KIT0112
KIT0112
    DFROBOT
    GRAVITYSENSORKITLATTEPANDA
KIT0112 数据手册
Gravity: Starter Sensor Set for LattePanda V1.0 SKU:KIT0112 If you want to use your LattePanda V1.0 for physical computing, this kit is the perfect choice to get started! You dont need a PhD degree in electronic engineering to use it - it is aimed at tinkerers who like to experiment and play. Every sensor comes with a LattePandacompatible Gravity interface connector, so no need to worry about compatibility issues! The LattePanda Starter Sensor Set is a DFRobot Gravity series product. The DFRobot Gravity Series is an open-source, plug and play electronics toolkit for anyone to create anything. With dozens of standardized functional modules and powerful expansion boards, Gravity Series allows users of any skill level to easily connect, mix and develop their own projects that are compatible with Arduino and other microcontroller platforms. Click here to learn more about this product series. PIR motion sensor connected with LattePanda What is LattePanda? LattePanda is a complete Windows 10 computer on a single board! It includes everything a regular PC has and can do anything that a regular PC does. It is compatible with almost every gadget you know: printers, joysticks, cameras and more. Any peripherals that work on your PC will work on LattePanda. LattePanda comes pre-installed with a pre-activated full edition of Windows 10, including powerful tools such as Visual Studio, NodeJS, Java, Processing, and more. Using existing APIs, you can develop your own software and hardware projects on LattePanda as you would on a normal PC - C#, Javascript, Ruby and so on. Say goodbye to your bulky laptop! Please note LattePanda is not included in the kit. SPECIFICATION • Suitable for LattePanda V1.0 (not compatible with LattePanda Alpha & Delta) • Great for experimenting and learning • Useful for a wide array of projects • Bundles the most popular DFRobot Sensors SHIPPING LIST PIR (Motion) Sensor x 1 https://media.digikey.com/pdf/Data%20Sheets/DFRobot%20PDFs/SEN0171_Web.pdf Analog Gas Sensor(MQ2) x 1 https://media.digikey.com/pdf/Data%20Sheets/DFRobot%20PDFs/SEN0127_Web.pdf Analog Flame Sensor x 1 https://media.digikey.com/pdf/Data%20Sheets/DFRobot%20PDFs/DFR0076_Web.pdf Gravity: Analog LM35 Temperature Sensor For Arduino x 1 https://media.digikey.com/pdf/Data%20Sheets/DFRobot%20PDFs/DFR0023_Web.pdf Analog Ambient Light Sensor x1 https://media.digikey.com/pdf/Data%20Sheets/DFRobot%20PDFs/SEN0043_Web.pdf Crash sensor(Left) x 1 https://media.digikey.com/pdf/Data%20Sheets/DFRobot%20PDFs/SEN0138-L_Web.pdf Crash sensor(Right) x 1 https://media.digikey.com/pdf/Data%20Sheets/DFRobot%20PDFs/SEN0138-R_Web.pdf Digital Push Button (White) x 1 https://media.digikey.com/pdf/Data%20Sheets/DFRobot%20PDFs/DFR0029-W_Web.pdf Digital Push Button (Blue) x 1 https://media.digikey.com/pdf/Data%20Sheets/DFRobot%20PDFs/DFR0029-B_Web.pdf Analog Rotation Sensor V2 x 1 https://media.digikey.com/pdf/Data%20Sheets/DFRobot%20PDFs/DFR0058_Web.pdf Digital Blue LED Light Module x 1 https://media.digikey.com/pdf/Data%20Sheets/DFRobot%20PDFs/DFR0021-B_Web.pdf Digital RED LED Light Module x 1 https://media.digikey.com/pdf/Data%20Sheets/DFRobot%20PDFs/DFR0021-R_Web.pdf Digital White LED Light Module x 1 https://media.digikey.com/pdf/Data%20Sheets/DFRobot%20PDFs/DFR0021-W_Web.pdf Relay Module V3.1 (Arduino Compatible) x 1 https://media.digikey.com/pdf/Data%20Sheets/DFRobot%20PDFs/DFR0017_Web.pdf Gravity Sensor cable x 14 https://www.dfrobot.com/product-1428.html/10-14-19
KIT0112 价格&库存
很抱歉,暂时无法提供与“KIT0112”相匹配的价格&库存,您可以联系我们找货
