KIT-13205
KIT-13205
    SPARKFUNELECTRONICS
    INVENTOR KIT FOR MICROVIEW ARD
KIT-13205 数据手册
Page 1 of 38   SparkFun Inventor's Kit for MicroView CONTRIBUTORS: JOE LEB Introduction Welcome to the SparkFun Inventor’s Kit for MicroView Experiment Guide, or the SIK for MicroView for short. This tutorial will guide you through eleven experiments to help you better understand your MicroView, and, once finished, you should have the knowledge necessary to make your MicroView project dreams a reality. Included Materials Before you do anything, you should make sure that you have all the necessary parts included with the SIK for MicroView. It’s a good idea to familiarize yourself with the parts now, so you know what to look for when it comes time to build the circuits. • • • • • • • • • • • • • SparkFun MicroView - OLED Arduino Module SparkFun MicroView - USB Programmer USB Cable Extension - 1.5 Foot White Solderless Breadboard 74HC595 Shift Register 2N2222 Transistors 1N4148 Diodes DC Motor with Gear Small Servo SPDT 5V Relay TMP36 Temp Sensor Softpot Jumper Wires Page 2 of 38 • • • • • • • Photocell RGB LED Red & Yellow LEDs 10K Trimpot Piezo Speaker Big 12mm Button 330 and 10K Resistors Suggested Reading To make your MicroView experience as enjoyable as possible, we recommend you be familiar with the following concepts before beginning. • • • • • • • • What is a Circuit How to Use a Breadboard What is an Arduino? Installing the Arduino IDE Installing an Arduino Library Polarity Analog vs Digital Analog to Digital Conversion MicroView Overview Before we dive into the experiments, let’s fist familiarize ourselves with the MicroView and its pins. The MicroView is the first chip-sized Arduino compatible module that lets you see what your Arduino is thinking by using a built-in OLED display. In the heart of MicroView, there is an ATMEL ATmega328P, 5V & 3.3V LDOs and a 64x48 pixel OLED display, together with other passive components that allow the MicroView to operate without any external components other than a power supply. Hardware Specifications • • • • • • • • • • • Display : 64x48 OLED Display Microcontroller : ATmega328P Operating Voltage : 5V Input Voltage : 3.3VDC - 16VDC Digital I/O Pins : 12 (of which 3 provide PWM output) Analog Input Pins : 6 Flash Memory : 32 KB SRAM : 2 KB EEPROM : 1 Kilobyte Clock Speed : 16 Mhz No other components required Pin Configuration Page 3 of 38 The MicroView has 16 “physical pins” that map to corresponding “Arduino pins” that can be referenced from within your Arduino sketch. For example, Physical Pin2 maps to the Arduino’s pin A5 (analog pin 5). Pinout of MicroView on it’s side. The top of the MicroView is on the right. (Click for larger image) The pin numbering for the MicroView increments as you move anticlockwise. The MicroView’s physical Pin1 is denoted by a dot on the underside of the MicroView. For more details on pins of MicroView, please refer to the ATmega328P Datasheet. Programming the MicroView In order to get your MicroView up and running, there a few easy steps you will need to follow: 1. 2. 3. 4. Download the FTDI Drivers Install Arduino software and MicroView Library Select the right board Run your first sketch Step 1 - Download and Install FTDI Drivers To use the MicroView with the Arduino IDE, you will first need to install the drivers for the FTDI chip on the USB Programmer. Visit our comprehensive tutorial on how to install FDTI drivers, then come on back to continue your MicroView Adventure. Once you have finished the FTDI driver installation, you will need to prepare your MicroView to be inserted into the computer’s USB port. If you’re using the USB Programmer, insert the MicroView into the USB Programmer now, if you have not done so already. Please take note that at the back of MicroView, there is a round dot marking showing the Pin 1 of the MicroView where you need to match the Pin 1 of the USB Programmer. Once you have inserted the MicroView into the USB Programmer, you can now insert the USB Programmer into the USB port of the computer as Page 4 of 38 pictured below. If your computer does not have a right-sided USB port, please use a USB Cable Extension to extend the USB port to the front so that you can easily work with the MicroView. As an alternative to the USB Programmer, you can use a 5V FTDI Basic Breakout or 5V FTDI Cable instead. Connect the FTDI Basic Breakout board as below, and you are ready to go. Step 2 - Install the Arduino Software (IDE) We will be using the Arduino IDE to program the MicroView. If you have already installed it, skip to installing the library. Install Arduino IDE and the MicroView Library If you have not installed the Arduino IDE already, now is the time to do so. Visit our Installing the Arduino IDE tutorial for detailed instructions. Install MicroView Library Download MicroView’s library from the MicroView Github repo, or click the link below to download the zip file directly. M IC RO V IEW L IB RA RY Z IP Save the ZIP file to your download folder, and then unzip the .ZIP file. Find the Library folder under MicroView-master -> Libraries -> SparkFun_Microview. Open the Arduino IDE, click Sketch, Import Library, and then Add Library. Page 5 of 38 Browse to the MicroView folder that was renamed, and select that folder. The MicroView library will be automatically installed. Click File, Example, and