Datasheet
Arduino TinkerKit Starter
K000002
The Starter Kit is a pack of different TinkerKit Modules, aimed to start designing interactive
environments / prototype interfaces without using the breadboard or the soldering iron.
The Starter Kit consists in the Sensor Shield V.2, 8 different Sensors and 7 Actuators,
some cables.
Kit Includes:
Description
Sensor Shield V.2
Button Module
LDR Module
Tilt Module
Therm Module
Rotary Potentiometer Module
Linear Potentiometer Module
Touch Sensor Module
Joystick Module
Relay Module
5mm Green Led Module
5mm Yellow Led Module
5mm Red Led Module
10mm Green Led Module
10mm Yellow Led Module
10mm Red Led Module
20cm Cables
50cm Cables
100cm Cables
Part Number
T020010
T000180
T000090
T000190
T000200
T000140
T000150
T000220
T000030
T010010
T010112
T010113
T010114
T010116
T010117
T010118
T020060
T020070
T020080
Quantity
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
4
2
1
Arduino TinkerKit Base available at Mouser Electronics: K000002
Datasheet
Datasheet
Datasheet
Datasheet
Datasheet
Datasheet
Datasheet
Datasheet
Datasheet
Datasheet
Datasheet
Datasheet
Datasheet
Datasheet
Datasheet
Datasheet
Datasheet
Datasheet
Datasheet
Datasheet
很抱歉,暂时无法提供与“K000002”相匹配的价格&库存,您可以联系我们找货
