ACT102H-600D,118
ACT102H-600D,118
    WEEN(瑞能)
    SOIC-8
    TRIAC SENS GATE 600V 0.2A 8SO
ACT102H-600D,118 数据手册
ACT102H-600D AC Thyristor power switch 21 August 2017 Product data sheet 1. General description An AC Thyristor power switch with very high noise immunity and over-voltage protection configured for negative gate triggering in a SOT96-1 (SO8) small surface-mountable plastic package 2. Features and benefits • • • • • • • • Exclusive negative gate triggering Full cycle AC conduction High noise immunity Remote gate separates the gate driver from the effects of the load current Surface-mountable package Very sensitive gate for lowest gate trigger current Safe clamping of low energy over-voltage transients Self-protective turn-on during high energy voltage transients 3. Applications • • • Fan motor circuits Pump motor circuits Lower-power highly inductive, resistive and safety loads 4. Quick reference data Table 1. Quick reference data Symbol Parameter VDRM repetitive peak offstate voltage IT(RMS) RMS on-state current ITSM Min Typ Max Unit - - 600 V - - 0.2 A non-repetitive peak on- full sine wave; Tj(init) = 25 °C; tp = 16.7 ms state current - - 8.8 A full sine wave; Tj(init) = 25 °C; tp = 20 ms; Fig. 3; Fig. 4 - - 8 A - - 125 °C Tj = 25 °C; non-repetitive, off-state; Fig. 5 - - 2 kV VD = 12 V; IT = 100 mA; LD+ G-; Tj = 25 °C; Fig. 7 0.5 - 5 mA Tj junction temperature VPP peak pulse voltage Conditions full sine wave; Tamb ≤ 100 °C; Fig. 1; Fig. 2 Static characteristics IGT gate trigger current ACT102H-600D WeEn Semiconductors AC Thyristor power switch Symbol Parameter Conditions Min Typ Max Unit VD = 12 V; IT = 100 mA; LD- G-; Tj = 25 °C; Fig. 7 0.5 - 5 mA IH holding current VD = 12 V; Tj = 25 °C; Fig. 9 - - 20 mA VT on-state voltage IT = 0.3 A; Tj = 25 °C; Fig. 10 - - 1.2 V VCL clamping voltage ICL = 0.1 mA; tp = 1 ms; Tj = 125 °C 650 - - V Dynamic charateristics dVD/dt rate of rise of off-state voltage VDM = 402 V; Tj = 125 °C; (VDM = 67% of VDRM); exponential waveform; gate open circuit; Fig. 11 300 - - V/µs dIcom/dt rate of change of commutating current VD = 400 V; Tj = 125 °C; IT(RMS) = 1 A; dVcom/dt = 15 V/µs; gate open circuit; Fig. 12; Fig. 13 0.15 - - A/ms 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 n.c. not connected 2 LD Load 3 n.c. not connected 4 n.c. not connected 5 G Gate 6 CM Common 7 CM Common 8 n.c. not connected Simplified outline 8 Graphic symbol 5 LD G CM 1 001aaj924 4 SO8 (SOT96-1) 6. Ordering information Table 3. Ordering information Type number ACT102H-600D ACT102H-600D Product data sheet Package Name Description Version SO8 plastic small outline package; 8 leads; body width 3.9 mm SOT96-1 All information provided in this document is subject to legal disclaimers. 21 August 2017 © WeEn Semiconductors Co., Ltd. 2017. All rights reserved 2 / 13 ACT102H-600D WeEn Semiconductors AC Thyristor power switch 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDRM repetitive peak off-state voltage IT(RMS) RMS on-state current ITSM non-repetitive peak onstate current 2 Conditions 2 Min Max Unit - 600 V full sine wave; Tamb ≤ 100 °C; Fig. 1; Fig. 2 - 0.2 A full sine wave; Tj(init) = 25 °C; tp = 16.7 ms - 8.8 A full sine wave; Tj(init) = 25 °C; tp = 20 ms; Fig. 3; Fig. 4 - 8 A I t I t for fusing tp = 10 ms; SIN - 0.31 A²s dIT/dt rate of rise of on-state current IG = 10 mA - 50 A/µs IGM peak gate current t = 20 μs - 1 A PGM peak gate power - 2 W PG(AV) average gate power - 0.1 W Tstg storage temperature -40 150 °C Tj junction temperature - 125 °C VPP peak pulse voltage - 2 kV over any 20 ms period Tj = 25 °C; non-repetitive, off-state; Fig. 5 003aaf739 0.20 Ptot (W) α α = 180° 0.16 α 0.12 0.08 0.04 0 0 0.04 0.08 0.12 0.16 IT(RMS) (A) 0.20 α = conduction angle Fig. 1. Total power dissipation as a function of RMS on-state current; maximum values ACT102H-600D Product data sheet All information provided in this document is subject to legal disclaimers. 21 August 2017 © WeEn Semiconductors Co., Ltd. 2017. All rights reserved 3 / 13 ACT102H-600D WeEn Semiconductors AC Thyristor power switch 003aaf740 0.24 IT(RMS) (A) 0.20 0.16 0.12 0.08 0.04 0 - 50 0 50 100 Ta (°C) 150 Fig. 2. RMS on-state current as a function of solder point temperature; maximum values 003aac804 10 ITSM (A) 8 6 4 ITSM IT t 2 1/f 0 Tj(init) = 25 °C max 1 102 10 number of cycles 103 f = 50 Hz Fig. 3. Non-repetitive peak on-state current as a function of the number of sinusoidal current cycles; maximum values ACT102H-600D Product data sheet All information provided in this document is subject to legal disclaimers. 