 F = 4220
4.7 F = 4470
= 5100
10 F
= 5220
22 F
= 5470
47 F
100 F = 6100
220 F = 6220
1000 F = 7100
1500 F = 7150
2.5 x 6.5 x 7.2
Size:
4.8 x 3.3 x 3 Size 1812
4.8 x 3.3 x 4 Size 1812
5.7 x 5.1 x 3.5 Size 2220
5.7 x 5.1 x 4.5 Size 2220
7.2 x 6.1 x 3 Size 2824
7.2 x 6.1 x 5 Size 2824
10.2 x 7.6 x 5 Size 4030
12.7 x 10.2 x 6 Size 5040
15.3 x 13.7 x 7 Size 6054
2.5 x 7 x 4.6 PCM 2.5
3 x 7.5 x 4.6 PCM 2.5
2.5 x 6.5 x 7.2 PCM 5
3 x 7.5 x 7.2 PCM 5
2.5 x 7 x 10 PCM 7.5
3 x 8.5 x 10 PCM 7.5
3 x 9 x 13 PCM 10
4 x 9 x 13 PCM 10
5 x 11 x 18 PCM 15
6 x 12.5 x 18 PCM 15
5 x 14 x 26.5 PCM 22.5
6 x 15 x 26.5 PCM 22.5
9 x 19 x 31.5 PCM 27.5
11 x21 x 31.5 PCM 27.5
9 x 19 x 41.5 PCM 37.5
11 x 22 x 41.5 PCM 37.5
19 x 31 x 56 PCM 48.5
25 x 45 x 57 PCM 52.5
Version code:
Standard
Version A1
Version A1.1.1
Version A2
= 00
= 1A
= 1B
= 2A
= KA
= KB
= QA
= QB
= TA
= TB
= VA
= XA
= YA
= 0B
= 0C
= 1A
= 1B
= 2A
= 2B
= 3A
= 3C
= 4B
= 4C
= 5A
= 5B
= 6A
= 6B
= 7A
= 7B
= 8D
= 9D
6 -2
Tolerance:
±20 % = M
±10 % = K
±5 %
=J
±2.5 % = H
±1 %
=E
Packing:
AMMO H16.5 340 x 340
AMMO H16.5 490 x 370
AMMO H18.5 340 x 340
AMMO H18.5 490 x 370
REEL H16.5 360
REEL H16.5 500
REEL H18.5 360
REEL H18.5 500
ROLL H16.5
ROLL H18.5
BLISTER W12 180
BLISTER W12 330
BLISTER W16 330
BLISTER W24 330
Bulk/TPS Standard
=A
=B
=C
=D
=F
=H
=I
=J
=N
=O
=P
=Q
=R
=T
=S
3.5 ±0.5 = C9
6 -2
= SD
16 ±1 = P1
Pin length (taped)
none
= 00
The data on this page is not complete and serves only to explain the part number system. Part number information is listed on
the pages of the respective WIMA range.
131
很抱歉,暂时无法提供与“MKS2D031001A00JSSD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.73680
- 10+3.05640
- 30+2.76480
- 100+2.39760
- 500+2.23560
- 1000+2.13840
- 国内价格 香港价格
- 1+5.639671+0.73101
- 10+3.4648310+0.44911
- 50+2.6290050+0.34077
- 100+2.37069100+0.30729
- 500+1.93480500+0.25079
- 1000+1.800191000+0.23334
- 2500+1.658122500+0.21493
- 5000+1.572515000+0.20383
