DEV-13814
DEV-13814
    SPARKFUNELECTRONICS
    SMOOTH THREAD BOBBIN 12M (STAINL
DEV-13814 数据手册
 Smooth Thread Bobbin - 12m (Stainless Steel) DE V-13 814 RO HS    images are CC BY-NC-SA 3.0 Description: This is 12 meters of smooth conductive thread spun from stainless steel fiber and wound on a plastic bobbin. Use it to sew up all of your e-textile projects. This small bobbin is a great way to get into wearable electronics without the upfront cost of buying an entire spool of thread. Close to 40 feet of thread is enough to get a simple design stitched onto your shirt, backpack or hat. What sets this thread apart from the other conductive thread that we carry is the fact that it’s actually spun from 12UM stainless steel fiber making it incredibly smooth and without the loose hairs seen on other bobbins. This means that while it may not be easy to solder to, because it’s stainless, it also won’t burn up when you touch it with a soldering iron. Suitable for hand or machine sewing (as a bobbin thread). We’ve had no trouble using it for close, tight connections, but if you’re worried, waxing the thread should keep it manageable! Features: • • • • • • Material : 12UM Stainless steel fiber Gram Weight:0.2458g/m Strength:2.8KGF Diameter(mm):0.12 Resistance (Ω/m) : 27 12m per spool (on plastic spools) https://www.sparkfun.com/products/13814 4/12/2016
DEV-13814 价格&库存
很抱歉,暂时无法提供与“DEV-13814”相匹配的价格&库存,您可以联系我们找货
