122-32335
122-32335
    PARALLAXINC.
    TEXTROBOTICSBOEBOTSHIELDBOT
122-32335 数据手册
    Robotics with the BOE Shield‐Bot for Arduino  Product ID: 122‐32335        122‐32335: Robotics with the Board of Education Shield for Arduino ‐ sample pages  Overview Build a rolling robot with an Arduino Uno microcontroller. Using one of our supported kits below, just follow the clear, step-by-step instructions and illustrations in the beginner-friendly text, Robotics with the BOE Shield-Bot for Arduino. This text was written with hobbyists, robotics summer camps, and grade 7-12 classrooms in mind. Paired with a supported robotics kit, it can be used as a California A-G approved elective course; contact education@parallax.com for details. Supported Kits     Robot Shield with Arduino kit; book is included as of October 2016 (#32335) Robotics Shield Kit (for Arduino); book not included (#130-35000) Boe-Bot to Shield-Bot Retrofit Kit; book not included (#32333) Boe-Bot to Shield-Bot Retrofit Kit with Arduino; book not included (#910-32333) The assembled and programmed robot will be able to navigate by touch, by light, or by infrared distance detection. Each chapter introduces new STEM skills the areas of programming, electronics, robotics, and engineering. A set of questions, exercises, and projects with solutions are included at the end of each chapter. For additional teacher resources, email education@parallax.com. Chapter Topics:         Programming the Arduino microcontroller Calibrating the servo motors and monitoring servo signals with LED lights Assembling and testing the BOE Shield-Bot Navigation basics and pre-programmed maneuvers Tactile navigation with whisker switches Light-sensitive navigation with phototransistors Navigating with infrared headlights for object detection Shadow vehicle navigation with distance detection Publishing Details      Version: 1.0 Publisher: Parallax Inc. ISBN: 978-1-928-98261-6 Dimensions: 7.5 x 8.5 inches (19 x 21.6 cm) page size Spiral-bound softcover/274 pages/black & white print                 https://www.parallax.com/product/122-32335 1/19/2017
122-32335
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
122-32335 价格&库存
很抱歉,暂时无法提供与“122-32335”相匹配的价格&库存,您可以联系我们找货
