BT152-400R,127
BT152-400R,127
    WEEN(瑞能)
    TO-220-3
    THYRISTOR 20A 450V TO220AB
BT152-400R,127 数据手册
$%&'((&($! )*+),                            !"#$%#  &#  ' (  ) !* ) +"   ,$ -      + +))  !* ) +    # + +    )  .     + *     *)   +)/    + ) + 0 +++1*  ++++    0  )   21*   )   2+   0   *3#      *#, ) +    *#    -4     5  4    !"#   5 .3 36   )       *)       )   ) * , )  )   2+   - 7/3  3  *   # 89    DISCRETE SEMICONDUCTORS '$7$ 6+((7 %7VHULHV 7K\ULVWRUV 3URGXFWVSHFLILFDWLRQ 0DUFK 1;3 Semiconductors Product specification Thyristors GENERAL DESCRIPTION Glass passivated thyristors in a plastic envelope, intended for use in applications requiring high bidirectional blocking voltage capability and high thermal cycling performance. Typical applications include motor control, industrial and domestic lighting, heating and static switching. PINNING - TO220AB PIN DESCRIPTION 1 cathode 2 anode 3 gate tab BT152 series QUICK REFERENCE DATA SYMBOL VDRM, VRRM IT(AV) IT(RMS) ITSM PARAMETER MAX. MAX. MAX. UNIT BT152Repetitive peak off-state voltages Average on-state current RMS on-state current Non-repetitive peak on-state current 400R 450 600R 650 800R 800 V 13 20 200 13 20 200 13 20 200 A A A PIN CONFIGURATION SYMBOL tab a k g 1 23 anode LIMITING VALUES Limiting values in accordance with the Absolute Maximum System (IEC 134). SYMBOL PARAMETER VDRM Repetitive peak off-state voltages IT(AV) IT(RMS) ITSM Average on-state current RMS on-state current Non-repetitive peak on-state current I2t dIT/dt IGM VGM VRGM PGM PG(AV) Tstg Tj CONDITIONS half sine wave; Tmb ≤ 103 ˚C all conduction angles half sine wave; Tj = 25 ˚C prior to surge t = 10 ms t = 8.3 ms t = 10 ms ITM = 50 A; IG = 0.2 A; dIG/dt = 0.2 A/μs I2t for fusing Repetitive rate of rise of on-state current after triggering Peak gate current Peak gate voltage Peak reverse gate voltage Peak gate power Average gate power over any 20 ms period Storage temperature Operating junction temperature MIN. MAX. UNIT - -400R -600R -800R 4501 6501 800 V - 13 20 A A - 200 220 200 200 A A A2s A/μs -40 - 5 5 5 20 0.5 150 125 A V V W W ˚C ˚C 1 Although not recommended, off-state voltages up to 800V may be applied without damage, but the thyristor may switch to the on-state. The rate of rise of current should not exceed 15 A/μs. March 1997 1 Rev 1.200 1;3 Semiconductors Product specification Thyristors BT152 series THERMAL RESISTANCES SYMBOL PARAMETER Rth j-mb Thermal resistance junction to mounting base Thermal resistance in free air junction to ambient Rth j-a CONDITIONS MIN. TYP. MAX. UNIT - - 1.1 K/W - 60 - K/W STATIC CHARACTERISTICS Tj = 25 ˚C unless otherwise stated SYMBOL PARAMETER CONDITIONS MIN. TYP. MAX. UNIT IGT IL IH VT VGT Gate trigger current Latching current Holding current On-state voltage Gate trigger voltage ID, IR Off-state leakage current VD = 12 V; IT = 0.1 A VD = 12 V; IGT = 0.1 A VD = 12 V; IGT = 0.1 A IT = 40 A VD = 12 V; IT = 0.1 A VD = VDRM(max); IT = 0.1 A; Tj = 125 ˚C VD = VDRM(max); VR = VRRM(max); Tj = 125 ˚C 0.25 - 3 25 15 1.4 0.6 0.4 0.2 32 80 60 1.75 1.5 1.0 mA mA mA V V V mA DYNAMIC CHARACTERISTICS Tj = 25 ˚C unless otherwise stated SYMBOL PARAMETER CONDITIONS MIN. TYP. MAX. UNIT dVD/dt Critical rate of rise of off-state voltage Gate controlled turn-on time Circuit commutated turn-off time VDM = 67% VDRM(max); Tj = 125 ˚C; exponential waveform gate open circuit VD = VDRM(max); IG = 0.1 A; dIG/dt = 5 A/μs; ITM = 40 A VD = 67% VDRM(max); Tj = 125 ˚C; ITM = 50 A; VR = 25 V; dITM/dt = 30 A/μs; dVD/dt = 50 V/μs; RGK = 100 Ω 200 300 - V/μs - 2 - μs - 70 - μs tgt tq March 1997 2 Rev 1.200 NXP Semiconductors Product specification Thyristors 25 BT152 series Ptot / W BT152 conduction angle degrees 30 60 90 120 180 20 15 Tmb(max) / C ITSM / A 250 97.5 BT152 form factor a a = 1.57 4 2.8 2.2 1.9 1.57 1.9 103 200 108.5 150 114 100 time T Tj initial = 25 C max 2.2 2.8 ITSM IT 4 10 119.5 5 0 0 5 50 125 15 10 0 IT(AV) / A Fig.1. Maximum on-state dissipation, Ptot, versus average on-state current, IT(AV), where a = form factor = IT(RMS)/ IT(AV). 