BT145-800R,127
BT145-800R,127
    WEEN(瑞能)
    TO-220-3
    SCR 800V 25A Standard Recovery Through Hole TO-220AB
BT145-800R,127 数据手册
IMPORTANT NOTICE 10 December 2015 1. Global joint venture starts operations as WeEn Semiconductors Dear customer, As from November 9th, 2015 NXP Semiconductors N.V. and Beijing JianGuang Asset Management Co. Ltd established Bipolar Power joint venture (JV), WeEn Semiconductors, which will be used in future Bipolar Power documents together with new contact details. In this document where the previous NXP references remain, please use the new links as shown below. WWW - For www.nxp.com use www.ween-semi.com Email - For salesaddresses@nxp.com use salesaddresses@ween-semi.com For the copyright notice at the bottom of each page (or elsewhere in the document, depending on the version) “© NXP Semiconductors N.V. {year}. All rights reserved” becomes “© WeEn Semiconductors Co., Ltd. {year}. All rights reserved” If you have any questions related to this document, please contact our nearest sales office via email or phone (details via salesaddresses@ween-semi.com). Thank you for your cooperation and understanding, WeEn Semiconductors Philips Semiconductors Product specification Thyristors GENERAL DESCRIPTION Glass passivated thyristors in a plastic envelope, intended for use in applications requiring high bidirectional blocking voltage capability and high thermal cycling performance. Typical applications include motor control, industrial and domestic lighting, heating and static switching. PINNING - TO220AB PIN DESCRIPTION 1 cathode 2 anode 3 gate tab BT145 series QUICK REFERENCE DATA SYMBOL VDRM, VRRM IT(AV) IT(RMS) ITSM PARAMETER MAX. MAX. MAX. UNIT BT145Repetitive peak off-state voltages Average on-state current RMS on-state current Non-repetitive peak on-state current 500R 500 600R 600 800R 800 V 16 25 300 16 25 300 16 25 300 A A A PIN CONFIGURATION SYMBOL tab a k g 1 23 anode LIMITING VALUES Limiting values in accordance with the Absolute Maximum System (IEC 134). SYMBOL PARAMETER CONDITIONS VDRM, VRRM Repetitive peak off-state voltages IT(AV) IT(RMS) ITSM I2t dIT/dt IGM VGM VRGM PGM PG(AV) Tstg Tj Average on-state current RMS on-state current Non-repetitive peak on-state current half sine wave; Tmb ≤ 101 ˚C all conduction angles half sine wave; Tj = 25 ˚C prior to surge t = 10 ms t = 8.3 ms t = 10 ms ITM = 50 A; IG = 0.2 A; dIG/dt = 0.2 A/µs I2t for fusing Repetitive rate of rise of on-state current after triggering Peak gate current Peak gate voltage Peak reverse gate voltage Peak gate power Average gate power over any 20 ms period Storage temperature Operating junction temperature MIN. MAX. UNIT - -500R -600R -800R 5001 6001 800 V - 16 25 A A - 300 330 450 200 A A A2s A/µs -40 - 5 5 5 20 0.5 150 125 A V V W W ˚C ˚C 1 Although not recommended, off-state voltages up to 800V may be applied without damage, but the thyristor may switch to the on-state. The rate of rise of current should not exceed 15 A/µs. October 1997 1 Rev 1.200 Philips Semiconductors Product specification Thyristors BT145 series THERMAL RESISTANCES SYMBOL PARAMETER Rth j-mb Thermal resistance junction to mounting base Thermal resistance in free air junction to ambient Rth j-a CONDITIONS MIN. TYP. MAX. UNIT - - 1.0 K/W - 60 - K/W STATIC CHARACTERISTICS Tj = 25 ˚C unless otherwise stated SYMBOL PARAMETER CONDITIONS MIN. TYP. MAX. UNIT IGT IL IH VT VGT Gate trigger current Latching current Holding current On-state voltage Gate trigger voltage ID, IR Off-state leakage current VD = 12 V; IT = 0.1 A VD = 12 V; IGT = 0.1 A VD = 12 V; IGT = 0.1 A IT = 30 A VD = 12 V; IT = 0.1 A VD = VDRM(max); IT = 0.1 A; Tj = 125 ˚C VD = VDRM(max); VR = VRRM(max); Tj = 125 ˚C 0.25 - 5 25 20 1.1 0.6 0.4 0.2 35 80 60 1.5 1.0 1.0 mA mA mA V V V mA DYNAMIC CHARACTERISTICS Tj = 25 ˚C unless otherwise stated SYMBOL PARAMETER CONDITIONS MIN. TYP. MAX. UNIT dVD/dt Critical rate of rise of off-state voltage Gate controlled turn-on time Circuit commutated turn-off time VDM = 67% VDRM(max); Tj = 125 ˚C; exponential waveform; gate open circuit ITM = 40 A; VD = VDRM(max); IG = 0.1 A; dIG/dt = 5 A/µs VD = 67% VDRM(max); Tj = 125 ˚C; ITM = 50 A; VR = 25 V; dITM/dt = 30 A/µs; dVD/dt = 50 V/µs 200 500 - V/µs - 2 - µs - 70 - µs tgt tq October 1997 2 Rev 1.200 Philips Semiconductors Product specification Thyristors 25 BT145 series Ptot / W conduction form angle factor degrees a 30 4 60 2.8 90 2.2 120 1.9 180 1.57 20 15 Tmb(max) / C 100 a = 1.57 BT145 ITSM / A 350 1.9 BT145 105 2.2 time T Tj initial = 25 C max 250 2.8 110 4 10 115 5 120 ITSM IT 300 200 150 100 50 0 0 5 10 IF(AV) / A 125 20 15 0 Fig.1. Maximum on-state dissipation, Ptot, versus average on-state current, IT(AV), where a = form factor = IT(RMS)/ IT(AV). 