find MicroView Example to confirm the installation. If you wish to compile and upload the MicroViewDemo from our example, there is a 3rd party Time library that is required to be installed. Download the Time library and use the same library installation method discussed above to install it into the Arduino IDE. Step 3 - Select the Right Board In the Arduino IDE, click Tools, board and select Arduino Uno. Due to the nature of Arduino IDE being not able to detect a board, the COM port (Serial Port) of the MicroView USB Programmer needs to be manually selected by clicking Tools, Serial Port and select the right port that was created in the previous driver installation. Click Upload to upload your first sketch to MicroView. MicroView is using the same bootloader as Uno. It behaves like an Uno when uploading sketches. For advance user that like to see MicroView as a board by itself in the IDE, add the following board definition to the boards.txt file. Depending on your setup, the boards.txt file usually located at arduinoversion\hardware\arduino folder. Replace arduino-version with the right folder name for your Arduino version installed in your computer. uview.upload.tool=avrdude uview.bootloader.tool=avrdude uview.name=MicroView uview.upload.protocol=arduino uview.upload.maximum_size=32256 uview.upload.speed=115200 uview.bootloader.low_fuses=0xff uview.bootloader.high_fuses=0xde uview.bootloader.extended_fuses=0x05 uview.bootloader.path=optiboot uview.bootloader.file=optiboot_atmega328.hex uview.bootloader.unlock_bits=0x3F uview.bootloader.lock_bits=0x0F uview.build.mcu=atmega328p uview.build.f_cpu=16000000L uview.build.core=arduino uview.build.variant=standard Page 6 of 38 Step 4 - Run Your First Sketch Select the correct COM port, and you’re ready to upload. Simply cut and paste the sketch below into the Arduino IDE, and click upload. #include void setup() { uView.begin(); uView.clear(PAGE); uView.print("HelloWorld"); uView.display(); } // start MicroView // clear page // display HelloWorld void loop () {} Once you have uploaded your first sketch, it’s time to get started with the experiments. Experiment 0: Quick Start The MicroView comes with a nice quick start experiment preinstalled to get you learning right out of the box without having to upload any code. Using just a few components, you can learn the ins and outs of the MicroView in this first step of the SIK for MicroView. Unboxing and Setting Up Your MicroView Remove all parts from the SparkFun Inventor’s Kit for MicroView. Identify PIN 1 of MicroView based on the following diagram, or refer back to the MicroView Overview section. In this guide, when there is a reference for PIN x of MicroView, it is referring to the above diagram’s PIN number. For example, connect PIN 5 and PIN 8 of the MicroView. MicroView with Factory USB Programmer The quickest way to get started is to use the USB programmer included in the SIK for MicroView. You will also need • USB Extension Cable • Breadboard Insert the MicroView to the factory USB Programmer then connect the female end of the USB extension cable to the factory USB Programmer based on the following diagram: Page 7 of 38 Connect the male end of the USB extension cable to the computer, and the MicroView demo will start. MicroView without Factory USB Programmer If you would like to use the MicroView without the USB Programmer, you will need the following (please note that the 9V battery and snap connector are not included in the SIK for MicroView and will need to be purchased separately): • 9V Battery • 9V Snap Connector (Remove the Molex connector, replace both wires with male header pins if necessary) • Jumper Wires M/M Pack of 10 (If you need more, you can also get the Pack of 100) • Breadboard Connect the required parts based on the diagram below, leave the battery snap connector to the last step: As soon as the battery snap connector is snapped to the 9V battery, the MicroView demo will start. Learn How to Use MicroView The MicroView is factory pre-programmed with a few simple built-in tutorials to help you get use to inserting jumper wires, resistors and LED. Skip these tutorials if you are already familiar with them. The simple tutorials will start after the demo. Note: The simple tutorials' diagrams are based on MicroView without the USB Programmer, if you have the USB Programmer, please ignore the battery, red jumper and black jumper. MicroView with USB Programmer gets its power supply from the USB Programmer via the USB cable connected to the computer. Simple Tutorial 1 Follow the instruction displayed on the MicroView, connect PIN 5 and PIN 8 Page 8 of 38 of the MicroView with a jumper using the following diagram as reference: Once you have successfully connected PIN 5 and PIN 8 of the MicroView, a “Well done!” message will be displayed. To proceed to the next simple tutorial, remove the jumper. Simple Tutorial 2 Follow the instruction displayed on the MicroView, connect PIN 3 and PIN 8 of the MicroView with a jumper using the following diagram as reference: Once you have successfully connected PIN 3 and PIN 8 of the MicroView, a “Well done!” message will be displayed. To proceed to the next simple tutorial, remove the jumper. Simple Tutorial 3 Follow the instruction displayed on the MicroView, connect PIN 2 and PIN 8 of the MicroView with a jumper using the following diagram as