Z0109NN0
4Q Triac
15 September 2018
Product data sheet
1. General description
Planar passivated sensitive gate four quadrant triac in a SOT223 (SC-73) surface-mountable
plastic package intended for applications requiring enhanced immunity to noise and direct
interfacing to logic level ICs and low power gate drivers.
2. Features and benefits
Direct interfacing to logic level ICs
Enhanced current surge capability
Enhanced noise immunity
High blocking voltage capability
Planar passivated for voltage ruggedness and reliability
Sensitive gate in four quadrants
Surface-mountable package
Triggering in all four quadrants
3. Applications
General purpose low power motor control
Home appliances
Industrial process control
Low power AC Fan controllers
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
VDRM
repetitive peak offstate voltage
IT(RMS)
RMS on-state current
ITSM
Tj
Conditions
Min
Typ
Max
Unit
800
V
1
A
non-repetitive peak on- full sine wave; Tj(init) = 25 °C;
tp = 20 ms; Fig. 4; Fig. 5
state current
12.5
A
tp = 16.7 ms
13.8
A
125
°C
0.4
10
mA
full sine wave; Tsp ≤ 105 °C; Fig. 1;
Fig. 2; Fig. 3
junction temperature
Static characteristics
IGT
gate trigger current
VD = 12 V; IT = 0.1 A; T2+ G+;
Tj = 25 °C; Fig. 9
Z0109NN0
WeEn Semiconductors
4Q Triac
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VD = 12 V; IT = 0.1 A; T2+ G-;
Tj = 25 °C; Fig. 9
0.4
10
mA
VD = 12 V; IT = 0.1 A; T2- G-;
Tj = 25 °C; Fig. 9
0.4
10
mA
VD = 12 V; IT = 0.1 A; T2- G+;
Tj = 25 °C; Fig. 9
0.4
10
mA
IH
holding current
VD = 12 V; Tj = 25 °C; Fig. 11
10
mA
VT
on-state voltage
IT = 1.4 A; Tj = 25 °C; Fig. 12
1.3
1.6
V
Dynamic characteristics
dVD/dt
rate of rise of off-state
voltage
VDM = 536 V; Tj = 110 °C; (VDM = 67%
of VDRM); exponential waveform; gate
open circuit; Fig. 14
120
V/µs
dVcom/dt
rate of change of
commutating voltage
VD = 400 V; Tj = 110 °C; dIcom/
dt = 0.44 A/ms; gate open circuit
2
V/µs
5. Pinning information
Table 2. Pinning information
Pin
Symbol Description
1
T1
main terminal 1
2
T2
main terminal 2
3
G
gate
4
T2
main terminal 2
Simplified outline
Graphic symbol
4
T2
sym051
1
2
T1
G
3
SC-73 (SOT223)
6. Ordering information
Table 3. Ordering information
Type number
Z0109NN0
Z0109NN0
Product data sheet
Package
Name
Description
Version
SC-73
plastic surface-mounted package with increased heatsink; 4
leads
SOT223
All information provided in this document is subject to legal disclaimers.
15 September 2018
WeEn Semiconductors Co., Ltd. 2018. All rights reserved
2 / 14
Z0109NN0
WeEn Semiconductors
4Q Triac
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VDRM
repetitive peak off-state
voltage
IT(RMS)
ITSM
non-repetitive peak onstate current
2
Conditions
2
Min
Max
Unit
800
V
full sine wave; Tsp ≤ 105 °C; Fig. 1; Fig. 2;
Fig. 3
1
A
full sine wave; Tj(init) = 25 °C; tp = 20 ms;
Fig. 4; Fig. 5
12.5
A
full sine wave; Tj(init) = 25 °C; tp = 16.7 ms
13.8
A
I t
I t for fusing
tp = 10 ms; SIN
0.78
A²s
dIT/dt
rate of rise of on-state
current
IG = 20 mA; T2+ G+
50
A/µs
IG = 20 mA; T2+ G-
50
A/µs
IG = 20 mA; T2- G-
50
A/µs
IG = 20 mA; T2- G+
A/µs
IGM
peak gate current
1
A
PGM
peak gate power
2
W
PG(AV)
average gate power
0.1
W
Tstg
storage temperature
-40
150
°C
Tj
125
°C
over any 20 ms period
003a a c270
1.2
003aac269
8
IT(RMS)
I T(RMS)
(A)
(A)
6
0.8
4
0.4
2
100
150
Ts p (°C)
Fig. 1. RMS on-state current as a function of solder
point temperature; maximum values
Z0109NN0
Product data sheet
10-1
1
10
surge duration (s)
f = 50 Hz; Tsp = 105 °C
Fig. 2. RMS on-state current as a function of surge
duration; maximum values
15 September 2018
3 / 14
Z0109NN0
WeEn Semiconductors
4Q Triac
003aac259
2.0
Ptot
(W)
1.6
1.2
conduction
angle, α
(degrees)
form
factor
a
30
60
90
120
180
2.816
1.967
1.570
1.329
1.110
α
α = 180°
α
120 °
90°
60°
0.8
30 °
0.4
0.0
0.4
0.6
0.8
1
1.2
I T(RMS ) (A)
α = conduction angle
a = form factor = IT(RMS) / IT(AV)
Fig. 3. Total power dissipation as a function of RMS on-state current; maximum values
003aaf449
16
ITSM
(A)
12
8
ITSM
IT
4
t
1/f
Tj(init) = 25 °C max
1
102
10
number of cycles
103
f = 50 Hz
Fig. 4. Non-repetitive peak on-state current as a function of the number of sinusoidal current cycles; maximum
values
Z0109NN0
Product data sheet
15 September 2018
4 / 14
Z0109NN0
WeEn Semiconductors
4Q Triac
003aaf490
103
ITSM
IT
ITSM
(A)
t
tp
102
(1)
(2)
10
1
10- 5
10- 4
10- 3
10- 2
tp (s)
10- 1
tp ≤ 20 ms
(1) dIT/dt limit
