COM-11759
COM-11759
    SPARKFUNELECTRONICS
    INFRARED REMOTE CONTROL
COM-11759 数据手册
  Infrared Remote Control COM -1 1759 RO HS  Description: Have you ever needed a cheap way to activate something from across the room? Infrared remotes are still the cheapest way to wirelessly control a device. We have designed the remote to be small, very simple, and low-cost. For the majority of the projects we build, we don’t need 34 buttons, we need one or two. It makes more sense to provide you with a cheap and easy to use remote. Our infrared remote control offers buttons for four directions, power, select, and three optional use buttons (labled “A,” “B,” and “C”). Unfortunately we can’t guarantee that it will work with your Stuart Hughes' PrestigeHD Supreme Rose Edition though. Rather, we are carrying this remote to work with many of the more common IR receiver ICs. Want to see what’s inside? Check the pictures, we tore one apart so you can see what’s on the inside. Note: The unit does NOT come with a CR2025 coin cell battery (check below). You can use a CR2032 battery, but we found they get stuck easily because they’re slightly too thick. It’s recommended that you use the CR2025, it fits well. https://www.sparkfun.com/products/11759 8/4/2016
COM-11759 价格&库存
很抱歉,暂时无法提供与“COM-11759”相匹配的价格&库存,您可以联系我们找货
