DEV-08467
DEV-08467
    SPARKFUNELECTRONICS
    TRI-COLORLED
DEV-08467 数据手册
 LilyPad Tri-Color LED DE V-08 467 RO HS        1  images are CC BY-NC-SA 3.0 3D Download: Sketchup, STL, Blender Description: Blink any color you need! Use the Tri-Color LED board as a simple indicator, or by pulsing the red, green, and blue channels, you can create any color. Very bright output. This is a common anode design - to turn on a channel you simply need to ground one of the R/G/B pins to illuminate that channel. LilyPad is a wearable technology developed by Leah Buechley and cooperatively designed by Leah and SparkFun. Each LilyPad was creatively designed to have large connecting pads to allow them to be sewn into clothing. Various input, output, power, and sensor boards are available. They’re even washable! Note: A portion of this sale is given back to Dr. Leah Buechley for continued development and education of e-textiles. Dimensions: • 20mm outer diameter • Thin 0.8mm PCB https://www.sparkfun.com/products/8467 10/12/2015
DEV-08467 价格&库存
很抱歉,暂时无法提供与“DEV-08467”相匹配的价格&库存,您可以联系我们找货