(2) T2- G+ quadrant limit
Fig. 5. Non-repetitive peak on-state current as a function of pulse width; maximum values
Z0109NN0
Product data sheet
15 September 2018
5 / 14
Z0109NN0
WeEn Semiconductors
4Q Triac
8. Thermal characteristics
Table 5. Thermal characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-sp)
thermal resistance
from junction to solder
point
full cycle; Fig. 6
15
K/W
Rth(j-a)
thermal resistance
from junction to
ambient free air
in free air; printed-circuit board
mounted: minimum footprint; full cycle;
Fig. 7
156
K/W
mounted: pad area; full cycle; Fig. 8
70
K/W
003aac210
102
Z th(j-sp)
(K/W)
10
1
P
10-1
10
-2
10-5
tp
10-4
10-3
10-2
10-1
1
tp (s)
t
10
Fig. 6. Transient thermal impedance from junction to solder point as a function of pulse width
Z0109NN0
Product data sheet
15 September 2018
6 / 14
Z0109NN0
WeEn Semiconductors
4Q Triac
3.8 min
36
1.5
min
18
6.3
1.5
min
(3×)
60
9
4.5
4.6
2.3
10
1.5
min
4.6
001aab508
7
All dimensions are in mm
15
Fig. 7. Minimum footprint SOT223
50
001aab509
Printed circuit board:
FR4 epoxy glass (1.6 mm thick), copper laminate
(35 um thick)
Fig. 8. Printed circuit board pad area: SOT223
Z0109NN0
Product data sheet
15 September 2018
7 / 14
Z0109NN0
WeEn Semiconductors
4Q Triac
9. Characteristics
Table 6. Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Tj = 25 °C; Fig. 9
0.4
10
mA
Tj = 25 °C; Fig. 9
0.4
10
mA
Tj = 25 °C; Fig. 9
0.4
10
mA
Tj = 25 °C; Fig. 9
0.4
10
mA
VD = 12 V; IG = 0.1 A; T2+ G+;
Tj = 25 °C; Fig. 10
15
mA
VD = 12 V; IG = 0.1 A; T2+ G-;
Tj = 25 °C; Fig. 10
30
mA
VD = 12 V; IG = 0.1 A; T2- G-;
Tj = 25 °C; Fig. 10
15
mA
VD = 12 V; IG = 0.1 A; T2- G+;
Tj = 25 °C; Fig. 10
15
mA
IGT
IL
latching current
IH
holding current
10
mA
VT
on-state voltage
1.3
1.6
V
VGT
gate trigger voltage
VD = 12 V; IT = 0.1 A; Tj = 25 °C;
Fig. 13
1
V
VD = 800 V; IT = 0.1 A; Tj = 125 °C;
Fig. 13
0.2
V
VD = 800 V; Tj = 125 °C
0.5
mA
ID
off-state current
dVD/dt
voltage
120
V/µs
dVcom/dt
rate of change of
commutating voltage
2
V/µs
Z0109NN0
Product data sheet
15 September 2018
8 / 14
Z0109NN0
WeEn Semiconductors
4Q Triac
003aaa205
4
003aaa203
3
IGT
IL
IGT(25°C)
IL(25°C)
3
(1)
(2)
2
(3)
(4)
2
1
1
100
Tj (°C)
150
(1) T2- G+
(2) T2- G(3) T2+ G(4) T2+ G+
100
Tj (°C)
150
Fig. 10. Normalized latching current as a function of
Fig. 9. Normalized gate trigger current as a function of
003aaa204
3
IT
(A)
IH
IH(25°C)
003aac258
2
1.6
2
1.2
0.8
(1)
1
(2)
(3)
0.4
100
Tj (°C)
0.8
1.2
1.6
VT (V)
2
Vo = 1.13 V
Rs = 0.31 Ω
(1) Tj = 125 °C; typical values
(2) Tj = 125 °C; maximum values
(3) Tj = 25 °C; maximum values
Fig. 11. Normalized holding current as a function of
Fig. 12. On-state current as a function of on-state
voltage
Z0109NN0
Product data sheet
15 September 2018
9 / 14
Z0109NN0
WeEn Semiconductors
4Q Triac
003aaa209
1.6
VGT
A
VGT(25°C)
1.2
1.2
0.8
0.8
0.4
0.4
003aaa208
1.6
100
Tj (°C)
100
Tj (°C)
150
Fig. 13. Normalized gate trigger voltage as a function of
Fig. 14. Normalized critical rate of rise of off-state
voltage as a function of junction temperature; typical
values
Z0109NN0
Product data sheet
15 September 2018
10 / 14
Z0109NN0
WeEn Semiconductors
4Q Triac
10. Package outline
Plastic surface-mounted package with increased heatsink; 4 leads
D
SOT223
E
B
A
X
c
y
HE
v M A
b1
4
Q
A
A1
1
2
e1
3
Lp
bp
w M B
detail X
e
4 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
bp
b1
c
D
E
e
e1
HE
Lp
Q
v
w
y
mm
1.8
1.5
0.10
0.01
0.80
0.60
3.1
2.9
0.32
0.22
6.7
6.3
3.7
3.3
4.6
2.3
7.3
6.7
1.1
0.7
0.95
0.85
0.2
0.1
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT223
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
04-11-10
06-03-16
SC-73
Fig. 15. Package outline SC-73 (SOT223)
Z0109NN0
Product data sheet
15 September 2018
11 / 14
Z0109NN0
WeEn Semiconductors
4Q Triac
Right to make changes — WeEn Semiconductors reserves the right to
make changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
11. Legal information
Data sheet status
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. WeEn Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences
of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local WeEn
Semiconductors sales office. In case of any inconsistency or conflict with the
short data sheet, the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
WeEn Semiconductors and its customer, unless WeEn Semiconductors and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the WeEn Semiconductors product
