HR CONNECTOR
Radial
RadialTape
Tape
2.5
2.5 mm
mm pitch/Disconnectable
pitch/Disconnectable Crimp
Crimp style
style connectors
connectors
HR
HR CONNECTOR
CONNECTOR
JS
Specifications
• Current rating: 3 A AC/DC (AWG #22)
• Voltage rating: 250 V AC/DC
• Temperature range: -25℃ to +85℃
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 10 mΩ max.
After environmental tests/ 20 mΩ max.
• Insulation resistance: 1,000 MΩ min.
• Withstanding voltage: 1,000 VAC/minute
• Applicable wire: AWG #26 to #22
• Applicable PC board thickness: 0.8 to 1.6 mm
T5
* In using the products,refer to "Handling Precautions for Terminals
and Connectors" described on our website (Technical documents
of Product information page).
* RoHS2 compliance
* Dimensional unit: mm
* Contact JST for details.
11.3 mm in mounting height, and 4.1 mm in
thickness. This connector is in-line method
taking out the wire vertically to the PC
board, and it enables insertion/withdrawal
operation and designing the mounting on
the PC board easier.
● Thin design
● High reliability
● Interchangeability
Standards
Recognized E60389
PC board layout and Assembly layout
2.5 min.
3.8
2.5 min.
(7.5)
0.6
(11.3)
2.5±0.05
+0.1
φ0.9 0
+0.1
φ0.9 0
(13.5)
4.2
2.2 min.
2.5±0.05
Side entry type
4.1
6.7 min.
Top entry type
Top entry type on radial-tape
+0.1
φ0.9 0
(11.8)
2.5 min.
2.2 min.
4.4
2.5±0.05
Note: 1 . The above figure is the figure viewed from the connector soldering side.
2. Tolerances are non-cumulative: ± 0.05 mm for all centers.
3. Hole dimension differ according to the type of PC board and piercing method. If PC boards made of hard material are used, the hole dimensions
should be larger. The dimensions above should serve as a guideline. Contact JST for details.
1
HR CONNECTOR
HRコネクタ表-1
Contact
Applicable wire
Model No.
SHR-001T-P0.6
8.2
AWG #
0.13 to 0.33
26 to 22
Insulation O.D. (mm)
Q'ty/
reel
1.3 to 1.7
9,000
HR CONNECTOR
Material and Finish
4.85
2.85
0.8
mm2
1.3
Phosphor bronze, tin-plated (reflow treatment)
2.1
RoHS2 compliance
Crimping
machine Crimp applicator
Contact
1.9
SHR-001T-P0.6 AP-K2N
MKS-L
Applicator
Dies
Crimp applicator with dies
MK/SHR/MR-001-06 APLMK SHR/MR001-06
Note: Contact JST for fully automatic crimping applicator.
HRコネクタ表-2
Housing
No. of
circuits
HRP-02-S
HRP-03-S
HRP-04-S
HRP-05-S
HRP-06-S
HRP-07-S
HRP-08-S
HRP-09-S
HRP-10-S
HRP-11-S
HRP-12-S
HRP-13-S
2
3
4
2.5
2.5
5
A
4.1
6
7
8
9
10.3
10
1
Model No.
11
12
13
Dimensions (mm)
A
B
Q'ty/
bag
2.5
7.5
2,000
5.0
10.0
2,000
7.5
12.5
1,000
10.0
15.0
1,000
12.5
17.5
1,000
15.0
20.0
500
17.5
22.5
500
20.0
25.0
500
22.5
27.5
500
25.0
30.0
500
27.5
32.5
500
30.0
35.0
250
Material and Finish
JST
PA 66, UL94V-0, natural (white)
B
RoHS2 compliance
Header
The headers are interchangeable with those of the EH crimp style and HR insulation displacement connectors.
Model number allocation
Contact
Housing
HR P - 02 - S
S HR - 001 T - P 0.6
Form: S…Strip form
Series name
Applicable wire range: 001…AWG #26 to AWG #22
Surface finish: T…Tin-plated (reflow treatment)
Material: P…Phosphor bronze
Terminal size
Series name
Part name: Plug
No. of circuits: 2 to 13
Color: S…Natural (White), K…Black, R…Red, TR…Tomato red, E…Blue,
L…Lemon yellow, M…Green, N…Brown, O…Orange, P…Purple,
PK…Pink, LE…Light blue, Y…Yellow, FY…Fluorescent yellow,
H…Gray
Note: Depending on the colors, it may take some time for delivery.
2
很抱歉,暂时无法提供与“SHR-001T-P0.6”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 9000+0.181919000+0.02363
