TF-002T-15
TF-002T-15
    SOFNG(硕方)
    SD-CARD-SOCKET-8P_13.55X13.48MM_SM
TF-002T-15 数据手册
Memory-Card-Sockets C ONNECTORS Operation:鉸鏈 LTEM NO.:TF-002T-15 (MEMORY-CARD-SOCKETS) Unit:mm Technical parameter ╲ LEVEL ╲ PROJECT Electrical Properties Initial Contact Resistance Contact Resistance Withstand Voltage Durable Performance A[better product] B[average product] C[low product] 30mΩ max. 30mΩ max. no data! 100mΩ min.100V DC 300V AC for 1min 側向導入 LATERAL Skey/PD:50mΩ min.100V DC 精密部品 NICETY 250 V AC for 1min There No Load 8,000 Cycles 7,000 Cycles no data! Rated Load 6,500 Cycles 50mΩ max. 5,000 Cycles 30mΩ max. no data! Insertion Force 表面貼裝 SMT 4.0Kgf MAX (Springback: 可靠 STABILIZE 適合環保 RoHS ) sofng.com C ONNECTORS CIRCUIT BOARD SIZE (Vertical view) PIN Assignment TF CARD Pin DESIGN Pin No. Pin NAME Type Description P① DAT2 I/0/PP Date Line[Bit 2] P② CD/DAT3 I/0/PP Card Detect Date Lin(BIT3) P③ CMD PP Command Response P④ VDD S Supply voltage P⑤ CLX l Clock P⑥ Vss S Supply voltage ground P⑦ DAT 0 l/0/PP Date Line [Bit 0] P⑧ DAT 1 l/0/PP Date Line [Bit 1] 注記 NOTICE 1.碩方電子公司擁有最終解釋權; The company reserves the right of final interpretation; 2.文件禁止外洩、轉載; Leaked and reproduced prohibited; 3.未經授權修改無效。Modify is invalid. 本品不屬於危害性廢棄物,須丟棄 時可以委託回收商予以回收再生 處理。Products do not belong to hazardous waste,When waste can recycling processing 運送時本產品不要直接與水、酸 鹼性化學物質接觸,或放置於含有 以上氣體環境中,並且需要注意會 有滑落、側翻的危險發生;運輸 過程中不能有碰撞或者擠壓,須保 證溫度與濕度適中[常溫 25℃,濕 度在 50℃以內],不可導致材料變 形或氧化。
TF-002T-15 价格&库存
很抱歉,暂时无法提供与“TF-002T-15”相匹配的价格&库存,您可以联系我们找货
