BOK-13997
BOK-13997
    SPARKFUNELECTRONICS
    MAKEYOUROWNPCBSWITHEAGLE
BOK-13997 数据手册
Make Your Own PCBs with Eagle BOK-13997 Description: Learn how to make double-sided, professional-quality PCBs from the ground up using Eagle – the powerful, flexible design software. In this step-by-step guide, electronics guru Simon Monk leads you through the process of designing a schematic, transforming it into a PCB layout, and submitting standard Gerber files to a manufacturing service to create your finished board. Filled with detailed illustrations, photos and screenshots, “Make Your Own PCBs with Eagle” features downloadable example projects so you can get started right away. Install Eagle Light Edition and discover the views and screens that make up an Eagle project Create the schematic and board files for a simple LED project Find the right components and libraries for your projects Work with the Schematic Editor Lay out PCBs with through-hole components and with surface-mount technology Build a sound level meter with a small amplifier and 10 LEDs Generate Gerber design files to submit for fabrication Solder through-hole PCBs and SMD boards Design a plug-in Arduino shield Build a Raspberry Pi expansion board Automate repetitive tasks using scripts and User Language Programs Create your own libraries and parts, and modify existing components Info: Author: Simon Monk Publisher: McGraw-Hill / TAB Electronics Paperback: 272 pages ISBN 10: 0071819258 ISBN 13: 860-1400849866 SparkFun Electronics ®
BOK-13997 价格&库存
很抱歉,暂时无法提供与“BOK-13997”相匹配的价格&库存,您可以联系我们找货
