DEV-13883
DEV-13883
    SPARKFUNELECTRONICS
    DEVLILYPADCOINCELLBATTHOLDR
DEV-13883 数据手册
  LilyPad Coin Cell Battery Holder - Switched 20mm DE V-13 883 RO HS Description: Sure, your flashing, chip-tune playing T-shirt is really cool at the party… but at some point you need to turn it off. And yes, you could just pull the battery, or maybe you’ve even sewn a LilyPad slide switch in-line. Wouldn’t it be nice if there was just a switch on the battery? Well, look no further. This LilyPad Coin Cell Battery Holder has a small slide switch installed on the board, in-line with the power so you can shut off your project and save batteries. This slide switch is the same as on the LilyPad Slide Switch Board, so it’s not easy to accidentally turn off or on. Just like the original Coin Cell Battery Holder, this simple board holds a 20mm coin cell battery (such as a CR2032) and gives you four connection points (two positive and two negative) for sewing into your project. Additionally, we have strengthened the battery connector on this board in order to ensure that it doesn’t accidentally pop off. Note: A portion of this sale is given back to Dr. Leah Buechley for continued development and education of e-textiles. https://www.sparkfun.com/products/13883 11/9/2016
DEV-13883 价格&库存
很抱歉,暂时无法提供与“DEV-13883”相匹配的价格&库存,您可以联系我们找货
