9781457187858
9781457187858
    O-REILLYMEDIA
    MAKE: FPGAS
9781457187858 数据手册
Maker Media, Inc Make: FPGAs Turning Software into Hardware with 8 Fun & Easy DIY Projects  David Romano ISBN: 9781457187858 Date Published: 2/25/2016 Pages: 320 Paperback 7.5 in W | 9.3 in H Computers / Logic Design  Summary: What if you could use software to design hardware? Not just any hardware‐‐imagine specifying the behavior of a  complex parallel computer, sending it to a chip, and having it run on that chip‐‐all without any manufacturing? With  Field‐Programmable Gate Arrays (FPGAs), you can design such a machine with your mouse and keyboard. When you  deploy it to the FPGA, it immediately takes on the behavior that you defined. Want to create something that behaves  like a display driver integrated circuit? How about a CPU with an instruction set you dreamed up? Or your very own  Bitcoin miner You can do all this with FPGAs. Because you're not writing programs‐‐rather, you're designing a chip whose sole purpose is to do what you tell it‐‐it's  faster than anything you can do in code. With Make: FPGAs, you'll learn how to break down problems into something  that can be solved on an FPGA, design the logic that will run on your FPGA, and hook up electronic components to  create finished projects.
9781457187858 价格&库存
很抱歉,暂时无法提供与“9781457187858”相匹配的价格&库存,您可以联系我们找货
