1756
1756
    ADAFRUIT
    ADAFRUIT LED SEQUINS
1756 数据手册
Adafruit LED Sequins - Emerald Green - Pack of 5 PRODUCT ID: 1756 Description Sew a little sparkle into your wearable project with an Adafruit LED Sequin. These are the kid-sister to our popular Flora NeoPixel, they only show a single color and they don't have digital control, but that makes them smaller easier to use for many projects. Simply connect 3 to 6VDC to the + pin and ground to the - pin, and the LED on the board will light up. You can make the LEDs fade and twinkle by using the PWM (a.k.a. analogWrite) functionality of your Gemma or Flora, or just connect directly to a digital I/O pin of a microcontroller to turn on and off. Or even skip the micro altogether, and power directly from a LiPoly or coin battery. This order comes with 5 Emerald Green "1206 size" LEDs, matched with a 100 ohm resistor. When powered from 3.3V they draw about 5mA so you can put up to 4 or 5 in parallel on a single microcontroller pin. We also have these sequins in warm white, ruby red, royal blue, and rose pink. Technical Details 4mm x 9mm / .16" x .35" 2mm thick Holes are 7mm / .28" apart Datasheet for green LED Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“1756”相匹配的价格&库存,您可以联系我们找货
    库存:22
    1756
    • 1+37.569701+4.71132
    库存:13
