Grove Indoor Environment Kit for Intel® Edison
SKU 110060064
Create indoor applications easily Rich grove modules and cables Cool demo codes No coding experience
required
Create Cool Indoor Environment Applications without Programming Experience!
A functional kit to help you explore and interact with your indoor environment. A bundle of
various sensors expands your imagination in rapid prototyping based on an Intel Edison
development board.
WHAT IS IT?
Grove Indoor Environment Kit for Intel® Edison makes it easy to create complete
indoor environment applications with Intel Edison and Arduino Breakout Board. With the
Base shield V2, developers can plug up to 11 different Grove sensors and actuators quickly.
We provide cool demo codes which are constantly updated, so as to make it simple to
operate even without any programming experience.
WHAT'S INSIDE?
Base Shield V2 x 1
Grove ‐ LCD RGB Backlight x 1
Grove – Temperature & Humidity Sensor x 1
Grove ‐ Relay x 1
Grove ‐ Moisture Sensor x 1
Grove ‐ Servo x 1
Grove ‐ Light Sensor x 1
Grove ‐ Buzzer x 1
Grove ‐ UV Sensor x 1
9V to Barrel Jack Adapter x 1
Grove ‐ PIR Motion Sensor x 1
26AWG Grove Cables x 2
Grove ‐ Encoder x 1
USB Cable x 1
Grove ‐ Button x 1
User Guide x 1
PROJECTS
Project 1: Light Control Switch
How does it work?
When the illumination<300, the servo will drive the switch. Just connect to PC, open the
Serial Monitor and type the command “set light<300, servo=90”, then click “Send” button.
Part list:
Grove ‐ Light Sensor, Grove – Servo, 26AWG Grove Cables
Project 2: Infrared Lamp
How does it work?
Connect to PC, open the Serial Monitor and type the command “set pir=1, relay=1”, then
click “Send” button. Then turn on the power, the PIR Motion Sensor will lighten the lamp
when it feels body motions or people passing by.
Part list:
Grove ‐ PIR Motion Sensor, Grove – Relay, 26AWG Grove Cable
Project 3: UV Alarm
How does it work?
The buzzer will alarm when UV goes beyond 55. Connect to your PC, open the Serial
Monitor and type the command “set uv>55, buzzer=1”, then click “Send” button.
Technical details
Dimensions
200mm x132mm x73mm
Weight
G.W 578g
Battery
Exclude
Part List
1
ECCN/HTS
ECCN
EAR99
HSCODE
9023009000
USHSCODE
9023000000
UPC
841454100379
ROHS
1
https://www.seeedstudio.com/Grove‐Indoor‐Environment‐Kit‐for‐Intel‐Edison‐p‐2427.html/6‐18‐19
很抱歉,暂时无法提供与“110060064”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+696.534921+90.21367
