Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
PBLS1501Y; PBLS1501V
15 V PNP BISS loadswitch
Rev. 02 — 24 August 2009
Product data sheet
1. Product profile
1.1 General description
Low VCEsat PNP transistor and NPN resistor-equipped transistor in one package.
Table 1.
Product overview
Type number
Package
NXP
JEITA
PBLS1501Y
SOT363
SC-88
PBLS1501V
SOT666
1.2 Features
n
n
n
n
n
Low VCEsat (BISS) transistor and resistor-equipped transistor in one package
Low ‘threshold’ voltage (< 1 V) compared to MOSFET
Low drive power required
Space-saving solution
Reduction of component count
1.3 Applications
n
n
n
n
Supply line switches
Battery charger switches
High-side switches for LEDs, drivers and backlights
Portable equipment
1.4 Quick reference data
Table 2.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
open base
−15
V
−500
mA
IC = −500 mA;
IB = −50 mA
300
500
mΩ
open base
50
V
TR1; PNP: low VCEsat transistor
VCEO
collector-emitter voltage
IC
collector-current (DC)
RCEsat
equivalent on-resistance
TR2; NPN: resistor-equipped transistor
VCEO
NXP Semiconductors
Table 2.
Quick reference data …continued
Symbol
Parameter
Min
Typ
Max
Unit
IO
output current (DC)
Conditions
100
mA
R1
bias resistor 1 (input)
1.54
2.2
2.86
kΩ
R2/R1
bias resistor ratio
0.8
1
1.2
2. Pinning information
Table 3.
Discrete pinning
Pin
Description
1
emitter TR1
Simplified outline
2
base TR1
3
output (collector) TR2
4
GND (emitter) TR2
5
input (base) TR2
6
collector TR1
6
5
Symbol
4
6
5
R1
4
R2
TR2
1
2
3
TR1
001aab555
1
2
3
sym036
3. Ordering information
Table 4.
Type number
Package
Name
Description
Version
PBLS1501Y
SC-88
plastic surface mounted package; 6 leads
SOT363
PBLS1501V
SOT666
4. Marking
Table 5.
Marking
Type number
Marking code[1]
PBLS1501Y
*C1
PBLS1501V
C1
[1]
* = -: made in Hong Kong
* = t: made in Malaysia
* = W: made in China
PBLS1501Y_PBLS1501V_2
Product data sheet
© NXP B.V. 2009. All rights reserved.
2 of 14
NXP Semiconductors
5. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
Transistor TR1: PNP
VCBO
collector-base voltage
open emitter
−15
V
VCEO
open base
−15
V
VEBO
emitter-base voltage
open collector
−6
V
IC
collector current (DC)
−500
mA
−1
A
−50
mA
−100
mA
200
mW
tp ≤ 1 ms; δ ≤ 0.02
ICM
peak collector current
IB
base current (DC)
IBM
peak base current
tp ≤ 1 ms; δ ≤ 0.02
total power dissipation
Tamb ≤ 25 °C
Ptot
[1]
Transistor TR2: NPN
VCBO
open emitter
50
V
VCEO
open base
50
V
VEBO
open collector
10
V
VI
input voltage
positive
+12
V
negative
−10
V
100
mA
IO
output current (DC)
ICM
Ptot
Tamb ≤ 25 °C
[1]
100
mA
200
mW
mW
Per device
Ptot
300
Tstg
storage temperature
−65
+150
°C
Tj
junction temperature
150
°C
Tamb
ambient temperature
−65
+150
°C
[1]
Device mounted on a FR4 printed-circuit board, single-sided copper, tin-plated and standard footprint.
6. Thermal characteristics
Table 7.
Symbol
Parameter
Conditions
thermal resistance from
junction to ambient
in free air
Min
Typ
Max
Unit
Per device
Rth(j-a)
SOT363
[1]
416
K/W
SOT666
[1][2]
416
K/W
[1]
[2]
Reflow soldering is the only recommended soldering method.
Product data sheet
3 of 14
NXP Semiconductors
7. Characteristics
Table 8.