21 August 2017 © WeEn Semiconductors Co., Ltd. 2017. All rights reserved 4 / 13 ACT102H-600D WeEn Semiconductors AC Thyristor power switch 003aaf756 103 ITSM IT ITSM (A) t tp 102 Tj(init) = 25 °C max 10 1 10- 5 10- 4 10- 3 10- 2 tp (s) 10- 1 tp ≤ 20 ms Fig. 4. Non-repetitive peak on-state current as a function of pulse width; maximum values IEC 61000-4-5 Standards Surge Generator Open Circuit Voltage 1.2 µs/50 µs waveform RGen R L 2Ω 150 Ω 5 µH Surge pulse Load Model RG DUT 220 Ω 003aad077 Fig. 5. Test circuit for inductive and resistive loads with conditions equivalent to IEC 61000-4-5 ACT102H-600D Product data sheet All information provided in this document is subject to legal disclaimers. 21 August 2017 © WeEn Semiconductors Co., Ltd. 2017. All rights reserved 5 / 13 ACT102H-600D WeEn Semiconductors AC Thyristor power switch 8. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-a) thermal resistance from junction to ambient free air full cycle; Fig. 6 - 150 - K/W 003aaf741 103 Zth(j-a) (K/W) 102 10 P tp 1 10- 3 10- 2 10- 1 1 102 10 tp (s) t 103 Fig. 6. Transient thermal impedance from junction to ambient as a function of pulse width ACT102H-600D Product data sheet All information provided in this document is subject to legal disclaimers. 21 August 2017 © WeEn Semiconductors Co., Ltd. 2017. All rights reserved 6 / 13 ACT102H-600D WeEn Semiconductors AC Thyristor power switch 9. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit VD = 12 V; IT = 100 mA; LD+ G-; Tj = 25 °C; Fig. 7 0.5 - 5 mA VD = 12 V; IT = 100 mA; LD- G-; Tj = 25 °C; Fig. 7 0.5 - 5 mA VD = 12 V; IG = 100 mA; LD+ G-; Tj = 25 °C; Fig. 8 - - 25 mA VD = 12 V; IG = 100 mA; LD- G-; Tj = 25 °C; Fig. 8 - - 25 mA Static characteristics IGT gate trigger current IL latching current IH holding current VD = 12 V; Tj = 25 °C; Fig. 9 - - 20 mA VT on-state voltage IT = 0.3 A; Tj = 25 °C; Fig. 10 - - 1.2 V VGT gate trigger voltage VD = 400 V; IT = 100 mA; Tj = 125 °C 0.15 - - V VD = 12 V; IT = 100 mA; Tj = 25 °C - - 0.9 V VD = 600 V; Tj = 25 °C - - 2 µA VD = 600 V; Tj = 125 °C - - 0.2 mA ICL = 0.1 mA; tp = 1 ms; Tj = 125 °C 650 - - V ID off-state current VCL clamping voltage Dynamic charateristics dVD/dt rate of rise of off-state voltage VDM = 402 V; Tj = 125 °C; (VDM = 67% of VDRM); exponential waveform; gate open circuit; Fig. 11 300 - - V/µs dIcom/dt rate of change of commutating current VD = 400 V; Tj = 125 °C; IT(RMS) = 1 A; dVcom/dt = 15 V/µs; gate open circuit; Fig. 12; Fig. 13 0.15 - - A/ms 003aac809 3 IGT IGT(25°C) 2 003aac811 3 IL IL(25°C) (1) 2 (2) 1 1 (2) 0 - 50 (1) 0 50 100 Tj (°C) (1) LD+ G(2) LD- GFig. 7. Normalized gate trigger current as a function of junction temperature ACT102H-600D Product data sheet 0 - 50 150 0 50 100 Tj (°C) 150 Fig. 8. Normalized latching current as a function of junction temperature All information provided in this document is subject to legal disclaimers. 21 August 2017 © WeEn Semiconductors Co., Ltd. 2017. All rights reserved 7 / 13 ACT102H-600D WeEn Semiconductors AC Thyristor power switch 003aac810 3 003aaf722 2.0 IT (A) IH IH(25°C) 1.5 2 1.0 (1) 1 (2) (3) 0.5 0 - 50 0 50 100 Tj (°C) 0.0 0.0 150 0.5 1.0 1.5 VT (V) 2.0 Vo = 0.758 V; Rs = 0.263 Ω (1) Tj = 125 °C; typical values (2) Tj = 125 °C; maximum values (3) Tj = 25 °C; maximum values Fig. 9. Normalized holding current as a function of junction temperature Fig. 10. On-state current as a function of on-state voltage A B 003aac813 12 003aac814 12 A B 10 8 8 6 4 4 2 0 25 50 75 100 Tj (°C) 0 125 A = dVD/dt at condition Tj °C B = dVD/dt at condition Tj [125] °C Fig. 11. Normalized rate of rise of off-state voltage as a function of junction temperature ACT102H-600D Product data sheet 25 50 75 100 Tj (°C) 125 A = dIcom/dt at condition Tj °C B = dIcom/dt at condition Tj [125] °C VD = 400 V Fig. 12. Normalized critical rate of rise of commutating current as a function of junction temperature All information provided in this document is subject to legal disclaimers. 21 August 2017 © WeEn Semiconductors Co., Ltd. 2017. All rights reserved 8 / 13 ACT102H-600D WeEn Semiconductors AC Thyristor power switch 003aac815 2.0 A [B] A [spec] 1.5 1.0 0.5 0 10- 1 1 10 B (V/µs) 102 A [B] = dIcom/dt at condition B, dVcom/dt A [spec] is the data sheet value for dIcom/dt turn-off time is less than 20 ms Fig. 13. Normalized critical rate of change of commutating current as a function of critical rate of change of commutating voltage; minimum values ACT102H-600D Product data sheet All information provided in this document is subject to legal disclaimers. 