BT258X-500R,127
BT258X-500R,127
    WEEN(瑞能)
    TO-220-3
    SCR 500V 8A Sensitive Gate Through Hole TO-220-3
BT258X-500R,127 数据手册
DISCRETE SEMICONDUCTORS DATA SHEET BT258X series Thyristors logic level Product specification September 2018 WeEn Semiconductors Product specification Thyristors logic level GENERAL DESCRIPTION Passivated, sensitive gate thyristors in a full pack, plastic envelope, intended for use in general purpose switching and phase control applications. These devices are intended to be interfaced directly to microcontrollers, logic integrated circuits and other low power gate trigger circuits. PINNING - SOT186A PIN BT258X series QUICK REFERENCE DATA SYMBOL VDRM, VRRM IT(AV) IT(RMS) ITSM PARAMETER MAX. MAX. MAX. UNIT BT258XRepetitive peak off-state voltages Average on-state current RMS on-state current Non-repetitive peak on-state current 500R 500 600R 600 800R 800 V 5 8 75 5 8 75 5 8 75 A A A PIN CONFIGURATION mb DESCRIPTION 1 cathode 2 anode 3 gate SYMBOL A K G sym037 1 2 3 case isolated TO-220F (SOT186A) LIMITING VALUES Limiting values in accordance with the Absolute Maximum System (IEC 134). SYMBOL PARAMETER CONDITIONS VDRM, VRRM Repetitive peak off-state voltages IT(AV) IT(RMS) ITSM I2t dIT/dt IGM VRGM PGM PG(AV) Tstg Tj Average on-state current RMS on-state current Non-repetitive peak on-state current half sine wave; Ths ≤ 90 ˚C all conduction angles half sine wave; Tj = 25 ˚C prior to surge t = 10 ms t = 8.3 ms t = 10 ms ITM = 10 A; IG = 50 mA; dIG/dt = 50 mA/µs I2t for fusing Repetitive rate of rise of on-state current after triggering Peak gate current Peak reverse gate voltage Peak gate power Average gate power over any 20 ms period Storage temperature Operating junction temperature MIN. MAX. UNIT - -500R -600R -800R 5001 6001 800 V - 5 8 A A - 75 82 28 50 A A A2s A/µs -40 - 2 5 5 0.5 150 1252 A V W W ˚C ˚C 1 Although not recommended, off-state voltages up to 800V may be applied without damage, but the thyristor may switch to the on-state. The rate of rise of current should not exceed 15 A/µs. 2 Note: Operation above 110˚C may require the use of a gate to cathode resistor of 1kΩ or less. September 2018 1 Rev 2.100 WeEn Semiconductors Product specification Thyristors logic level BT258X series ISOLATION LIMITING VALUE & CHARACTERISTIC Ths = 25 ˚C unless otherwise specified SYMBOL PARAMETER CONDITIONS Visol R.M.S. isolation voltage from all three terminals to external heatsink f = 50-60 Hz; sinusoidal waveform; R.H. ≤ 65% ; clean and dustfree Cisol Capacitance from T2 to external f = 1 MHz heatsink MIN. TYP. MAX. UNIT - - 2500 V - 10 - pF MIN. TYP. MAX. UNIT - 55 5.0 6.9 - K/W K/W K/W MIN. TYP. MAX. UNIT 0.1 - 50 0.4 0.3 1.3 0.4 0.2 0.1 200 10 6 1.6 1.5 0.5 µA mA mA V V V mA MIN. TYP. MAX. UNIT 50 100 - V/µs - 2 - µs - 100 - µs THERMAL RESISTANCES SYMBOL PARAMETER CONDITIONS Rth j-hs Thermal resistance junction to heatsink Thermal resistance junction to ambient with heatsink compound without heatsink compound in free air Rth j-a STATIC CHARACTERISTICS Tj = 25 ˚C unless otherwise stated SYMBOL PARAMETER CONDITIONS IGT IL IH VT VGT Gate trigger current Latching current Holding current On-state voltage Gate trigger voltage ID, IR Off-state leakage current VD = 12 V; IT = 0.1 A VD = 12 V; IGT = 0.1 A VD = 12 V; IGT = 0.1 A IT = 16 A VD = 12 V; IT = 0.1 A VD = VDRM(max); IT = 0.1 A; Tj = 110 ˚C VD = VDRM(max); VR = VRRM(max); Tj = 125 ˚C DYNAMIC CHARACTERISTICS Tj = 25 ˚C unless otherwise stated SYMBOL PARAMETER CONDITIONS dVD/dt Critical rate of rise of off-state voltage Gate controlled turn-on time Circuit commutated turn-off time VDM = 67% VDRM(max); Tj = 125 ˚C; exponential waveform; RGK = 100 Ω ITM = 10 A; VD = VDRM(max); IG = 5 mA; dIG/dt = 0.2 A/µs VD = 67% VDRM(max); Tj = 125 ˚C; ITM = 12 A; VR = 24 V; dITM/dt = 10 A/µs; dVD/dt = 2 V/µs; RGK = 1 kΩ tgt tq September 2018 2 Rev 2.100 WeEn Semiconductors Product specification Thyristors logic level BT258X series Ptot (W) Ths(max) (˚C) 85 a = 1.57 90 8 conduction angle degrees 30 60 90 120 180 6 form factor (a) 1.9 4 2.8 2.2 1.9 1.57 2.2 2.8 4 4 2 0 0 4 2 IT(AV) (A) I TSM 70 IT 95 60 100 50 time T Tj initial = 25 C max 105 40 110 30 115 20 120 10 125 0 6 Fig.1. Maximum on-state dissipation, Ptot, versus average on-state current, IT(AV), where a = form factor = IT(RMS)/ IT(AV). 