Page 1 of 3
(images/product/106060002 1_02.jpg)
Sidekick Basic Kit for TI LaunchPad
SKU: 106060002
Page 2 of 3
Description
As for more support materials, please to access www.energia.nu/sidekick
(http://www.energia.nu/sidekick).
Sidekick is a collection of popular components for DIY projects. It is easy to create custom
breadboard circuits that can interface with a development kit. This is an excellent starter kit
for new electronics engineers and makers.
This kit is fully compatible with all TI LaunchPads. The following examples are based on
LaunchPads that support Energia software. If you are using any of the LaunchPad kits, the
examples should be the same or involve minor pin configuration changes.
THE EXAMPLES
Example 00: Blinking LED (Output)
Example 01: Fade RGB LED (PWM)
Example 02: Push Button (Input)
Example 03: Multiple LED (Many Outputs)
Example 04: Shift Register (Integrated Circuit)
Example 05: Piezo Buzzer (Sound)
Example 06: Potentiometer (Variable Resistor)
Example 07: Photoresistor (Light Sensor)
Example 08: Spin the Motor (Transistor)
Example 09: Temperature (Thermistor and Temp Sensor)
Example 10: 7 Segment Display (Digital Display)
Features:
Fully compatible with all TI LaunchPads.
Lot of examples
Energia supported
Breadboard BoosterPack for TI LaunchPad
Part List:
1 x Breadboard
5 x Green LED
5 x Red LED
1 x RGB Common Anode LED
10 x Ceramic Capacitor 10nF
10 x Ceramic Capacitor 100nF
5 x Aluminum capacitor 100uF
Page 3 of 3
10 x Resistor 330R
10 x Resistor 1K
10 x Resistor 10K
1 x Tilt switch
1 x Thermistor
1 x Photoresistor
1 x Diode
1 x Buzzer
5 x Button
5 x Switch
2 x Potentiometer with knob
5 x Breadboard jumper wire – long
20 x Breadboard jumper wire – short
1 x 7 segment display
1 x Small DC motor
1 x TI 8-bit shift register (SN74HC595N)
1 x TI Analog Temperature Sensor (LM19CIZ/NOPB)
1 x TI NPN transistor (LP395Z/NOPB)
1 x TI NPN transistor (PN2222/NOPB)
1 x Breadboard BoosterPack Adapter PCB
1 x Label for components
1 x Sidekick basic for LaunchPad Manual
http://www.seeedstudio.com/depot/Sidekick-Basic-Kit-for-TI-LaunchPad-p-2571.html?cP...
12/1/2015
很抱歉,暂时无法提供与“106060002”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+280.730401000+36.38801