21 August 2017 © WeEn Semiconductors Co., Ltd. 2017. All rights reserved 9 / 13 ACT102H-600D WeEn Semiconductors AC Thyristor power switch 10. Package outline SO8 Gauge plane Plastic small outline package; 8 leads D 0.25 L (L1) E E1 c b e A A2 A1 Note: 1. All dimensions don't include mold flash and metal protrusion. Fig. 14. Package outline SO8 (SOT96-1) ACT102H-600D Product data sheet All information provided in this document is subject to legal disclaimers. 21 August 2017 © WeEn Semiconductors Co., Ltd. 2017. All rights reserved 10 / 13 ACT102H-600D WeEn Semiconductors AC Thyristor power switch Right to make changes — WeEn Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 11. Legal information Suitability for use — WeEn Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an WeEn Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. WeEn Semiconductors and its suppliers accept no liability for inclusion and/or use of WeEn Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. WeEn Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ween-semi.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. WeEn Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local WeEn Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between WeEn Semiconductors and its customer, unless WeEn Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the WeEn Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, WeEn Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. WeEn Semiconductors takes no responsibility for the content in this document if provided by an information source outside of WeEn Semiconductors. In no event shall WeEn Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, WeEn Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of WeEn Semiconductors. ACT102H-600D Product data sheet Customers are responsible for the design and operation of their applications and products using WeEn Semiconductors products, and WeEn Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the WeEn Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. WeEn Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using WeEn Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). WeEn does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific WeEn Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. WeEn Semiconductors accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without WeEn Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond WeEn Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies WeEn Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond WeEn Semiconductors’ standard warranty and WeEn Semiconductors’ product specifications. All information provided in this document is subject to legal disclaimers. 21 August 2017 © WeEn Semiconductors Co., Ltd. 2017. All rights reserved 11 / 13 ACT102H-600D WeEn Semiconductors AC Thyristor power switch Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. ACT102H-600D Product data sheet All information provided in this document is subject to legal disclaimers. 21 August 2017 © WeEn Semiconductors Co., Ltd. 2017. All rights reserved 12 / 13 ACT102H-600D WeEn Semiconductors AC Thyristor power switch 12. Contents 1. General description......................................................1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Limiting values............................................................. 3 8. Thermal characteristics............................................... 6 9. Characteristics..............................................................7 10. Package outline........................................................ 10 11. Legal information..................................................... 11 © WeEn Semiconductors Co., Ltd. 2017. All rights reserved For more information, please visit: http://www.ween-semi.com For sales office addresses, please send an email to: salesaddresses@ween-semi.com Date of release: 21 August 2017 ACT102H-600D Product data sheet All information provided in this document is subject to legal disclaimers. 21 August 2017 © WeEn Semiconductors Co., Ltd. 2017. All rights reserved 13 / 13
ACT102H-600D,118 价格&库存
很抱歉,暂时无法提供与“ACT102H-600D,118”相匹配的价格&库存,您可以联系我们找货