is deemed to offer functions and qualities beyond those described in the
Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, WeEn Semiconductors does not
give any representations or warranties, expressed or implied, as to the
accuracy or completeness of such information and shall have no liability for
the consequences of use of such information. WeEn Semiconductors takes
no responsibility for the content in this document if provided by an information
source outside of WeEn Semiconductors.
In no event shall WeEn Semiconductors be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, WeEn Semiconductors’ aggregate and cumulative liability
towards customer for the products described herein shall be limited in
accordance with the Terms and conditions of commercial sale of WeEn
Semiconductors.
Product data sheet
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. WeEn Semiconductors makes
no representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.ween-semi.com.
Z0109NN0
Suitability for use — WeEn Semiconductors products are not designed,
authorized or warranted to be suitable for use in life support, life-critical
or safety-critical systems or equipment, nor in applications where failure
or malfunction of an WeEn Semiconductors product can reasonably
be expected to result in personal injury, death or severe property or
environmental damage. WeEn Semiconductors and its suppliers accept no
liability for inclusion and/or use of WeEn Semiconductors products in such
equipment or applications and therefore such inclusion and/or use is at the
customer’s own risk.
Customers are responsible for the design and operation of their applications
and products using WeEn Semiconductors products, and WeEn
Semiconductors accepts no liability for any assistance with applications or
customer product design. It is customer’s sole responsibility to determine
whether the WeEn Semiconductors product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products.
WeEn Semiconductors does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default
in the customer’s applications or products, or the application or use by
customer’s third party customer(s). Customer is responsible for doing all
necessary testing for the customer’s applications and products using WeEn
Semiconductors products in order to avoid a default of the applications
and the products or of the application or use by customer’s third party
customer(s). WeEn does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific WeEn Semiconductors product is automotive
qualified, the product is not suitable for automotive use. It is neither qualified
nor tested in accordance with automotive testing or application requirements.
WeEn Semiconductors accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without WeEn Semiconductors’ warranty
of the product for such automotive applications, use and specifications, and
(b) whenever customer uses the product for automotive applications beyond
WeEn Semiconductors’ specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies WeEn Semiconductors for
any liability, damages or failed product claims resulting from customer
design and use of the product for automotive applications beyond WeEn
Semiconductors’ standard warranty and WeEn Semiconductors’ product
specifications.
15 September 2018
12 / 14
Z0109NN0
WeEn Semiconductors
4Q Triac
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Z0109NN0
Product data sheet
15 September 2018
13 / 14
Z0109NN0
WeEn Semiconductors
4Q Triac
12. Contents
1. General description......................................................1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................2
6. Ordering information....................................................2
7. Limiting values............................................................. 3
8. Thermal characteristics............................................... 6
9. Characteristics..............................................................8
10. Package outline........................................................ 11
11. Legal information..................................................... 12
For more information, please visit: http://www.ween-semi.com
For sales office addresses, please send an email to: salesaddresses@ween-semi.com
Date of release: 15 September 2018
Z0109NN0
Product data sheet
15 September 2018
14 / 14
