Adafruit Metro 328 Starter Pack
PRODUCT ID: 68
Heard about Arduino IDE-compatibles but not sure how to start? The Adafruit
Metro is an ATmega328-based (like a lot of our own products) development
board. Since it is shaped the same, and code/shield-compatible with the
Arduino UNO R3 design, our Adafruit Metro is easy to use and hacker friendly
and this is the perfect beginner kit for learning how to use the Adafruit Metro!
This bundle is designed to get you started quickly and easily on your path of
learning electronics. Once you've received your starter pack you can follow
the introductory tutorials here on my site, designed for everyone, even people
with little or no electronics and programming experience. The starter pack has
everything you need (except tools) for most of the lessons.
It includes:
Adafruit Metro 328 w/ Headers - The Adafruit Metro - assembled and
ready to go, including 4 rubber feet
MicroUSB Cable - Perfect for connecting your Metro to a computer
Protoshield Kit - Get hacking with the best prototyping shield out there!
Tiny Breadboard - Fits on top of the protoshield, easy to use
9V DC regulated wall adapter - You can power your Metro from any wall
socket. This switching regulator is efficient and small and works with US
(110V) and European (220V) power.
9V Battery case with switch and a 2.1mm plug- so you can power your
Metro using a 9V battery. This case is much sturdier than just a battery
clip and it has an on/off switch too! Note that this comes unassembled
Tutorial starter pack parts - Includes a 10K potentiometer, 1K
potentiometer, 2 small pushbuttons, 5 red diffused bright LEDs, one each
of red, green and blue ultra-bright LED, 5 100 ohm resistors, 5 1K
resistors, 5 10K resistors, and a CdS photocell sensor.
Also includes 65 flexible breadboard wires in 8 colors, perfect for use
with the solderless breadboard.
https://www.adafruit.com/product/68 4‐26‐18
很抱歉,暂时无法提供与“68”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+429.561831+55.45284