Characteristics
Tamb = 25 °C unless otherwise specified
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Transistor TR1: PNP
ICBO
collector-base cut-off
current
VCB = −15 V; IE = 0 A
−100
nA
VCB = −15 V; IE = 0 A; Tj = 150 °C
−50
µA
ICES
collector-emitter
cut-off current
VCE = −15 V; VBE = 0 V
−100
nA
IEBO
emitter-base cut-off
current
VEB = −5 V; IC = 0 A
−100
nA
hFE
DC current gain
VCE = −2 V; IC = −10 mA
200
150
VCEsat
collector-emitter
saturation voltage
VCE = −2 V; IC = −100 mA
[1]
VCE = −2 V; IC = −500 mA
[1]
IC = −10 mA; IB = −0.5 mA
IC = −200 mA; IB = −10 mA
90
−25
mV
−150
mV
IC = −500 mA; IB = −50 mA
[1]
−250
mV
300
500
mΩ
RCEsat
equivalent
on-resistance
[1]
VBEsat
base-emitter
saturation voltage
[1]
−1.1
V
VBEon
base-emitter turn-on
voltage
[1]
−0.9
V
fT
transition frequency
VCE = −5 V; IC = −100 mA;
f = 100 MHz
100
280
MHz
Cc
collector capacitance
VCB = −10 V; IE = ie = 0 A;
f = 1 MHz
10
pF
Transistor TR2: NPN
ICBO
current
VCB = 50 V; IE = 0 A
100
nA
ICEO
collector-emitter
cut-off current
VCE = 30 V; IB = 0 A
1
µA
VCE = 30 V; IB = 0 A; Tj = 150 °C
50
µA
mA
IEBO
current
VEB = 5 V; IC = 0 A
2
hFE
DC current gain
VCE = 5 V; IC = 20 mA
30
VCEsat
collector-emitter
saturation voltage
IC = 10 mA; IB = 0.5 mA
150
VI(off)
off-state input voltage
VCE = 5 V; IC = 1 mA
1.2
0.5
V
VI(on)
on-state input voltage
VCE = 0.3 V; IC = 20 mA
2
1.6
V
R1
1.54
2.2
2.86
kΩ
R2/R1
bias resistor ratio
0.8
1
1.2
Cc
2.5
[1]
VCB = 10 V; IE = ie = 0 A; f = 1 MHz
mV
pF
Pulse test: tp ≤ 300 µs; δ ≤ 0.02
Product data sheet
4 of 14
NXP Semiconductors
001aaa181
600
hFE
001aaa185
−103
VCEsat
(mV)
(1)
(1)
−102
400
(2)
(3)
(2)
−10
200
(3)
−10−1
−1
−10
−102
−1
−10−1
−103
−1
−10
−102
IC (mA)
VCE = −2 V
IC/IB = 20
(1) Tamb = 150 °C
(1) Tamb = 150 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = −55 °C
(3) Tamb = −55 °C
Fig 1.
−103
IC (mA)
TR1(PNP): DC current gain as a function of
collector current; typical values
001aaa183
−1100
VBE
(mV)
−900
Fig 2.
TR1(PNP): Collector-emitter saturation voltage
as a function of collector current; typical
values
001aaa184
−1200
VBEsat
(mV)
−1000
(1)
−700
(1)
−800
(2)
(2)
−500
−600
(3)
(3)
−300
−400
−100
−10−1
−1
−10
−102
−103
−200
−10−1
−1
VCE = −2 V
(1) Tamb = 150 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = 150 °C
(3) Tamb = −55 °C
TR1(PNP): Base-emitter voltage as a function
of collector current; typical values
Fig 4.
−103
TR1(PNP): Base-emitter saturation voltage as
a function of collector current; typical values
Product data sheet
−102
IC/IB = 20
(1) Tamb = −55 °C
Fig 3.
−10
IC (mA)
IC (mA)
5 of 14
NXP Semiconductors
001aaa182
−1200
RCEsat
(Ω)
(1)
(2)
(3)
IC
(mA)
001aaa186
103
102
(4)
(5)
−800
(6)
(7)
10
(8)
−400
(9)
(1)
1
(10)
−2
−4
−6
(2)
(3)
−8
−10
VCE (V)
10−1
−10−1
−1
−10
−102
−103
IC (mA)
Tamb = 25 °C
IC/IB = 20
(1) IB = −7.0 mA
(1) Tamb = −55 °C
(2) IB = −6.3 mA
(2) Tamb = 25 °C
(3) IB = −5.6 mA
(3) Tamb = 150 °C
(4) IB = −4.9 mA
(5) IB = −4.2 mA
(6) IB = −3.5 mA
(7) IB = −2.8 mA
(8) IB = −2.1 mA
(9) IB = −1.4 mA
(10) IB = −0.7 mA
Fig 5.
TR1(PNP): Collector current as a function of
collector-emitter voltage; typical values
Fig 6.
TR1(PNP): Equivalent on-resistance as a
Product data sheet
6 of 14
NXP Semiconductors
006aaa004
−1
006aaa005
103
RCEsat
(Ω)
VCEsat
(V)
102
−10−1
(1)
(1)
10
(2)
(2)
(3)
−10−2
1
(3)
−10−3
−10−1
−1
−10
−102
−103
10−1
−10−1
−1
Tamb = 25 °C
(1) IC/IB = 100
(2) IC/IB = 50
(2) IC/IB = 50
(3) IC/IB = 10
(3) IC/IB = 10
values
Fig 8.
−103
Product data sheet
−102
Tamb = 25 °C
(1) IC/IB = 100
Fig 7.
