Technical
Data
Sheet
Product Name:1206 High Bright Purple Chip LED
Part Number:
HT15-2102UPC
Customer:
Customer PN:
Version No.:
Date:
A.2
2009.01.01
Customer Approval
Instituted By:
Checked By:
Approved By:
HARVATEK OPTO-ELECTRONICS (SHENZHEN) CO., LTD.
TEL:
0755-83742883
FAX:
0755-83744522
Web:
http://www.harvatek.cn
Harvatek
Technical
Part No. :
Version
A.2
Data
Sheet
HT15-2102UPC
Issued date
2009.01.01
1 of 10
Page
1. Features
l
l
l
l
l
l
l
Package ( L/W/H ) : 3.2 × 1.5 × 1.1 mm
Color : Purple
Lens: Water Clear Flat Mold
EIA STD Package
Meet ROHS, Green Product
Compatible With SMT Automatic Equipment
Compatible With Infrared Reflow Solder And Wave Solder Process
2. Package Profile & Soldering PAD Suggested
①
②
①
②
Polarity
Soldering PAD Suggested:
Φ0.8
Notes:
1. All dimensions are in millimeters ;
2. Tolerance is ± 0.10 mm unless otherwise noted.
Harvatek
Technical
Part No. :
Version
3.
A.2
Data
Sheet
HT15-2102UPC
Issued date
2009.01.01
Page
2 of 10
Soldering Profile Suggested
3.1、For Lead Solder
3.2、For Lead Free Solder
Harvatek
Technical
Part No. :
Version
Sheet
HT15-2102UPC
Issued date
A.2
Data
Page
2009.01.01
3 of 10
4. Absolute Maximum Ratings At Ta=25℃
Parameter
Symbol
Rating
Unit
Power Dissipation
Pd
90
mW
Peak Forward Current
(1/10 Duty Cycle, 0.1ms Pulse Width)
IFP
100
mA
DC Forward Current
IF
30
mA
Reverse Voltage
VR
5
V
Operating Temperature Range
Topr
-30°C
+ 85°C
Storage Temperature Range
Tstg
-40°C
+ 90°C
Soldering Condition
Tsol
Reflow soldering : 260°C For 5 Seconds
Hand soldering: 300°C For 3 Seconds
Harvatek
Technical
Part No. :
Version
Sheet
HT15-2102UPC
Issued date
A.2
Data
Page
2009.01.01
4 of 10
5. Electrical Optical Characteristics At Ta=25℃
Parameter
Symbol
Min.
Typ.
Max.
Unit
Test Condition
Luminous Intensity
IV
4
mcd
IF = 20mA
Viewing Angle
2θ1/2
120
deg
IF = 20mA
Dominant Wavelength
λd
408
nm
IF=20mA
Peak Wavelength
λp
420
nm
IF=20mA
Spectral Line Half-Width
Δλ
30
nm
IF=20mA
Forward Voltage
VF
2.8
3.6
V
IF=20mA
Reverse Current
IR
10
uA
VR=5V
Notes: 1. Luminous intensity is measured with a light sensor and filter combination that approximates the
CIE eye-response curve.
2. θ1/2 is the off-axis angle at which the luminous intensity is half the axial luminous intensity.
3. The dominant wavelength, λd is derived from the CIE chromaticity diagram and represents the
single wavelength which defines the color of the device.
Harvatek
Technical
Part No. :
Version
A.2
Data
Sheet
HT15-2102UPC
Issued date
2009.01.01
Page
5 of 10
6. Typical Electrical-Optical Characteristics Curves
Harvatek
Technical
Part No. :
Version
Sheet
HT15-2102UPC
Issued date
A.2
Data
Page
2009.01.01
6 of 10
7. Label Explanation
HARVATEK
CAT:Luminous Intensity Rank(unit : mcd)
HUE:Dominant Wavelength Rank(unit : nm)
REF:Forward Voltage Rank(unit : V)
CPN: XXXXXX
P/N:
RoHS
D: XX
CAT: XXXX
HUE: XXXX
REF: XXXX
LOT NO: XXXXXXXXXXXXXX
XXXXXXXXXXXX
QTY: XXXX
Rank Tolerance:
a. Luminous Intensity: ± 15%
b. HUE: ± 1nm
c. Forward Voltage: ± 0.1V
XX.XX.XX.XX.XX.XX-XX
φ60
8.Reel And Tape Dimensions:
φ13.0
φ
Notes:
