107040001
107040001
    SEEED(矽递科技)
    XADOW AUDIO
107040001 数据手册
      Xadow Audio  SKU 107040001            The Xadow Audio integrates a speaker box and a microphone on one single board. The speaker unit is rated  at 0.7Watt with an impedance of 8 ohm. Unlike the common cone type speakers, the loudspeaker driver used  on the Xadow Audio has a flat surface and is mounted in a rectangular enclosure, which enables it to  reproduce sounds at an amazing effect.      Include  Xadow Audio *1  FPC Cable 35 PIN * 2  Features:  Open source and modular design  Built‐in enclosure for speaker  Combines speaker and microphone on one board  Built‐in Xadow Connectors for easy pluggable FPC cables  Stackable and chainable with other Xadow Modules  Perfect choice for your audio and DIY Phone projects  Speaker Box:  Resonant Frequency:  900 Hz   Impedance:  8±20% Ω  Rated Power:  0.7 W  MAX. Power:  1 W  Frequency Range:  900 Hz to 20 kHz  Microphone:  Microphone Sensitivity: ‐42dBV Typ.  Max Input Sound Pressure: 130dB SPL     Dimensions:   Speaker: 13mm X 18mm X 4.5mm / 0.51” X 0.71” X 0.18”  Microphone: 2.95mm X 3.76mm / 0.12” X 0.15”  Board: 25.37mm X 20.30mm / 1’’ X 0.8’’       Technical Details  Dimensions 120mm x 80mm x 7mm  Weight  G.W 6g      Battery  Exclude  Part List  Xadow Audio 1  ECCN/HTS  ECCN Not Available  HSCODE  8518900090                                    https://www.seeedstudio.com/Xadow‐Audio‐p‐2554.html 12‐5‐18
107040001 价格&库存
很抱歉,暂时无法提供与“107040001”相匹配的价格&库存,您可以联系我们找货
  • 7+44.217107+5.72690
