BT148W-600R,115
BT148W-600R,115
    WEEN(瑞能)
    TO-261-4
    THYRISTOR 1A 600V SOT-223
BT148W-600R,115 数据手册
IMPORTANT NOTICE 10 December 2015 1. Global joint venture starts operations as WeEn Semiconductors Dear customer, As from November 9th, 2015 NXP Semiconductors N.V. and Beijing JianGuang Asset Management Co. Ltd established Bipolar Power joint venture (JV), WeEn Semiconductors, which will be used in future Bipolar Power documents together with new contact details. In this document where the previous NXP references remain, please use the new links as shown below. WWW - For www.nxp.com use www.ween-semi.com Email - For salesaddresses@nxp.com use salesaddresses@ween-semi.com For the copyright notice at the bottom of each page (or elsewhere in the document, depending on the version) “© NXP Semiconductors N.V. {year}. All rights reserved” becomes “© WeEn Semiconductors Co., Ltd. {year}. All rights reserved” If you have any questions related to this document, please contact our nearest sales office via email or phone (details via salesaddresses@ween-semi.com). Thank you for your cooperation and understanding, WeEn Semiconductors SO T2 23 BT148W-600R SCR 2 December 2014 Product data sheet 1. General description Planar passivated SCR with sensitive gate in a SOT223 (SC-73) surface mountable plastic package. These devices are intended to be interfaced directly to microcontrollers, logic integrated circuits and other low power gate trigger circuits. 2. Features and benefits • • • • Sensitive gate Planar passivated for voltage ruggedness and reliability Direct triggering from low power drivers and logic ICs Surface mountable package 3. Applications • • • Adapters Battery powered applications Industrial automation 4. Quick reference data Table 1. Quick reference data Symbol Parameter VDRM repetitive peak offstate voltage VRRM Conditions Min Typ Max Unit - - 600 V repetitive peak reverse voltage - - 600 V ITSM non-repetitive peak on- half sine wave; Tj(init) = 25 °C; state current tp = 10 ms; Fig. 4; Fig. 5 - - 10 A IT(AV) average on-state current half sine wave; Tsp ≤ 112 °C; Fig. 1 - - 0.6 A IT(RMS) RMS on-state current half sine wave; Tsp ≤ 112 °C; Fig. 2; - - 1 A - 50 200 µA [1] Fig. 3 Static characteristics IGT gate trigger current [1] VD = 12 V; IT = 0.1 A; Tj = 25 °C; Fig. 9 Although not recommended, off-state voltages up to 800 V may be applied without damage, but the thyristor may switch to the on-state. Scan or click this QR code to view the latest information for this product BT148W-600R NXP Semiconductors SCR 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 K Simplified outline Graphic symbol 4 A cathode K G 2 A anode 3 G gate 4 mb mb; connected to anode sym037 1 2 3 SC-73 (SOT223) 6. Ordering information Table 3. Ordering information Type number BT148W-600R Package Name Description Version SC-73 plastic surface-mounted package with increased heatsink; 4 leads SOT223 7. Marking Table 4. Marking codes Type number Marking code BT148W-600R BT148W 60 BT148W-600R Product data sheet All information provided in this document is subject to legal disclaimers. 2 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 2 / 15 BT148W-600R NXP Semiconductors SCR 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions VDRM repetitive peak off-state voltage VRRM repetitive peak reverse voltage IT(AV) average on-state current IT(RMS) RMS on-state current Min Max Unit - 600 V - 600 V half sine wave; Tsp ≤ 112 °C; Fig. 1 - 0.6 A half sine wave; Tsp ≤ 112 °C; Fig. 2; - 1 A - 10 A - 11 A [1] Fig. 3 ITSM non-repetitive peak on-state current half sine wave; Tj(init) = 25 °C; tp = 10 ms; Fig. 4; Fig. 5 half sine wave; Tj(init) = 25 °C; tp = 8.3 ms I t I t for fusing tp = 10 ms; SIN - 0.5 A s dIT/dt rate of rise of on-state current IG = 400 µA - 100 A/µs IGM peak gate current - 1 A VRGM peak reverse gate voltage - 5 V PGM peak gate power - 1.2 W PG(AV) average gate power - 0.12 W Tstg storage temperature -40 150 °C Tj junction temperature - 125 °C 2 2 [1] [2] BT148W-600R Product data sheet over any 20 ms period [2] 2 Although not recommended, off-state voltages up to 800 V may be applied without damage, but the thyristor may switch to the on-state. Operation above 110˚C may require the use of a gate to cathode resistor of 1kΩ or less. All information provided in this document is subject to legal disclaimers. 2 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 3 / 15 BT148W-600R NXP Semiconductors SCR aaa-011921 1 Ptot (W) Tsp(max) (°C) a = 1.57 0.8 110 113 1.9 2.2 0.6 116 2.8 4 0.4 conduction angle (degrees) form factor a 30 60 90 120 180 4 2.8 2.2 1.9 1.57 0.2 0 0 0.2 0.4 0.6 119 122 α IT(AV) (A) 125 0.8 α = conduction angle a = form factor = IT(RMS) / IT(AV) Fig. 1. Total power dissipation as a function of average on-state current; maximum values aaa-011922 1.2 112 °C IT(RMS) (A) aaa-011925 12 IT(RMS) (A) 10 8 0.8 6 4 0.4 2 0 -50 Fig. 2. 