2. Tolerance is ± 0.1 mm unless otherwise noted.
Harvatek
Technical
Part No. :
Version
A.2
Data
Sheet
HT15-2102UPC
Issued date
Page
2009.01.01
7 of 10
9. Tape Leader & Trailer Dimensions And Reel
10. Packaging:
Label
Reel
Desiccant
Aluminum moisture-proof bag
Label
Vacuum
10 bags/carton
5 cartons/box
Harvatek
Technical
Part No. :
Version
Sheet
HT15-2102UPC
Issued date
A.2
Data
2009.01.01
Page
8 of 10
11. Reliability Test
Classification
Test Condition
Test Item
Reference Standard
Reference
Standard
MIL-STD-750D:1026
Ta= Under Room Temperature As Per
Operation Life
1000HRS
MIL-STD-883D:1005
Data Sheet Maximum Rating
(-24HRS,+72HRS)*@20mA
JIS C 7021:B-1
High Temperature, High
Endurance
Test
Humidity Storage
High Temperature
Storage
Low Temperature
IR-Reflow In-Board, 2 Times
Ta= 65±5℃,RH= 90〜95%
240HRS±2HRS
JIS C 7021:B-11
1000HRS
Ta= 105±5℃
MIL-STD-202F:103B
(-24HRS,+72HRS)
MIL-STD-883D:1008
JIS C 7021:B-10
1000HRS
Ta= -55±5℃
JIS C 7021:B-12
Storage
(-24HRS,+72H RS)
MIL-STD-202F:107D
Temperature
Cycling
105℃ 〜 25℃ 〜 -55℃ 〜 25℃
30mins 5mins
30mins 5mins
10 Cycles
MIL-STD-750D:1051
MIL-STD-883D:1010
JIS C 7021:A-4
Thermal
85 ± 5℃ 〜 -40℃ ± 5℃
Shock
10mins
Solder
MIL-STD-202F:107D
10 Cycles
10mins
MIL-STD-750D:1051
MIL-STD-883D:1011
MIL-STD-202F:210A
T.sol= 260 ± 5℃
10 ± 1secs
Resistance
MIL-STD-750D:2031
JIS C 7021:A-1
Ramp-up rate(183℃ to Peak) +3℃ / second max
MIL-STD-750D:2031.2
Temp. maintain at 125(±25)℃ 120 seconds max
IR-Reflow
Environmental
Test
Normal Process
J-STD-020C
Temp. maintain above 183℃ 60-150 seconds
Peak temperature range 235℃ +5/-0℃
Time within 5°C of actual Peak Temperature (tp)
10-30 seconds
Ramp-down rate +6℃ /second max
Ramp-up rate(217℃ to Peak) +3℃ / second max
MIL-STD-750D:2031.2
Temp. maintain at 175(±25)℃ 180 seconds max
IR-Reflow
Pb Free Process
J-STD-020C
Temp. maintain above 217℃ 60-150 seconds
Peak temperature range 260℃ +0/-5℃
20-40 seconds
MIL-STD-202F:208D
Solderability
T.sol= 235 ± 5℃
Immersion rate 25±2.5 mm/sec
Coverage ≧95% of the dipped surface
Immersion time 2±0.5
sec
MIL-STD-750D:2026
MIL-STD-883D:2003
IEC 68 Part 2-20
JIS C 7021:A-2
Harvatek
Technical
Part No. :
Version
A.2
Data
Sheet
HT15-2102UPC
Issued date
2009.01.01
Page
9 of 10
12. Cautions
Application
1. A LED is a current-operated device. The slight shift of voltage will cause big change of current, which
will damage LEDs. Customer should use resistors in series for the Over-Current-Proof.
2. In order to ensure intensity uniformity on multiple LEDs connected in parallel in an application, it is
recommended to use individual resistor separately, as shown in Circuit A below. The brightness of each
LED shown in Circuit B might appear difference due to the differences in the I-V characteristics of those
LEDs.
Circuit model A
Circuit model B
3. High temperature may reduce LEDs’ intensity and other performances, so keeping it away from heat
source to get good performance is necessary.
Storage
1.Before opening original package, it is recommended to store them in the following environment:
Temperature: 5℃~30℃
Humidity: 85%RH max.
2. After opening original package, the storage ambient for the LEDs should be in 5~30°C temperature and
60% or less relative humidity.
3. In order to avoid moisture absorption, it is recommended that the LEDs that out of the original package
should be stored in a sealed container with appropriate desiccant, or in desiccators with nitrogen ambient.
4. The LEDs should be used within 168hrs (7 days) after opening the package. Once been mounted, soldering
should be quick.
5. If the moisture absorbent material (silica gel) has faded away or the LEDs stored out of original
package for more than 168hrs (7 days), baking treatment should be performed using the conditions:
60℃ at least 24 hours.
ESD (Electrostatic Discharge )-Protection
A LED (especially the Blue、White and Green product) is an ESD sensitive component, and static
electricity or power surge will damage the LED. ESD-damaged LEDs will exhibit abnormal characteristics
such as high reverse leakage current, low forward voltage, or “no light-up” at low currents, etc.
Some advice as below should be noticed:
1. A conductive wrist strap or anti-electrostatic glove should be worn when handling these LEDs.
2. All devices, equipment, machinery, work tables and storage racks, etc. must be properly grounded.
Harvatek
Technical
Part No. :
Version
A.2
Data
Sheet
HT15-2102UPC
Issued date
2009.01.01
Page
10 of 10
3. Use anti-static package or boxes to carry and storage LEDs. And ordinary plastic package or boxes is
forbidden to use.
4. Use ionizer to neutralize the static charge during handling or operating.
5. All surfaces and objects within 1 ft close to LEDs measure less than 100V.
Cleaning
Use alcohol-based cleaning solvents such as IPA (isopropyl alcohol) to clean LEDs if necessary.
Soldering
1. Soldering condition refer to the draft “Soldering Profile Suggested” on page 1.
2. Reflow soldering should not be done more than 2 times.
3. Manual soldering is only suggested on repair and rework. The maximum soldering temperature should
not exceed 300°C within 3 sec. And the maximum capacity of soldering iron is 30W in power.
4. During the soldering process, do not touch the lens at high temperature.
5. After soldering, any mechanical force on the lens or any excessive vibration shall not be accepted to
apply, also the circuit board shall not be bent as well.
Others
1. The LEDs described here are intended to be used for ordinary electronic equipment (such as office
equipment, communication equipment and household applications).Consult Harvatek’s Sales in
advance for the applications in which exceptional reliability is required, particularly when the failure
or malfunction of the LEDs may directly jeopardize life or health. (such as in aviation, transportation,
traffic control equipment, medical and life support systems and safety devices).
2. The light output from the high luminous intensity LEDs may cause injury to human eyes when viewed
directly.
3.
The appearance and specifications of the product may be modified for improvement without prior
notice.