−10
IC (mA)
IC (mA)
7 of 14
NXP Semiconductors
006aaa015
103
006aaa014
103
hFE
(1)
(2)
(3)
102
VCEsat
(mV)
102
(1)
(2)
(3)
10
1
10−1
1
102
10
10
1
IC (mA)
VCE = 5 V
IC/IB = 20
(1) Tamb = 150 °C
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = −40 °C
(3) Tamb = −40 °C
Fig 9.
102
10
IC (mA)
TR2(NPN): DC current gain as a function of
006aaa016
102
VI(on)
(V)
Fig 10. TR2(NPN): Collector-emitter saturation voltage
values
006aaa017
10
VI(off)
(V)
10
(1)
(2)
1
(3)
(1)
(2)
(3)
1
10−1
10−1
1
102
10
10−1
10−2
10−1
IC (mA)
10
IC (mA)
VCE = 0.3 V
VCE = 5 V
(1) Tamb = −40 °C
(1) Tamb = −40 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = 100 °C
(3) Tamb = 100 °C
Fig 11. TR2(NPN): On-state input voltage as a function
Fig 12. TR2(NPN): Off-state input voltage as a function
Product data sheet
1
8 of 14
NXP Semiconductors
8. Package outline
Plastic surface-mounted package; 6 leads
SOT363
D
E
B
y
X
A
HE
6
5
v M A
4
Q
pin 1
index
A
A1
1
2
e1
3
bp
c
Lp
w M B
e
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
max
bp
c
D
E
e
e1
HE
Lp
Q
v
w
y
mm
1.1
0.8
0.1
0.30
0.20
0.25
0.10
2.2
1.8
1.35
1.15
1.3
0.65
2.2
2.0
0.45
0.15
0.25
0.15
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT363
JEITA
SC-88
EUROPEAN
PROJECTION
ISSUE DATE
04-11-08
06-03-16
Fig 13. Package outline SOT363 (SC-88)
Product data sheet
9 of 14
NXP Semiconductors
SOT666
D
E
A
X
Y S
S
HE
6
5
4
pin 1 index
A
1
2
e1
c
3
bp
w M A
Lp
e
detail X
2 mm
scale
UNIT
A
bp
c
D
E
e
e1
HE
Lp
w
y
mm
0.6
0.5
0.27
0.17
0.18
0.08
1.7
1.5
1.3
1.1
1.0
0.5
1.7
1.5
0.3
0.1
0.1
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
04-11-08
06-03-16
SOT666
Fig 14. Package outline SOT666
Product data sheet
10 of 14
NXP Semiconductors
9. Packing information
Table 9.
Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number
PBLS1501Y
PBLS1501V
Package
SOT363
SOT666
Description
Packing quantity
3000
4000
4 mm pitch, 8 mm tape and reel; T1
[2]
-115
−135
4 mm pitch, 8 mm tape and reel; T2
[3]
-125
-165
-115
[1]
For further information and the availability of packing methods, see Section 12.
[2]
T1: normal taping
[3]
T2: reverse taping
Product data sheet
10000
11 of 14
NXP Semiconductors
10. Revision history
Table 10.
Revision history
Document ID
Release date
PBLS1501Y_PBLS1501V_2 20090824
Modifications:
Data sheet status
Change notice
Supersedes
Product data sheet
PBLS1501Y_PBLS1501V_1
This data sheet was changed to reflect the new company name NXP Semiconductors,
including new legal definitions and disclaimers. No changes were made to the technical
content.
Table 3 “Discrete pinning”: amended
Figure 13 “Package outline SOT363 (SC-88)”: updated
Figure 14 “Package outline SOT666”: updated
PBLS1501Y_PBLS1501V_1 20041105
Product data sheet
Product data sheet
12 of 14
NXP Semiconductors
11. Legal information
11.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nxp.com.
11.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. NXP Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local NXP Semiconductors sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
11.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, NXP Semiconductors does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — NXP Semiconductors reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — NXP Semiconductors products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of an NXP Semiconductors product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. NXP Semiconductors accepts no liability for inclusion and/or use of
NXP Semiconductors products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. NXP Semiconductors makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — NXP Semiconductors products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nxp.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by NXP Semiconductors. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
11.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
12. Contact information
For more information, please visit: http://www.nxp.com
For sales office addresses, please send an email to: salesaddresses@nxp.com
Product data sheet
13 of 14
NXP Semiconductors
13. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
10
11
11.1
11.2
11.3
11.4
12
13
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description. . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data. . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Thermal characteristics. . . . . . . . . . . . . . . . . . . 3
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9
Packing information. . . . . . . . . . . . . . . . . . . . . 11
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12
Legal information. . . . . . . . . . . . . . . . . . . . . . . 13
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Contact information. . . . . . . . . . . . . . . . . . . . . 13
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
© NXP B.V. 2009.
Date of release: 24 August 2009
Document identifier: PBLS1501Y_PBLS1501V_2