0 50 100 Tsp (°C) 0 10-2 150 RMS on-state current as a function of solder point temperature; maximum values BT148W-600R Product data sheet 10-1 1 10 surge duration (s) f = 50 Hz; Tsp = 112 °C Fig. 3. RMS on-state current as a function of surge duration; maximum values All information provided in this document is subject to legal disclaimers. 2 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 4 / 15 BT148W-600R NXP Semiconductors SCR aaa-011923 103 IT ITSM (A) ITSM t tp Tj(init) = 25 °C max 102 10 1 10-5 10-4 10-3 10-2 tp (s) tp ≤ 10 ms Fig. 4. Non-repetitive peak on-state current as a function of pulse width for sinusoidal currents; maximum values aaa-011924 12 ITSM (A) 10 8 6 t 2 0 ITSM IT 4 1/f Tj(init) = 25 °C max 1 102 10 number of cycles 103 f = 50 Hz Fig. 5. Non-repetitive peak on-state current as a function of the number of sinusoidal current cycles; maximum values BT148W-600R Product data sheet All information provided in this document is subject to legal disclaimers. 2 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 5 / 15 BT148W-600R NXP Semiconductors SCR 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-sp) thermal resistance from junction to solder point Fig. 6 - - 15 K/W Rth(j-a) thermal resistance from junction to ambient printed circuit board mounted; pad area; Fig. 7 - 70 - K/W printed circuit board mounted; minimum footprint; Fig. 8 - 156 - K/W aaa-011929 102 Zth(j-sp) (K/W) 10 1 P 10-1 10-2 10-5 Fig. 6. tp 10-4 10-3 10-2 10-1 1 tp (s) t 10 Transient thermal impedance from junction to solder point as a function of pulse width BT148W-600R Product data sheet All information provided in this document is subject to legal disclaimers. 2 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 6 / 15 BT148W-600R NXP Semiconductors SCR 3.8 min 36 1.5 min 18 60 9 4.5 4.6 6.3 1.5 min (3×) 10 2.3 1.5 min 4.6 001aab508 7 All dimensions are in mm 15 Fig. 8. 50 001aab509 Minimum footprint SOT223 All dimensions are in mm Printed circuit board: FR4 epoxy glass (1.6 mm thick), copper laminate (35 um thick) Fig. 7. Printed circuit board pad area: SOT223 BT148W-600R Product data sheet All information provided in this document is subject to legal disclaimers. 2 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 7 / 15 BT148W-600R NXP Semiconductors SCR 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit Static characteristics IGT gate trigger current VD = 12 V; IT = 0.1 A; Tj = 25 °C; Fig. 9 - 50 200 µA IL latching current VD = 12 V; IG = 0.1 A; Tj = 25 °C; - 0.17 10 mA Fig. 10 IH holding current VD = 12 V; Tj = 25 °C; Fig. 11 - 0.1 6 mA VT on-state voltage IT = 2 A; Tj = 25 °C; Fig. 12 - 1.3 1.5 V VGT gate trigger voltage VD = 12 V; IT = 0.1 A; Tj = 25 °C; - 0.4 1 V 0.1 0.2 - V Fig. 13 VD = 600 V; IT = 0.1 A; Tj = 125 °C; Fig. 13 ID off-state current VD = 600 V; Tj = 125 °C - 0.1 0.5 mA IR reverse current VR = 600 V; Tj = 125 °C - 0.1 0.5 mA VDM = 402 V; Tj = 125 °C; RGK = 100 Ω; - 50 - V/µs Dynamic characteristics dVD/dt rate of rise of off-state voltage (VDM = 67% of VDRM); exponential waveform; Fig. 14 tgt gate-controlled turn-on ITM = 4 A; VD = 600 V; IG = 5 mA; dIG/ time dt = 0.2 A/µs; Tj = 25 °C - 2 - µs tq commutated turn-off time - 100 - µs VDM = 402 V; Tj = 125 °C; ITM = 4 A; VR = 35 V; (dIT/dt)M = 30 A/µs; dVD/ dt = 2 V/µs; RGK = 1 kΩ; (VDM = 67% of VDRM) BT148W-600R Product data sheet All information provided in this document is subject to legal disclaimers. 2 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 8 / 15 BT148W-600R NXP Semiconductors SCR aaa-011902 3 IGT IL IGT(25°C) IL(25°C) 2 2 1 1 0 -50 aaa-011903 3 0 50 100 Tj (°C) 0 -50 150 0 50 100 Tj (°C) 150 RGK = 1 kΩ Normalized gate trigger current as a function of junction temperature Fig. 10. Normalized latching current as a function of junction temperature Fig. 9. aaa-011904 3 aaa-011926 6 IT (A) IH IH(25°C) 2 4 1 2 0 -50 0 50 100 Tj (°C) 0 150 (1) 0 (2) (3) 1 2 VT (V) 3 Vo = 1.107 V; Rs = 0.14 Ω RGK = 1 kΩ (1) Tj = 125 °C; typical values Fig. 11. Normalized holding current as a function of junction temperature (2) Tj = 125 °C; maximum values (3) Tj = 25 °C; maximum values Fig. 12. On-state current as a function of on-state voltage BT148W-600R Product data sheet All information provided in this document is subject to legal disclaimers. 