1000 10 100 Number of half cycles at 50Hz 1000 Fig.4. Maximum permissible non-repetitive peak on-state current ITSM, versus number of cycles, for sinusoidal currents, f = 50 Hz. BT152 ITSM / A 1 50 BT152 IT(RMS) / A dI T /dt limit 40 30 100 20 I TSM IT 10 time T Tj initial = 25 C max 10 10us 100us 0 0.01 10ms 1ms 0.1 1 surge duration / s T/s Fig.5. Maximum permissible repetitive rms on-state current IT(RMS), versus surge duration, for sinusoidal currents, f = 50 Hz; Tmb ≤ 103˚C. Fig.2. Maximum permissible non-repetitive peak on-state current ITSM, versus pulse width tp, for sinusoidal currents, tp ≤ 10ms. 25 BT152 IT(RMS) / A 1.6 103 C 20 10 VGT(Tj) VGT(25 C) BT151 1.4 1.2 15 1 10 0.8 5 0 -50 0.6 0 50 Tmb / C 100 0.4 -50 150 Fig.3. Maximum permissible rms current IT(RMS) , versus mounting base temperature Tmb. March 1997 0 50 Tj / C 100 150 Fig.6. Normalised gate trigger voltage VGT(Tj)/ VGT(25˚C), versus junction temperature Tj. 3 Rev 1.200 1;3Semiconductors Product specification Thyristors 3 BT152 series IGT(Tj) IGT(25 C) 50 BT152 BT152 IT / A Tj = 125 C Tj = 25 C 2.5 40 2 30 Vo = 1.12 V Rs = 0.015 ohms max typ 1.5 20 1 10 0.5 0 -50 0 50 Tj / C 100 0 150 Fig.7. Normalised gate trigger current IGT(Tj)/ IGT(25˚C), versus junction temperature Tj. 3 IL(Tj) IL(25 C) 0 0.5 1 VT / V 1.5 2 Fig.10. Typical and maximum on-state characteristic. 10 BT145 2.5 BT152 Zth j-mb (K/W) 1 2 0.1 1.5 P D 1 tp 0.01 0.5 t 0 -50 0 50 Tj / C 100 0.001 10us 150 IH(Tj) IH(25 C) 1ms 10ms tp / s 0.1s 1s 10s Fig.11. Transient thermal impedance Zth j-mb, versus pulse width tp. Fig.8. Normalised latching current IL(Tj)/ IL(25˚C), versus junction temperature Tj. 3 0.1ms 10000 BT152 dVD/dt (V/us) 2.5 RGK = 100 Ohms 1000 2 gate open circuit 1.5 100 1 0.5 0 -50 0 50 Tj / C 100 10 150 50 100 150 Tj / C Fig.12. Typical, critical rate of rise of off-state voltage, dVD/dt versus junction temperature Tj. Fig.9. Normalised holding current IH(Tj)/ IH(25˚C), versus junction temperature Tj. March 1997 0 4 Rev 1.200 1;3Semiconductors Product specification Thyristors BT152 series MECHANICAL DATA Dimensions in mm 4,5 max Net Mass: 2 g 10,3 max 1,3 3,7 2,8 5,9 min 15,8 max 3,0 max not tinned 3,0 13,5 min 1,3 max 1 2 3 (2x) 0,9 max (3x) 2,54 2,54 0,6 2,4 Fig.13. TO220AB; pin 2 connected to mounting base. Notes 1. Refer to mounting instructions for TO220 envelopes. 2. Epoxy meets UL94 V0 at 1/8". March 1997 5 Rev 1.200 NXP Semiconductors Legal information DATA SHEET STATUS DOCUMENT STATUS(1) Objective data sheet PRODUCT STATUS(2) Development DEFINITION This document contains data from the objective specification for product development. Preliminary data sheet Qualification This document contains data from the preliminary specification. Product data sheet Production This document contains the product specification. Notes 1. Please consult the most recently issued document before initiating or completing a design. 2. The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. DEFINITIONS Product specification ⎯ The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. DISCLAIMERS Limited warranty and liability ⎯ Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Right to make changes ⎯ NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use ⎯ NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications ⎯ Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors Legal information NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values ⎯ Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale ⎯ NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license ⎯ Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control ⎯ This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data ⎯ The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Non-automotive qualified products ⎯ Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. Customer notification This data sheet was changed to reflect the new company name NXP Semiconductors, including new legal definitions and disclaimers. No changes were made to the content, except for the legal definitions and disclaimers. Contact information For additional information please visit: http://www.nxp.com For sales offices addresses send e-mail to: salesaddresses@nxp.com © NXP B.V. 2011 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights. Printed in The Netherlands
BT152-400R,127 价格&库存
很抱歉,暂时无法提供与“BT152-400R,127”相匹配的价格&库存,您可以联系我们找货