reference: Once you have successfully connected PIN 2 and PIN 8 of the MicroView, a “Well done!” message will be displayed. To proceed to the next simple tutorial, remove the jumper. Simple Tutorial 4 Follow the instruction displayed on the MicroView, connect PIN 4 and PIN 8 of the MicroView with a 330 ohm resistor using the following diagram as reference: Page 9 of 38 Once you have successfully connected PIN 4 and PIN 8 of the MicroView with the resistor, a “Well done!” message will be displayed. To proceed to the next simple tutorial, remove the resistor. Simple Tutorial 5 Follow the instruction displayed on the MicroView, connect PIN 4 and PIN 8 of the MicroView with a 10K ohm resistor using the following diagram as reference: Once you have successfully connected PIN 4 and PIN 8 of the MicroView with the resistor, a “Well done!” message will be displayed. To proceed to the next simple tutorial, remove the resistor. Simple Tutorial 6 Follow the instruction displayed on the MicroView, connect PIN 5 and PIN 8 of the MicroView with a 330 ohm resistor using the following diagram as reference: With the resistor still at the same place, insert a LED with both of the pins at PIN 4 and PIN 5 of MicroView respectively using the following diagram as reference. Page 10 of 38 The MicroView is able to detect if the LED is inserted with the correct polarity, if the LED does not blink, remove the LED and turn the pins the other way round and connect them to PIN 4 and PIN 5 of the MicroView. With that, you are now ready to upload code and begin building the experiments in this guide. Experiment 1: Blinking an LED LEDs (light-emitting diodes) are small, powerful lights that are used in many different applications. To start off the MicroView course, we will work on blinking an LED. That’s right – it’s as simple as turning a light on and off. It might not seem like much, but establishing this important baseline will give you a solid foundation as we work toward more complex experiments. Blink is the “Hello World” of hardware. Parts Needed You will need the following parts: • 1x LED • 1x 330Ω Resistor (Orange, Orange, Brown, Gold) Breadboard Setup Pay close attention to the polarity of the LED. Hook up your circuit as pictured below: Page 11 of 38 MicroView Arduino Code Upload the following code to your MicroView: int LED = A2; iew void setup() { pinMode(LED, OUTPUT); } // declare LED as pin A3 of MicroV // set LED pin as OUTPUT void loop() { digitalWrite(LED, HIGH); ED will be on delay(1000); digitalWrite(LED, LOW); D will be off delay(1000); } // set LED pin HIGH voltage, L // delay 1000 ms // set LED pin LOW voltage, LE // delay 1000 ms What You Should See You should see your LED blink on and off. If it isn’t, make sure you have assembled the circuit correctly and verified and uploaded the code to your MicroView or see the troubleshooting tips below. Code to Note Before you can use one of the MicroView’s pins, you need to tell the MicroView whether it is an INPUT or OUTPUT. We use a built-in “function” called pinMode() to do this. pinMode(A3, OUTPUT); When you’re using a pin as an OUTPUT, you can command it to be HIGH (output 5 volts), or LOW (output 0 volts). digitalWrite(A3, HIGH); Arduino programs run in a loop. When the MicroView sees the delay() command, it will pause the loop for the amount of time (in milliseconds). For example delay(1000) will stop the loop for one second as there are 1000 ms in one second. delay(1000); Page 12 of 38 Troubleshooting LED Not Lighting Up? LEDs will only work in one direction. Try taking it out and turning it around 180 degrees (no need to worry, installing it backward does no permanent harm). Still No Success? A broken circuit is no fun, send us an e-mail and we will get back to you as soon as we can: TechSupport@sparkfun.com Experiment 2: Reading a Potentiometer In this circuit, you’ll work with a potentiometer. A potentiometer is also known as a variable resistor. When it’s connected with 5 volts across its two outer pins, the middle pin outputs a voltage between 0 and 5, depending on the position of the knob on the potentiometer. A potentiometer is a perfect demonstration of a variable voltage divider circuit. The voltage is divided proportionate to the resistance between the middle pin and the ground pin. In this circuit, you’ll learn how to use a potentiometer and display its value on the MicroView. Parts Needed You will need the following parts: • 1x Potentiometer • 3x Jumper Wire Breadboard Setup Hook up your circuit as pictured below: MicroView Arduino Code Upload the following code to your MicroView: Page 13 of 38 #include // include MicroView library MicroViewWidget *widget; MicroViewWidget *widget2; // create widget pointer // create widget pointer int sensorPin = A1; ometer int sensorValue = 0; om the sensor // select the input pin for the potenti // variable to store the value coming fr void setup() { digitalWrite(sensorPin, HIGH); // Internal Pull­up pinMode(sensorPin, INPUT); // make pin as INPUT uView.begin(); // start MicroView uView.clear(PAGE); // clear page widget = new MicroViewSlider(0, 0, 0, 1024); // make wi dget as Slider widget2 = new MicroViewSlider(0, 20, 0, 1024, WIDGETSTYLE 1); // make widget as Silder STYLE1 uView.display(); // display the conten t in the screen buffer } void loop() { sensorValue = analogRead(sensorPin); widget­>setValue(sensorValue); nsorPin