GrovePi+ Starter Kit for Raspberry Pi A+,B,B+&2,3 (CE certified)
SKU 110060161
What is GrovePi+ Start kit for Raspberry Pi?
Carrying a GrovePi+ board together with 12 carefully selective Grove sensors with 10
pieces cables , this starter kit gets you up and running with the Raspberry Pi quickly. Just
slip the GrovePi+ board over your Raspberry Pi and connect sensors to the board, you're
ready to start hardware playing and prototyping with the powerful platform.
About The GrovePi+, It is stacked on top of the Raspberry Pi without the need for any other
connections. Communication between the two occurs over the I2C interface. All Grove
modules connect to the universal Grove connectors on the GrovePi+ shield via the universal
4 pin connector cable.
About Grove modules, which work on analog and digital signals, connect directly to the
ATMEGA328 microcontroller on the Grove Pi+. The microcontroller acts as an interpreter
between the Raspberry Pi and the Grove sensors. It sends, receives, and executes
commands sent by the RaspberryPi.
The GrovePi+ is compatible with Raspberry Pi A+,B,B+/2,3.
Note: The Raspberry Pi board is not included.
The new GrovePi+ is CE certified and compatible with Linux and Win 10 IoT.
Technical Details
Dimensions
180mm x 120mm x 45mm
Weight
G.W 323g
Battery
Exclude
Part List
Grove Pi+
1
Grove ‐ Rotary Angle Sensor
1
Grove ‐ Sound Sensor
1
Grove ‐ LCD RGB Backlight
1
Grove ‐ Temp&Humi Sensor
1
Grove ‐ Red LED
1
Grove ‐ Light Sensor
1
Grove ‐ Buzzer
1
Grove ‐ Relay
1
Grove ‐ Blue LED
1
Grove ‐ Button
1
GrovePi+ Guidebook
1
Cables
10
Grove ‐ UItrasonic Ranger
1
Grove ‐ Green LED
1
ECCN/HTS
ECCN
Not Available
HSCODE
9023009000
Certification
Certification
CE
https://www.seeedstudio.com/GrovePi‐Starter‐Kit‐for‐Raspberry‐Pi‐A‐B‐B‐2‐3‐CE‐certifie‐p‐2572.html 10‐18‐18
很抱歉,暂时无法提供与“110060161”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+605.724031+78.25483