1000 ITSM / A 80 1 10 100 Number of half cycles at 50Hz 1000 Fig.4. Maximum permissible non-repetitive peak on-state current ITSM, versus number of cycles, for sinusoidal currents, f = 50 Hz. ITSM / A 24 IT(RMS) / A 20 16 dI T/dt limit 100 12 I TSM IT 8 time T 4 Tj initial = 25 C max 10 10us 100us 0 0.01 10ms 1ms 0.1 1 surge duration / s T/s Fig.2. Maximum permissible non-repetitive peak on-state current ITSM, versus pulse width tp, for sinusoidal currents, tp ≤ 10ms. 9 Fig.5. Maximum permissible repetitive rms on-state current IT(RMS), versus surge duration, for sinusoidal currents, f = 50 Hz; Ths ≤ 90˚C. IT(RMS) / A 1.6 90 C 8 10 VGT(Tj) VGT(25 C) 1.4 7 6 1.2 5 4 1 3 0.8 2 0.6 1 0 -50 0 50 Ths / C 100 0.4 -50 150 Fig.3. Maximum permissible rms current IT(RMS) , versus mounting base temperature Ths. September 2018 0 50 Tj / C 100 150 Fig.6. Normalised gate trigger voltage VGT(Tj)/ VGT(25˚C), versus junction temperature Tj. 3 Rev 2.100 WeEn Semiconductors Product specification Thyristors logic level 3 BT258X series IGT(Tj) IGT(25 C) I /A 30 T Tj = 125 °C Tj = 25 °C 2.5 20 2 1.5 typ 10 1 max Vo = 1 V Rs = 0.04 Ω 0.5 0 -50 0 0 50 Tj / C 100 150 Fig.7. Normalised gate trigger current IGT(Tj)/ IGT(25˚C), versus junction temperature Tj. 3 IL(Tj) IL(25 C) 0 0.5 1 VT / V 1.5 2 Fig.10. Typical and maximum on-state characteristic. 10 BT150 Zth j-hs (K/W) without heatsink compound 2.5 with heatsink compound 1 2 1.5 0.1 1 P D t p t 0.5 0 -50 0 50 Tj / C 100 0.01 10us 150 1ms 10ms 0.1s 1s 10s tp / s Fig.8. Normalised latching current IL(Tj)/ IL(25˚C), versus junction temperature Tj. 3 0.1ms Fig.11. Transient thermal impedance Zth j-hs, versus pulse width tp. IH(Tj) IH(25 C) 1000 dVD/dt (V/us) RGK = 100 ohms 2.5 100 2 1.5 10 1 0.5 0 -50 0 50 Tj / C 100 1 150 50 100 150 Tj / C Fig.9. Normalised holding current IH(Tj)/ IH(25˚C), versus junction temperature Tj. September 2018 0 Fig.12. Typical, critical rate of rise of off-state voltage, dVD/dt versus junction temperature Tj. 4 Rev 2.100 WeEn Semiconductors Product specification Thyristors logic level BT258X series MECHANICAL DATA September 2018 5 Rev 2.100 WeEn Semiconductors Legal information Data sheet status Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ween-semi.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. WeEn Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local WeEn Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between WeEn Semiconductors and its customer, unless WeEn Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the WeEn Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, WeEn Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. WeEn Semiconductors takes no responsibility for the content in this document if provided by an information source outside of WeEn Semiconductors. In no event shall WeEn Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges whether or not such damages are based on tort (including negligence, warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, WeEn Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of WeEn Semiconductors. Right to make changes — WeEn Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — WeEn Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an WeEn Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. WeEn Semiconductors and its suppliers accept no liability for inclusion and/or use of WeEn Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. WeEn Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using WeEn Semiconductors products, and WeEn Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the WeEn Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. WeEn Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using WeEn Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). WeEn does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific WeEn Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. WeEn Semiconductors accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without WeEn Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond WeEn Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies WeEn Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond WeEn Semiconductors’ standard warranty and WeEn Semiconductors’ product specifications. WeEn Semiconductors Translations — A non-English (translated version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners.
BT258X-500R,127 价格&库存
很抱歉,暂时无法提供与“BT258X-500R,127”相匹配的价格&库存,您可以联系我们找货