10000 10 100 Number of half cycles at 50Hz 1000 Fig.4. Maximum permissible non-repetitive peak on-state current ITSM, versus number of cycles, for sinusoidal currents, f = 50 Hz. BT145 ITSM / A 1 50 BT145 IT(RMS) / A 40 30 1000 dI T /dt limit 20 ITSM IT 10 time T Tj initial = 25 C max 100 10us 100us 0 0.01 10ms 1ms 0.1 1 surge duration / s T/s Fig.2. Maximum permissible non-repetitive peak on-state current ITSM, versus pulse width tp, for sinusoidal currents, tp ≤ 10ms. 30 Fig.5. Maximum permissible repetitive rms on-state current IT(RMS), versus surge duration, for sinusoidal currents, f = 50 Hz; Tmb ≤ 101˚C. BT145 IT(RMS) / A 1.6 BT151 1.4 20 1.2 15 1 10 0.8 5 0.6 0 50 Tmb / C 100 0.4 -50 150 Fig.3. Maximum permissible rms current IT(RMS) , versus mounting base temperature Tmb. October 1997 VGT(Tj) VGT(25 C) 101 C 25 0 -50 10 0 50 Tj / C 100 150 Fig.6. Normalised gate trigger voltage VGT(Tj)/ VGT(25˚C), versus junction temperature Tj. 3 Rev 1.200 Philips Semiconductors Product specification Thyristors 3 BT145 series IGT(Tj) IGT(25 C) 50 BT145 BT145 IT / A Tj = 125 C Tj = 25 C 2.5 40 2 30 Vo = 1.045 V Rs = 0.011 ohms typ max 1.5 20 1 10 0.5 0 -50 0 0 50 Tj / C 100 150 Fig.7. Normalised gate trigger current IGT(Tj)/ IGT(25˚C), versus junction temperature Tj. 3 IL(Tj) IL(25 C) 0 0.5 1 VT / V 1.5 2 Fig.10. Typical and maximum on-state characteristic. 10 BT145 2.5 BT145 Zth j-mb (K/W) 1 2 0.1 1.5 P D 1 tp 0.01 0.5 t 0 -50 0 50 Tj / C 100 0.001 10us 150 IH(Tj) IH(25 C) 1ms 10ms tp / s 0.1s 1s 10s Fig.11. Transient thermal impedance Zth j-mb, versus pulse width tp. Fig.8. Normalised latching current IL(Tj)/ IL(25˚C), versus junction temperature Tj. 3 0.1ms 10000 BT145 dVD/dt (V/us) 2.5 1000 2 gate open circuit 1.5 100 1 0.5 0 -50 0 50 Tj / C 100 10 150 50 100 150 Tj / C Fig.12. Typical, critical rate of rise of off-state voltage, dVD/dt versus junction temperature Tj. Fig.9. Normalised holding current IH(Tj)/ IH(25˚C), versus junction temperature Tj. October 1997 0 4 Rev 1.200 Philips Semiconductors Product specification Thyristors BT145 series MECHANICAL DATA Dimensions in mm 4,5 max Net Mass: 2 g 10,3 max 1,3 3,7 2,8 5,9 min 15,8 max 3,0 max not tinned 3,0 13,5 min 1,3 max 1 2 3 (2x) 0,9 max (3x) 2,54 2,54 0,6 2,4 Fig.13. TO220AB; pin 2 connected to mounting base. Notes 1. Refer to mounting instructions for TO220 envelopes. 2. Epoxy meets UL94 V0 at 1/8". October 1997 5 Rev 1.200 Philips Semiconductors Product specification Thyristors BT145 series DEFINITIONS Data sheet status Objective specification This data sheet contains target or goal specifications for product development. Preliminary specification This data sheet contains preliminary data; supplementary data may be published later. Product specification This data sheet contains final product specifications. Limiting values Limiting values are given in accordance with the Absolute Maximum Rating System (IEC 134). Stress above one or more of the limiting values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or at any other conditions above those given in the Characteristics sections of this specification is not implied. Exposure to limiting values for extended periods may affect device reliability. Application information Where application information is given, it is advisory and does not form part of the specification.  Philips Electronics N.V. 1997 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, it is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent or other industrial or intellectual property rights. LIFE SUPPORT APPLICATIONS These products are not designed for use in life support appliances, devices or systems where malfunction of these products can be reasonably expected to result in personal injury. Philips customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Philips for any damages resulting from such improper use or sale. October 1997 6 Rev 1.200
BT145-800R,127 价格&库存
很抱歉,暂时无法提供与“BT145-800R,127”相匹配的价格&库存,您可以联系我们找货
BT145-800R,127
  • 1+24.685841+3.19378