to widget widget2­>setValue(sensorValue); nsorPin to widget uView.display(); tent in the screen buffer } // read sensorPin // set value of se // set value of se // display the con What You Should See By turning the potentiometer’s knob you should see on your MicroView’s display two different styles of widget reflect the reading of the potentiometer. Code to Note A “variable” is a stored value you’ve given a name to. You must introduce, or “declare” variables before you use them; here we’re declaring a variable called sensorValue, of type “int” (integer). Don’t forget that variable names are case-sensitive! int sensorValue; We use the analogRead() function to read the value on an analog pin. analogRead() takes one parameter, the analog pin you want to use (“sensorPin”), and returns a number (“sensorValue”) between 0 (0 volts) and 1023 (5 volts). sensorValue = analogRead(sensorPin); Troubleshooting LED Not Lighting Up? Page 14 of 38 LEDs will only work in one direction. Try taking it out and turning it around 180 degrees (no need to worry, installing it backward does no permanent harm). Still No Success? A broken circuit is no fun, send us an e-mail and we will get back to you as soon as we can: TechSupport@sparkfun.com Experiment 3: RGB LED You know what’s even more fun than a blinking LED? Changing colors with one LED. RGB, or red-green-blue, LEDs have three different color-emitting diodes that can be combined to create all sorts of colors. In this circuit, you’ll learn how to use an RGB LED to create unique color combinations. Depending on how bright each diode is, nearly any color is possible! Parts Needed You will need the following parts: • 1x RGB LED • 3x 330Ω Resistor (Orange, Orange, Brown, Gold) • 5x Jumper Wire Breadboard Setup Be sure to pay close attention to the polarity of the RGB LED. Hook up your circuit as pictured below: Page 15 of 38 MicroView Arduino Code Page 16 of 38 #include // include MicroView library MicroViewWidget *redWidget, *greenWidget, *blueWidget; lare 3 widget pointers int int int int int RED = 6; GREEN = 5; BLUE = 3; fadeStep = 10; dly=20; // // // // // declare declare declare declare declare RED LED pin 6 GREEN LED pin 5 BLUE LED pin 3 fading steps delay void setup() { uView.begin(); icroView uView.clear(PAGE); age redWidget = new MicroViewSlider(0,0,0,255); e RED widget as slider greenWidget = new MicroViewSlider(0,10,0,255); e GREEN widget as slider blueWidget = new MicroViewSlider(0,20,0,255); e BLUE widget as slider pinMode(RED, OUTPUT); D LED pin as OUTPUT pinMode(GREEN, OUTPUT); EN LED pin as OUTPUT pinMode(BLUE, OUTPUT); E LED pin as OUTPUT } void loop() { int i; e for general use // brightening for (i=0;isetValue(i); value for RED LED to widget uView.display(); tent of the screen buffer analogWrite(RED,i); value for RED LED to the pin delay(dly); } // dimming for (i=255;i>=0;i­=fadeStep) { 5 to 0 by fadeSteps redWidget­>setValue(i); uView.display(); analogWrite(RED,i); delay(dly); } // brightening for (i=0;isetValue(i); uView.display(); analogWrite(GREEN,i); delay(dly); // dec // start M // clear p // declar // declar // declar // set RE // set GRE // set BLU // init i variabl // step i from 0 t // set brightness // display the con // set brightness // step i from 25 Page 17 of 38 } // dimming for (i=255;i>=0;i­=fadeStep) { greenWidget­>setValue(i); uView.display(); analogWrite(GREEN,i); delay(dly); } // brightening for (i=0;isetValue(i); uView.display(); analogWrite(BLUE,i); delay(dly); } // dimming for (i=255;i>=0;i­=fadeStep) { blueWidget­>setValue(i); uView.display(); analogWrite(BLUE,i); delay(dly); } } What You Should See You should see your RGB LED go through a colorful sequence of various colors with the slider widget showing the value of each color channel’s brightness. Code to Note A for() loop is used to step a number across a range, and repeatedly runs code within the brackets {} until a condition is met. We use for loops to change over time the intensity of our RGB pin’s brightness. The variable “i” starts a 0, ends at 255, and increases by the amount of the variable fadeStep. for (i=0;isetValue(sensorValue); alue to the gauge widget uView.display(); get } // read value fro // set the sensorV // display the wid What You Should See You should see the potentiometer value being displayed on the MicroView’s display. Code to Note A “variable” is a stored value you’ve given a name to. You must introduce, or “declare” variables before you use them; here we’re declaring a variable called sensorValue, of type “int” (integer). Don’t forget that variable names are case-sensitive! int sensorValue; Page 22 of 38 We use the analogRead() function to read the value on an analog pin. analogRead() takes one parameter, the analog pin you want to use (“sensorPin”), and returns a number (“sensorValue”) between 0 (0 volts) and 1023 (5 volts). sensorValue = analogRead(sensorPin); Troubleshooting Sporadically Working This is most likely due to a slightly dodgy connection with the photoresistor’s pins. This can usually be conquered by pushing the photoresistor down into the breadboard. Still No Success? A broken circuit is no fun, send us an e-mail and we will get back to you as soon as we can: TechSupport@sparkfun.com Pull-up Resistors Many of the sensors you’ll use (potentiometers, photoresistors, etc.) are resistors in