2 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 9 / 15 BT148W-600R NXP Semiconductors SCR aaa-011905 1.6 VGT VGT(25°C) aaa-011907 103 dVD/dt (V/µs) 1.2 (1) 102 0.8 10 0.4 0 -50 0 50 100 Tj (°C) 1 150 0 50 100 Tj (°C) 150 (1) RGK = 100 Ω Fig. 13. Normalized gate trigger voltage as a function of junction temperature Fig. 14. Critical rate of rise of off-state voltage as a function of junction temperature; typical values BT148W-600R Product data sheet All information provided in this document is subject to legal disclaimers. 2 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 10 / 15 BT148W-600R NXP Semiconductors SCR 11. Package outline Plastic surface-mounted package with increased heatsink; 4 leads D SOT223 E B A X c y HE v M A b1 4 Q A A1 1 2 e1 3 Lp bp w M B detail X e 0 2 4 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp b1 c D E e e1 HE Lp Q v w y mm 1.8 1.5 0.10 0.01 0.80 0.60 3.1 2.9 0.32 0.22 6.7 6.3 3.7 3.3 4.6 2.3 7.3 6.7 1.1 0.7 0.95 0.85 0.2 0.1 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT223 JEITA SC-73 EUROPEAN PROJECTION ISSUE DATE 04-11-10 06-03-16 Fig. 15. Package outline SC-73 (SOT223) BT148W-600R Product data sheet All information provided in this document is subject to legal disclaimers. 2 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 11 / 15 BT148W-600R NXP Semiconductors SCR 12. Soldering 7 3.85 3.6 3.5 0.3 1.3 1.2 (4×) (4×) solder lands 4 solder resist 3.9 6.1 7.65 solder paste occupied area 1 2 3 Dimensions in mm 2.3 2.3 1.2 (3×) 1.3 (3×) 6.15 sot223_fr Fig. 16. Reflow soldering footprint for SC-73 (SOT223) 8.9 6.7 1.9 solder lands 4 solder resist 6.2 1 2 8.7 Dimensions in mm 3 1.9 (3×) 2.7 occupied area preferred transport direction during soldering 2.7 1.1 1.9 (2×) sot223_fw Fig. 17. Wave soldering footprint for SC-73 (SOT223) BT148W-600R Product data sheet All information provided in this document is subject to legal disclaimers. 2 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 12 / 15 BT148W-600R NXP Semiconductors SCR In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. 13. Legal information 13.1 Data sheet status Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 13.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. NXP Semiconductors takes no responsibility for the content in this document if provided by an information source outside of NXP Semiconductors. BT148W-600R Product data sheet Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors and its suppliers accept no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the All information provided in this document is subject to legal disclaimers. 2 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 13 / 15 BT148W-600R NXP Semiconductors SCR grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Bitsound, CoolFlux, CoReUse, DESFire, FabKey, GreenChip, HiPerSmart, HITAG, I²C-bus logo, ICODE, I-CODE, ITEC, MIFARE, MIFARE Plus, MIFARE Ultralight, SmartXA, STARplug, TOPFET, TrenchMOS, TriMedia and UCODE — are trademarks of NXP Semiconductors N.V. HD Radio and HD Radio logo — are trademarks of iBiquity Digital Corporation. BT148W-600R Product data sheet All information provided in this document is subject to legal disclaimers. 2 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 14 / 15 BT148W-600R NXP Semiconductors SCR 14. Contents 1 General description ............................................... 1 2 Features and benefits ............................................1 3 Applications ........................................................... 1 4 Quick reference data ............................................. 1 5 Pinning information ............................................... 2 6 Ordering information ............................................. 2 7 Marking ................................................................... 2 8 Limiting values .......................................................3 9 Thermal characteristics .........................................6 10 Characteristics ....................................................... 8 11 Package outline ................................................... 11 12 Soldering .............................................................. 12 13 13.1 13.2 13.3 13.4 Legal information .................................................13 Data sheet status ............................................... 13 Definitions ...........................................................13 Disclaimers .........................................................13 Trademarks ........................................................ 14 © NXP Semiconductors N.V. 2014. All rights reserved For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 2 December 2014 BT148W-600R Product data sheet All information provided in this document is subject to legal disclaimers. 2 December 2014 © NXP Semiconductors N.V. 2014. All rights reserved 15 / 15
BT148W-600R,115 价格&库存
很抱歉,暂时无法提供与“BT148W-600R,115”相匹配的价格&库存,您可以联系我们找货
