110020109
110020109
    SEEED(矽递科技)
    GROVE STARTER KIT FOR ARDUINO
110020109 数据手册
      Grove Starter kit for Arduino&Genuino 101 SKU 110020109   Rapid prototyping Well‐chosen Grove modules Easy‐to‐use base shield Holding both an Arduino/Genuino 101and a nice idea but don’t know where to start? This kit can help you on that. It introduces the simplicity of Grove System to your Arduino project. The Grove Base Shield works perfectly on the Arduino/Genuino 101 or any development board that applies the Arduino Uno form factor. With a bunch of well‐chosen and plug‐and‐play Grove modules, you can set up a project and turn your idea into real thing easily and quickly. Now check out the part list below to see what we’ve prepared for you! NOTE: This kit DOES NOT include the Arduino/Genuino 101.    Features Plug‐N‐play Grove system Easy‐to‐use base shield for Arduino/Genuino 101 Various well‐chosen Grove sensors and actuators for rapid prototyping Technical details Dimensions 0mm x0mm x0mm Weight G.W 328g Battery Exclude Part List Grove‐ Button 1 Grove – Sound Sensor 1 v1.2 Grove – Touch Sensor 1 Grove – Light Sensor 1 v1.2 Grove – Temperature 1 Sensor v1.1 Grove – Rotary Angle Sensor(P) 1 Grove – Piezo Vibration 1 Sensor Grove – LCD RGB 1 Backlight Grove – Buzzer 1 Grove – LED v1.3 1 Gear Stepper Motor with 1 Driver Grove Base Shield v2 1 Grove Universal 4 Pin 1 Cable Red LEDs 1 Green LEDs 1 Blue LEDs 1 ECCN/HTS ECCN EAR99 HSCODE 9023009000 USHSCODE 9023000000 UPC 84145411784       https://www.seeedstudio.com/Grove‐Starter‐kit‐for‐Arduino‐Genuino‐101‐p‐2664.html/6‐18‐19
110020109 价格&库存
很抱歉,暂时无法提供与“110020109”相匹配的价格&库存,您可以联系我们找货