disguise. Their resistance changes in proportion to whatever they’re sensing (light level, temperature, sound, etc.). The MicroView’s analog input pins measure voltage, not resistance. But we can easily read voltage by using the MicroView’s internal pull-up resistors. Visit our pull-up resistors tutorial for more info. To get the most out of your photoresistor, we recommend replacing one of the resistors in a voltage divider circuit with a photoresistor. Experiment 6: Temperature Sensor A temperature sensor is exactly what it sounds like – a sensor used to measure ambient temperature. This particular sensor has three pins – a positive, a ground, and a signal. This is a linear temperature sensor. A change in temperature of one degree centigrade is equal to a change of 10 millivolts at the sensor output. The TMP36 sensor has a nominal 750 mV at 25°C (about room temperature). In this circuit, you’ll learn how to integrate the temperature sensor with your MicroView, and use the serial monitor to display the temperature. Heads up! When you’re building the circuit be careful not to mix up the transistor and the temperature sensor, they’re almost identical. Look for “TMP” on the body of the temperature sensor. Page 23 of 38 Parts Needed You will need the following parts: • 1x TMP36 Temperature Sensor • 2x Jumper Wire Breadboard Setup Hook up your circuit as pictured below: Be sure to insert the TMP36 in the correct orientation. It is polarized and will not work if inserted incorrectly. Once you are sure orientation is correct, you can place the remaining jumper wires. Page 24 of 38 MicroView Arduino Code #include // include MicroView library MicroViewWidget *widget; // declare widget pointer int sensorPin = A0; ature sensor int sensorValue = 0; from the sensor // select the input pin for the temper // variable to store the value coming void setup() { pinMode(sensorPin,INPUT); // set sensor pin as INPUT uView.begin(); // start MicroView uView.clear(PAGE); // clear page widget = new MicroViewGauge(32,24,0,255,WIDGETSTYLE 1); // declare as gauge widget uView.drawChar(47,33,67); // Character C is ASCII code 6 7 } void loop() { sensorValue= analogRead(sensorPin); nsor pin value float voltage = sensorValue * 5.0; e at pin in volt voltage /= 1024.0; e = sensorValue x (5/1024) float temperatureC = (voltage ­ 0.5) * 100 ; ltage ­ 0.5) x 100 widget­>setValue(temperatureC); perature value to the gauge uView.display(); y gauge tick } // read se // voltag // voltag // C = (vo // set tem // displa What You Should See As you warm and cool your temperature sensor, you should be able to see the gauge on your MicroView’s display go up or down. Troubleshooting Temperature Value is Unchanging Try pinching the sensor with your fingers to heat it up or pressing a bag of ice against it to cool it down. Still No Success? A broken circuit is no fun, send us an e-mail and we will get back to you as soon as we can: TechSupport@sparkfun.com Experiment 7: Servo Motors Servos are ideal for embedded electronics applications because they do one thing very well that motors cannot – they can move to a position accurately. By varying the pulse width of the output voltage to a servo, you can move a servo to a specific position. For example, a pulse of 1.5 milliseconds will move the servo 90 degrees. In this circuit, you’ll learn how to use PWM (pulse width modulation) to control and rotate a servo. To learn more about PWM, visit our tutorial. Parts Needed Page 25 of 38 You will need the following parts: • 1x Servo Motor • 3x Jumper Wire Breadboard Setup Hook up your circuit as pictured below: MicroView Arduino Code #include #include // include MicroView library // include Servo library Servo servo; // declare servo object void setup() { uView.begin(); uView.clear(PAGE); servo.attach(6); } // start MicroView // clear page // servo control pin at D6 void loop() { uView.setCursor(0,0); // set cursor to 0,0 uView.print("Mid "); // display Mid uView.display(); servo.write(90); // about 90 degree delay(2000); // delay 2 seconds uView.setCursor(0,0); uView.print("Left "); uView.display(); servo.write(20); // delay(2000); about 20 degree uView.setCursor(0,0); uView.print("Mid "); uView.display(); servo.write(90); // about 90 degree delay(2000); uView.setCursor(0,0); uView.print("Right"); uView.display(); servo.write(160); // about 160 degree delay(2000); } What You Should See Page 26 of 38 You should see your servo motor move to various locations at several speeds. If the motor doesn’t move, check your connections and make sure you have verified and uploaded the code, or see the troubleshooting tips below. Code to Note #include is a special “preprocessor” command that inserts a library (or any other file) into your sketch. You can type this command yourself, or choose an installed library from the “sketch / import library” menu. #include   The servo library adds new commands that let you control a servo. To prepare the Arduino to control a servo, you must first create a Servo “object” for each servo (here we’ve named it “servo”), and then “attach” it to a digital pin (here we’re using digital pin 6). Servo servo;  servo.attach(6);  The servo in this kit doesn’t spin all the way around, but they can be commanded to move to a specific position. We use the servo library’s write () command to move a servo to a specified number of degrees(0 to 