2935
2935
    ADAFRUIT
    SCREWDRIVER SLOTTED 0.4X2.5MM
2935 数据手册
IoT CONTROL RELAY Safely control AC power from logic. Build the IoT. Connect easily and safely. Control power from an Arduino, Raspberry Pi, Galileo or other microcontroller. The universal input connects to any circuit including 3.3V and 5 volt logic. No driver is requried. • A single logic input signal controls one high-current SPDT AC relay. This relay signal switches four AC outlets in pairs: Two outlets are normally on. Two are normally off. Simply connect two wires. One to ground and one to your control signal, such as an output bit on a microcontroller. • The universal control voltage 3-48VDC or 12-120VAC allows control from virtually any micro or AC source. The relay can also be controlled by an AC input voltage of 12 to 120VAC. No changes or jumpers are required. The internal circuitry is very power efficient, using approximately 1/5W unswitched and 1.1W activated. Applications include: • • • • IoT products, DIY gadgets, OEM test equipment Home and building automation Green power and energy conservation Kiosks, vending machines and signage controls Multiple AC loads of up to 12 Amps total may be controlled. Your imagination is the limit. The IoT control relay is rugged and reliable, with US design and QC. It ships fully assembled and tested with a 1 year warranty. Single units are available on Amazon. Call DLI for quantity discounts and overnight shipping. • Self-contained design eliminates dangerous high voltage wiring and safety hazards. • Safety features include: Optical isolation -- eliminates shock hazard Relay hysteresis -- prevents relay chatter De-bounce protection -- extends contact life LEDs -- verify input voltage and switch state • A large 3600W MOV clamps surges for clean power. • The durable SPDT control relay is rated at 30/40A, 400,000 operations at 12A resistive. At no load, the estimated lifetime is 5.3 million mechanical operations. • A 12A thermal safety circuit breaker switch prevents overloads and adds supplemental protection. • Recommended operating range: AC input 90-120VAC. Current 0-8A with 18AWG power cords, 0-12A with 16AWG cord. Use14AWG for 12A spans over 10 feet. • Input connector: C-13/C14. Output: 4x NEMA 5-15. • Included cord: 24" C-13 to 5-15 16AWG. Cords up to 50' length are in-stock in 14AWG. Digital Loggers, Inc. 2695 Walsh Avenue, Santa Clara, CA 95051 Tel: (408) 330-5599 IoTrelay.com • Indoor use only: -35F to 145F, 5-95% noncondensing. © 1999-2016 DLI. US & foreign patents pending.
很抱歉,暂时无法提供与“2935”相匹配的价格&库存,您可以联系我们找货
    库存:264
