105040000
105040000
    SEEED(矽递科技)
    XADOWVIBRATIONMOTOR
105040000 数据手册
Xadow ‐ Vibration Motor SKU 105040000 This small vibrator motor can vibrate like your phone. When using it, You only need to power for the module and then send "Vibration" command. In fact, The "Vibration" command is setting control pins to high level, then it will work. I like this module because it can creat a short-term shock to prompt me whether one operation was successful, such as shaking my arm to switch my iPhone songs, which sound terrible, and it is not like the buzzer which sound terrible. Xadow is a though small but perfectly formed Arduino(TM) compatible board series containing several modules. It's a kit extremely suitable for space-sensitive projects such as wearable devices & arts designs, which have higher request on size, weight and flexible cascade connection. You can find more modules here. Note: This module is not compatible with any other Xadow version 2 or RePhone modules. Technical Details Dimensions 0mm x 0mm x 0mm Weight G.W 11g Battery Exclude ECCN/HTS ECCN Not Available HSCODE 8503001000 https://www.seeedstudio.com/Xadow-Vibration-Motor-p-1517.html 10-8-19
105040000 价格&库存
很抱歉,暂时无法提供与“105040000”相匹配的价格&库存,您可以联系我们找货