160). Remember that the servo requires time to move, so give it a short delay() if necessary. servo.write(160);  Troubleshooting Servo Not Twisting Even with colored wires it is still shockingly easy to plug a servo in backward. This might be the case. Still Not Working A mistake we made a time or two was simply forgetting to connect the power (red and brown wires) to +5 volts and ground. Fits and Starts If the servo begins moving then twitches, and there’s a flashing light on your MicroView, the power supply you are using is not quite up to the challenge. Try using a USB adapter that provides more current. Still No Success? A broken circuit is no fun, send us an e-mail and we will get back to you as soon as we can: TechSupport@sparkfun.com Experiment 8: Piezo Buzzer Introduction In this circuit, we’ll again bridge the gap between the digital world and the analog world. We’ll be using a Piezo buzzer that makes a small “click” when you apply voltage to it (try it!). By itself that isn’t terribly exciting, but if you turn the voltage on and off hundreds of times a second, the buzzer will produce a tone. And if you string a bunch of tones together, you’ve got music! This circuit and sketch will play a classic tune. We’ll never let you down! Parts Needed Page 27 of 38 You will need the following parts: • 1x Piezo Buzzer • 2x Jumper Wires Breadboard Setup Hook up your circuit as pictured below: Page 28 of 38 MicroView Arduino Code Page 29 of 38 #include  // adapted from SparkFun Inventor Kit https://www.sparkfun.co m/products/12001 // Please download the original source code for detail commen t of the source code // http://cdn.sparkfun.com/datasheets/Kits/SIK%20Guide%20Code. zip const int buzzerPin = A0; const int songLength = 18; char notes[] = "cdfda ag cdfdg gf "; // a space represents a r est int beats[] = {1,1,1,1,1,1,4,4,2,1,1,1,1,1,1,4,4,2}; int tempo = 150; void setup()  {      uView.begin();     uView.clear(PAGE); pinMode(buzzerPin, OUTPUT); }  void loop()  {  int i, duration; for (i = 0; i < songLength; i++) // step through the song  arrays     {          duration = beats[i] * tempo;  // length of note/rest i n ms if (notes[i] == ' ')          // is this a rest?          {              uView.print(" ");             uView.display(); delay(duration);            // then pause for a mo ment         }  else // otherwise, play the n ote         {              uView.print(notes[i]);             uView.display(); tone(buzzerPin, frequency(notes[i]), duration); delay(duration);            // wait for tone to fi nish         }  delay(tempo/10);              // brief pause between n otes     }  // We only want to play the song once, so we'll pause fore ver: while(true){} // If you'd like your song to play over and over, // remove the above statement }  int frequency(char note)  {  // This function takes a note character (a­g), and return Page 30 of 38 s the // corresponding frequency in Hz for the tone() function. int i; const int numNotes = 8;  // number of notes we're storing // The following arrays hold the note characters and their // corresponding frequencies. The last "C" note is upperca se // to separate it from the first lowercase "c". If you wan t to // add more notes, you'll need to use unique characters. // For the "char" (character) type, we put single characte rs // in single quotes. char names[] = { 'c', 'd', 'e', 'f', 'g', 'a', 'b', 'C' }; int frequencies[] = {262, 294, 330, 349, 392, 440, 494, 52 3}; // Now we'll search through the letters in the array, and  if // we find it, we'll return the frequency for that note. for (i = 0; i < numNotes; i++)  // Step through the notes     {  if (names[i] == note)         // Is this the one?         {  return(frequencies[i]);     // Yes! Return the fre quency         }      }  return(0);  // We looked through everything and didn't fin d it, // but we still need to return a value, so return 0. }  What You Should See You should see - well, nothing; but you should be able to hear a song. If it isn’t working, make sure you have assembled the circuit correctly and verified and uploaded the code to your MicroView or see the troubleshooting tips below. Code to Note Up until now we’ve been working solely with numerical data, but the Arduino can also work with text. Characters (single, printable, letters, numbers and other symbols) have their own type, called “char”. When you have an array of characters, it can be defined between double-quotes (also called a “string”), OR as a list of single-quoted characters. char notes[] = "cdfda ag cdfdg gf ";  char names[] = {'c','d','e','f','g','a','b','C'};  One of Arduino’s many useful built-in commands is the tone() function. This function drives an output pin at a certain frequency, making it perfect for driving buzzers and speakers. If you give it a duration (in milliseconds), it will play the tone then stop. If you don’t give it a duration, it will keep playing the tone forever (but you can stop it with another function, noTone() ). tone(pin, frequency, duration);  Page 31 of 38 Troubleshooting No Sound Given the size and shape of the piezo element it is easy to miss the right holes on the breadboard. Try double checking its placement. Can’t Think While the Melody is Playing Just pull up the piezo element whilst you think, upload your program then plug it back in. Still No Success? A broken circuit is