COM-11705
COM-11705
    SPARKFUNELECTRONICS
    BARREL JACK POWER SWITCH M-F 3"
COM-11705 数据手册
  Barrel Jack Power Switch - M-F (3") COM -1 1705 Description: We use barrel jacks a lot around here and sometimes we need to pop a switch into the mix. That usually means hacking up a perfectly good barrel jack extension cable, but the whole point of using the barrel jacks was so that we wouldn’t have to hack things apart… Well, we found a solution: The Barrel Jack Power Switch. Okay, it’s nothing fancy but it is really useful. Plug your power supply into one end and the other into your project and, just like that, you’ve got a power switch! The onoff rocker switch has a good stiff ‘click’ to it, so it isn’t easy to accidentally switch. It’s also fairly small so it won’t add too much unnecessary bulk to your project. Dimensions: • Switch Body: ≈ 61 x 27 x 23mm • Cable: 85mm long (each side) • Barrel Connector: 5.5x2.1mm https://www.sparkfun.com/products/11705 8/3/2016
COM-11705 价格&库存
很抱歉,暂时无法提供与“COM-11705”相匹配的价格&库存,您可以联系我们找货
