DEV-10753
DEV-10753
    SPARKFUNELECTRONICS
    LED MICRO - WHITE (5PCS)
DEV-10753 数据手册
APT3216QWF/D 3.2 mm x 1.6 mm SMD Chip LED Lamp DESCRIPTIONS     PACKAGE DIMENSIONS The source color devices are made with InGaN Light Emitting Diode Electrostatic discharge and power surge could damage the LEDs It is recommended to use a wrist band or anti-electrostatic glove when handling the LEDs All devices, equipments and machineries must be electrically grounded FEATURES         3.2 mm x 1.6 mm SMD LED, 0.75 mm thickness Low power consumption Wide viewing angle Ideal for backlight and indicator Package: 2000 pcs / reel Moisture sensitivity level: 3 Halogen-free RoHS compliant APPLICATIONS      Backlight Status indicator Home and smart appliances Wearable and portable devices Healthcare applications RECOMMENDED SOLDERING PATTERN (units : mm; tolerance : ± 0.1) ATTENTION Observe precautions for handling electrostatic discharge sensitive devices Notes: 1. All dimensions are in millimeters (inches). 2. Tolerance is ±0.2(0.008") unless otherwise noted. 3. The specifications, characteristics and technical data described in the datasheet are subject to change without prior notice. 4. The device has a single mounting surface. The device must be mounted according to the specifications. SELECTION GUIDE Part Number APT3216QWF/D Emitting Color (Material) White (InGaN) Iv (mcd) @ 20mA [2] Viewing Angle [1] Lens Type Yellow Fluorescent Min. Typ. 2θ1/2 120 250 160° Notes: 1. θ1/2 is the angle from optical centerline where the luminous intensity is 1/2 of the optical peak value. 2. Luminous intensity / luminous flux: +/-15%. 3. Luminous intensity value is traceable to CIE127-2007 standards. © 2021 Kingbright. All Rights Reserved. Spec No: DSAI2506 / 1203001960 Rev No: V.12B Date: 09/29/2021 Page 1 / 4 APT3216QWF/D ELECTRICAL / OPTICAL CHARACTERISTICS at TA=25°C Value Parameter Symbol Emitting Color Unit Typ. Max. Chromaticity Coordinates x IF = 20mA x [1] White 0.31 - - Chromaticity Coordinates y IF = 20mA y [1] White 0.31 - - C White 100 - pF Forward Voltage IF = 20mA VF [2] White 3.3 4.0 V Reverse Current (VR = 5V) IR White - 50 µA Capacitance Notes: 1. Measurement tolerance of the chromaticity coordinates is ±0.01. 2. Forward voltage: ±0.1V. 3. Excess driving current and / or operating temperature higher than recommended conditions may result in severe light degradation or premature failure. ABSOLUTE MAXIMUM RATINGS at TA=25°C Parameter Symbol Value Unit Power Dissipation PD 120 mW Reverse Voltage VR 5 V Junction Temperature Tj 115 °C Operating Temperature Top -40 to +85 °C Storage Temperature Tstg -40 to +85 °C DC Forward Current IF 30 mA IFM [1] 150 mA - 250 V Peak Forward Current Electrostatic Discharge Threshold (HBM) Notes: 1. 1/10 Duty Cycle, 0.1ms Pulse Width. 2. Relative humidity levels maintained between 40% and 60% in production area are recommended to avoid the build-up of static electricity – Ref JEDEC/JESD625-A and JEDEC/J-STD-033. © 2021 Kingbright. All Rights Reserved. Spec No: DSAI2506 / 1203001960 Rev No: V.12B Date: 09/29/2021 Page 2 / 4 APT3216QWF/D TECHNICAL DATA SPATIAL DISTRIBUTION 0° -15° Ta = 25 °C 15° -30° 30° -45° 45° 60° -60° 75° -75° -90° 1.0 0.5 0.0 90° 1.0 0.5 WHITE Forward current (mA) Ta = 25 °C 40 30 20 10 2.4 2.8 3.2 3.6 Forward voltage (V) Permissible forward current (mA) 2.5 Luminous intensity normalised at 20 mA 50 0 2.0 Forward Current Derating Curve Luminous Intensity vs. Forward Current Ta = 25 °C 2.0 1.5 1.0 0.5 0.0 4.0 0 10 20 30 40 Forward current (mA) 50 Luminous Intensity vs. Ambient Temperature 50 2.5 Luminous intensity normalised at T a = 25 °C Forward Current vs. Forward Voltage 40 30 20 10 0 -40 -20 0 20 40 60 80 100 Ambient temperature (°C) 2.0 1.5 1.0 0.5 0.0 -40 -20 0 20 40 60 80 100 Ambient temperature (°C) CIE CHROMATICITY DIAGRAM 0.40 c0 a2 0.35 b1 y b2 0.30 b2 a0 0.25 c0 a2 0.20 0.20 0.25 0.30 0.35 0.40 x © 2021 Kingbright. All Rights Reserved. Spec No: DSAI2506 / 1203001960 Rev No: V.12B Date: 09/29/2021 x y x y 0.263 0.213 0.282 0.245 0.282 0.245 0.298 0.271 0.265 0.265 0.286 0.299 0.242 0.226 0.265 0.265 0.298 0.271 0.313 0.296 0.313 0.296 0.329 0.325 0.306 0.332 0.329 0.371 0.286 0.299 0.306 0.332 0.329 0.325 0.358 0.372 0.363 0.400 0.329 0.371 a0 b1 Notes: Shipment may contain more than one chromaticity regions. Orders for single chromaticity region are generally not accepted. Measurement tolerance of the chromaticity coordinates is ±0.01. Page 3 / 4 APT3216QWF/D REFLOW SOLDERING PROFILE for LEAD-FREE SMD PROCESS TAPE SPECIFICATIONS (units : mm) REEL DIMENSION (units : mm) Notes: 1. Don't cause stress to the LEDs while it is exposed to high temperature. 2. The maximum number of reflow soldering passes is 2 times. 3. Reflow soldering is recommended. Other soldering methods are not recommended as they might cause damage to the product. PACKING & LABEL SPECIFICATIONS PRECAUTIONARY NOTES 1. The information included in this document reflects representative usage scenarios and is intended for technical reference only. 2. The part number, type, and specifications mentioned in this document are subject to future change and improvement without notice. Before production usage customer should refer to the latest datasheet for the updated specifications. 3. When using the products referenced in this document, please make sure the product is being operated within the environmental and electrical limits specified in the datasheet. If customer usage exceeds the specified limits, Kingbright will not be responsible for any subsequent issues. 4. The information in this document applies to typical usage in consumer electronics applications. If customer's application has special reliability requirements or have life-threatening liabilities, such as automotive or medical usage, please consult with Kingbright representative for further assistance. 5. The contents and information of this document may not be reproduced or re-transmitted without permission by Kingbright. 6. All design applications should refer to Kingbright application notes available at https://www.KingbrightUSA.com/ApplicationNotes © 2021 Kingbright. All Rights Reserved. Spec No: DSAI2506 / 1203001960 Rev No: V.12B Date: 09/29/2021 Page 4 / 4
DEV-10753 价格&库存
很抱歉,暂时无法提供与“DEV-10753”相匹配的价格&库存,您可以联系我们找货