no fun, send us an e-mail and we will get back to you as soon as we can: TechSupport@sparkfun.com Experiment 9: Spinning a Motor Introduction Remember before when you played around with a servo motor? Now we are going to tackle spinning a motor. This requires the use of a transistor, which can switch a larger amount of current than the MicroView can. When using a transistor, you just need to make sure its maximum specs are high enough for your use. The transistor we are using for this circuit is rated at 40V max and 200 milliamps max – perfect for our toy motor! When the motor is spinning and suddenly turned off, the magnetic field inside it collapses, generating a voltage spike. This can damage the transistor. To prevent this, we use a “flyback diode”, which diverts the voltage spike around the transistor. Parts Needed You will need the following parts: • • • • • 1x 330Ω resistor (Orange Orange Brown Gold) 1x Transistor 1x Diode 1x Motor 4x Jumper Wires Breadboard Setup Pay close attention when building this circuit as there are two polarized parts that must be inserted into the breadboard correctly in order for this circuit to work. The first polarized part is a transistor. The second is a diode. Page 32 of 38 Hook up the rest of your circuit as pictured below: Page 33 of 38 MicroView Arduino Code #include // include MicroView library int motorPIN = 3; MicroViewWidget *widget; // set motor control pin // declare widget pointer void setup() { uView.begin(); // start MicroView uView.clear(PAGE); // clear page pinMode(motorPIN, OUTPUT); // initialize the digital pin as an output. widget = new MicroViewGauge(32,24,90,255,WIDGETSTYLE 1); // set widget as gauge STYLE1 setPwmFrequency(motorPIN,1); // set PWM frequency to ab out 31K } void loop() { for (int i=90;isetValue(i); uView.display(); analogWrite(motorPIN, i); he motorPIN delay(500); } } // step i from 90 to 255 b // set i value to gauge // display gauge // set the DUTY cycle of t // delay 500 ms // function to set the frequency of the PWM pin // adapted from http://playground.arduino.cc/Code/PwmFrequency void setPwmFrequency(int pin, int divisor) { byte mode; if(pin == 5 || pin == 6 || pin == 9 || pin == 10) { switch(divisor) { case 1: mode = 0x01; break; case 8: mode = 0x02; break; case 64: mode = 0x03; break; case 256: mode = 0x04; break; case 1024: mode = 0x05; break; default: return; } if(pin == 5 || pin == 6) { TCCR0B = TCCR0B & 0b11111000 | mode; } else { TCCR1B = TCCR1B & 0b11111000 | mode; } } else if(pin == 3 || pin == 11) { switch(divisor) { case 1: mode = 0x01; break; case 8: mode = 0x02; break; case 32: mode = 0x03; break; case 64: mode = 0x04; break; case 128: mode = 0x05; break; case 256: mode = 0x06; break; case 1024: mode = 0x7; break; default: return; } TCCR2B = TCCR2B & 0b11111000 | mode; } } What You Should See Page 34 of 38 The DC Motor should spin if you have assembled the circuit’s components correctly, and also verified/uploaded the correct code. If your circuit is not working check the troubleshooting section below. Code to Note In this code, we use the command setPwmFrequency(motorPIN,1); to call a function (an encapsulated section of resuable code) for setting the PWM Frequency. Pulse Width Modulation, or PWM, is a technique for getting analog results with digital means. Digital control is used to create a square wave, a signal switched between on and off. The setPwmFrequency function is defined on line 25. void setPwmFrequency(int pin, int divisor){ ... } Troubleshooting USB Port not providing enough power or tripping? Some USB ports don’t provide enough current to spin the motor. If that’s the case with a USB port on your computer we recommend powering your MicroView and motor with a powered USB hub or by using batteries. Checkout this circuit for powering your motor with batteries. Motor Not Spinning If you sourced your own transistor, double check with the data sheet that the pinout is compatible with a P2N2222AG (many are reversed). Still No Luck If you sourced your own motor, double check that it will work with 5 volts and that it does not draw too much power. Still No Success? A broken circuit is no fun, send us an e-mail and we will get back to you as soon as we can: TechSupport@sparkfun.com Experiment 10: Relays A relay is basically an electrically controlled mechanical switch. Inside that harmless looking plastic box is an electromagnet that, when it gets a jolt of energy, causes a switch to trip. In this circuit, you’ll learn how to control a relay like a pro – giving your MicroView even more powerful abilities! Parts Needed You will need the following parts: • • • • • • • 2x 330Ω resistor (Orange Orange Brown Gold) 1x Transistor 1x Diode 1x Yellow LED 1x Red LED 1x Relay 11x Jumper Wires Breadboard Setup Hook up your circuit as pictured below. Be cautious of polarized parts. Refer back to previous experiments to see how each component is oriented. For the relay, pay attention to which side has two pins and which has three pins. Page 35 of 38 MicroView Arduino Code #include // include MicroView library int relayPin = 2; duino // set relayPin as pin 2 of Ar void setup() { uView.begin(); uView.clear(PAGE); pinMode(relayPin, OUTPUT); as an output. } // start MicroView // clear page // initialize the digital pin void loop() { uView.setCursor(0,0); uView.print("YELLOW"); uView.display(); digitalWrite(relayPin, HIGH); H is the voltage level) delay(1000); uView.setCursor(0,0); uView.print("RED "); uView.display(); digitalWrite(relayPin, LOW); aking the voltage LOW delay(1000); } // // // // set cursor at 0,0 print YELLOW text display turn the RELAY ON (HIG // wait for a second // turn the RELAY off by m // wait for a second What You Should See You should be able to hear the relay contacts click, and see the two LEDs alternate illuminating at 1-second intervals. If you don’t, double-check that you have assembled the circuit correctly, and uploaded the correct sketch to the MicroView. Also, see the troubleshooting tips below. Code to Note When we turn on the transistor, which in turn energizes the relay’s coil, the relay’s switch contacts are closed. This connects the relay’s COM pin to the NO (Normally Open) pin. Whatever you’ve connected using these pins will turn on. (Here we’re using LEDs, but this could be almost anything.) digitalWrite(relayPin, HIGH); The relay has an additional contact called NC (Normally Closed). The NC pin is connected to the COM pin when the relay is OFF. You can use either pin depending on whether something should be normally on or normally off. You can also use both pins to alternate power to two devices, much like railroad crossing warning lights. Page 36 of 38 digitalWrite(relayPin, LOW); Troubleshooting LEDs Not Lighting Double-check that you’ve plugged them in correctly. The longer lead (and non-flat edge of the plastic flange) is the positive lead. No Clicking Sound The transistor or coil portion of the circuit isn’t quite working. Check the transistor is plugged in the right way. Not Quite Working The included relays are designed to be soldered rather than used in a breadboard. As such you may need to press it in to ensure it works (and it may pop out occasionally). When you’re building the circuit be careful not to mix up the temperature sensor and the transistor, they’re almost identical. Still No Success? A broken circuit is no fun, send us an e-mail and we will get back to you as soon as we can: TechSupport@sparkfun.com Experiment 11: Soft Potentiometer Introduction In this circuit you’ll work with a soft potentiometer. Back in Experiment 2, you used a regular potentiometer to vary the resistance of a circuit. With the soft pot, you can do all the same things you would with a regular potentiometer. However, this time the interface changes, showing you how you can accomplish the same tasks with different forms of the same technology or with different technologies altogether. Parts Needed You will need the following parts: • 1x Soft Potentiometer • 2x 330Ω resistor (Orange Orange Brown Gold) • 2x Jumper Wires Breadboard Setup Hook up your circuit as pictured below. The soft pot is polarized, so pay attention to its orientation. The side with the adhesive back is the bottom, and the side with the touch strips is the top (as pictured below). Page 37 of 38 MicroView Arduino Code #include ry // include MicroView libra MicroViewWidget // declare widget pointer *widget; int sensorValue; re sensor value int sensorPin=A0; 0 of Arduino // declare variable to sto // declare sensor pin as A void setup() { uView.begin(); // start MicroView uView.clear(PAGE); // clear page widget = new MicroViewSlider(0,0,0,1024, WIDGETSTYLE 1); // declare widget as slider pinMode(sensorPin, INPUT); // set sensor pin as INPUT } void loop () { sensorValue=analogRead(sensorPin); sensor value widget­>setValue(sensorValue); e to widget uView.display(); delay(20); } What You Should See // read and store // set sensor valu // display widget // delay 20 ms Page 38 of 38 As you move a blunt long object (like your finger) up and down the soft potentiometer, the MicroView Slider Widget should change it’s value accordingly. If it isn’t working, make sure you have assembled the circuit correctly and verified and uploaded the code to your MicroView, or see the troubleshooting tips below. Troubleshooting Bizarre Results The most likely cause of this is if you’re pressing the potentiometer in more than one position. This is normal and can actually be used to create some neat results. Still No Success? A broken circuit is no fun, send us an e-mail and we will get back to you as soon as we can: TechSupport@sparkfun.com Resources and Going Further Congratulations, you have completed the SparkFun Inventor’s Kit for MicroView! From here, the world is your oyster. Here are some more resources to aid in your understanding of the MicroView. • MicroView GitHub Repository - All the source files for everything MicroView related. • Explore the MicroView Library - Learn about the functions that control the MicroView and its OLED screen. • Creating Your Own Fonts for the MicroView - Learn how to fully utilize the OLED screen embedded within the MicroView. • MicroView Bootloader Installation - Should you ever need to reflash the bootloader on your MicroView, we have an extensive guide covering that process. Check out these other experiment guides for more learning fun! • • • • • • SparkFun Inventor’s Kit SparkFun Inventor’s Kit for RedBot mbed Starter Kit Experiment Guide Intel Galileo Experiment Guide Digital Sandbox Experiment Guide LogicBlocks Experiment Guide https://learn.sparkfun.com/tutorials/sparkfun-inventors-kit-for-microview/all 4/16/2015
KIT-13205 价格&库存
很抱歉,暂时无法提供与“KIT-13205”相匹配的价格&库存,您可以联系我们找货
